ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
View Poll Results: OEM M5 Brake transplant on a Z4M?
Dude you are insane, do it and please the ///M gods. 4 22.22%
No way it will work. 0 0%
This thread is already lame, please change your name for the 5th time and go away forever. 12 66.67%
I am interested in this and if it works would like to be next in line 0 0%
Why not go with Brembo? 1 5.56%
the juice isn't worth the squeeze 4 22.22%
Multiple Choice Poll. Voters: 18. You may not vote on this poll
      06-27-2012, 12:06 PM   #1
Z4-VILLA
Afghanistan
114
Drives: Z4M Hardtop Roadster
OEM M5 Brake crossover to a Z4M (no pics yet)
This is a little adventure that I am about to embark on since an entire OEM brake kit off of an M5 fell into my lap.
Any thoughts would be appreciated.
      06-27-2012, 12:27 PM   #2
Mirko
Mirko's Avatar
182
Drives: E86 Z4M, E90 328i, E84 X1
What are measurements of the M5 rotors? How much modification is required? What about the size of the master cylinder? It has to be bigger in the M5.
Would love to see this get pulled off, but will the cost associated be more or less than just getting a stoptech kit off the shelf?
      06-27-2012, 12:45 PM   #3
Z4-VILLA
Afghanistan
114
stoptech? I like original equipment... I don't have any of the specs of this project as it literally has just taken it off. I will update accordingly
      06-27-2012, 12:46 PM   #4
DataStream18
45
Drives: 2003 ESS TS1 Z4
Holy hell that would be massive!
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit.
      06-27-2012, 12:54 PM   #5
Z4-VILLA
Afghanistan
114
if you can bypass labor byknowing someone who is skillful with the welding in all that with the bolts and what not the actual part of the m5 brake itself isn't that devastating
      06-27-2012, 12:54 PM   #6
Z4-VILLA
Afghanistan
114
this was all inspired by my recent viewing of an m3 front bumper morphed onto a z 4
      06-27-2012, 12:56 PM   #7
Z4-VILLA
Afghanistan
114
that's what she said.
      06-27-2012, 01:06 PM   #8
ZStig
instagram 997turbotom
284
Drives: Interlagos Z4MR
I'm sorry to hear that. I usually hear that it IS massive, not WILL be massive after significant mods.
      06-27-2012, 01:10 PM   #9
DataStream18
45
HAHAHAHAHA
      06-27-2012, 01:11 PM   #10
dorifto88
49
Drives: 88 Nissan Pathfinder
id add another option, porsche calipers.
http://www.rallyroad.net/content/e46...apter-brackets
not what you want to hear though lol.
good luck
      06-27-2012, 01:19 PM   #11
Z4-VILLA
Afghanistan
114
good luck
god damnit you posting those porsche brakes makes me mad... yes I will try my best to make this work with my shop
      06-27-2012, 01:26 PM   #12
Z4-VILLA
Afghanistan
114
tom you are a bastardo!
      06-27-2012, 07:54 PM   #13
Z4-VILLA
Afghanistan
114
well damn poll option 3 has 2 hits....wtf lol
      06-28-2012, 09:08 AM   #14
Z4-VILLA
Afghanistan
114
Pic of part
      06-28-2012, 12:22 PM   #15
ZStig
284
Good luck, and don't forget that without a bigger brake master cylinder the pedal will go straight to the floor
      06-28-2012, 12:34 PM   #16
Z4-VILLA
Afghanistan
114
i wonder about abs too
      06-28-2012, 12:44 PM   #17
beta
80
Drives: 2006 M Roadster
Just putting bigger brakes on there isn't going to make it stop better. More than likely you're going to affect your brake bias and end up with a worse braking distance. That is unless you do a lot of testing and adjust accordingly.
If it was me, I'd start by recording some 60-0 and 90-0 stops, seeing how many feet it takes to stop on average. Then after the mod is done do the same test and verify that your stopping distance is same or better, and if not keep adjusting until it is.
There's a lot of testing that goes into a kit like Brembo or Stoptech.
      06-28-2012, 12:47 PM   #18
Z4-VILLA
Afghanistan
114
challenge accepted.
      06-28-2012, 12:52 PM   #19
Z4-VILLA
Afghanistan
114
true...I think it will be easier than many of u predict. I've seen too many swaps with engines. ......
      06-28-2012, 01:08 PM   #20
Rated M Roadster
Rated M Roadster's Avatar
162
Drives: F10 M5, i3, Z4M
This might help: http://www.tceperformanceproducts.com/bias-calculator/
Good luck.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      06-28-2012, 01:47 PM   #21
Beedub
United Kingdom
423
Drives: 2007 Z4 M roadster vt2-500
those better not be your shoes barney...... fo Realll.....
btw i like the upgrade BUT.... BUT... are you aware that Ap, Brembo, stoptech, alcon and the likes spent huge amount of time getting the piston sizes to match so you still get a nice pedal ect ect....
that said you may get lucky and these bad boys just bolt right on..... if it was me, id have gone for a top brand off the shelf BBK that was deisgned to fit our car.... they are a pain enough to fit anyway never mind fitting something that was never designed for the car..... Also the Ap 6 pot is very light... quite abit lighter than the stock caliper, you may well be adding weight on each corner here.
well done for trying though... keep it and and keep the pics coming.... with all this stopping power you better have the vt1 under the hood....
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      06-28-2012, 03:17 PM   #22
Z4-VILLA
Afghanistan
114
I'm still gonna try this
zpost
