06-26-2012, 01:44 PM | #1 |
64
Rep 760
Drives: E82 135i & F80 M3
135i N54 DP->Midpipe->Axleback Gaskets
I recently purchased a used set of Berk Full DP Back Street exhaust from a fellow member off the forums. Their coming in Friday and I want to have everything I need to get them installed same day as they arrive.
My question is, what gaskets do you guys recommend I use? I know I want new ones, as gaskets are fairly cheap and exhaust leaks is something I dont want to deal with. I've googled online and it looks like the OEM ones have this coating on them, while I've also found some after-market (Berk, Maddad) ones that seem to be just regular stainless steel. I believe these are OEM: http://www.ecstuning.com/BMW-E82-135i-N54_3.0L/ES40634/ Aftermarket: http://www.berktechnology.com/produc...exhaust-gasket What does everyone recommend? EDIT:: I also know I'll need more than just one type, as there are the 2x DP->Midpipes & 1x Midpipes->Axleback connections. Where are the 2.5in & 3inch ones? Do I need any more? |
06-26-2012, 03:23 PM | #2 |
15
Rep 187
I bought 2 2.5" copper gaskets (http://www.summitracing.com/parts/SCE-4200/) for the DP->MP connections. They stick out a little at the bolt corners but don't leak. I had previously used the ones that came with PLM DPs but they were leaking.
The MP->Axle back connection uses a donut gasket. I had to special order it from my dealer. As long as your exhaust is setup like the stock exhaust those are the 3 gaskets. |
06-26-2012, 03:41 PM | #3 | |
European Editor
10589
Rep 22,992
http://realoem.com/bmw/showparts.do?...70&hg=18&fg=10 you will need... #2 & #11 (2) 18307553603 gaskets (1) 18117553130 gasket/ring #12 & #13 bolts & springs (2) 18307790610 spring (2) 18307561670 bolts Post #17... http://www.1addicts.com/forums/showt...ht=18117553130
06-26-2012, 04:35 PM | #4 | |
64
Rep 760
06-26-2012, 05:03 PM | #5 | |
European Editor
10589
Rep 22,992
No. The part numbers are only to install a N55 mid pipe. Just use RealOEM.com to look up those other gaskets.
06-26-2012, 11:40 PM | #6 |
64
Rep 760
is a photo of the full exhaust. I've decided to purchase the two OEM gaskets from the DP's to the first section of the mid pipes. My question is what gaskets should I utilize for the Midpipe -> Midpipe Y Connection? And lastly the 3" Midpipe Y connection to the Axleback? What makes this question difficult is the OEM N54/N55 midpipes are composed of a single set of pipes which mate to the axleback. |
04-24-2015, 03:44 PM | #7 | |
Rep 55
Did you end up needing an additional two gaskets for Midpipe pt1 > Midpipe pt2?
And what did you end up using for the donut gasket from Midpipe pt2 > axle Thanks Quote:
