05-28-2012, 09:41 PM | #2 |
ti fan
67
Rep 273
Drives: 14 12C | 17 X5 50i | 19 M2C
Garage List 2014 McLaren 12C Sp ... [0.00]
2017 BMW X5 xDrive50i [0.00] 2019 BMW M2 Competi ... [0.00] 2008 BMW 535xi Touring [10.00] 2008 BMW 135i [10.00] |
You can adjust it somewhat to maybe -1 degree for the fronts. The rear are more flexible. Adjusting the front significantly requires removing the camber pin on the top hats for the front.
05-28-2012, 09:43 PM | #3 |
43
Rep 440
thanks for the quick response. is adjusting it a somewhat easy task?
05-29-2012, 05:29 AM | #4 |
105
Rep 2,696
It's extremely easy...it takes about 5 minutes total once you get the pins out
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
05-29-2012, 09:36 AM | #5 |
43
Rep 440
And taking these pins out will not harm anything correct?
05-29-2012, 03:01 PM | #7 |
117
Rep 1,664
Drives: E82 N55 DCT
05-29-2012, 07:19 PM | #8 | |
43
Rep 440
05-29-2012, 08:35 PM | #10 |
43
Rep 440
some are saying the same...and some say they get -1*....
05-29-2012, 09:24 PM | #11 |
117
Rep 1,664
Drives: E82 N55 DCT
It will be pretty close to -1*
Do you have M3 control arms? Those would bump you slightly above -1*
05-29-2012, 09:51 PM | #13 |
43
Rep 440
what are you at now with the dinan plates?
05-29-2012, 10:20 PM | #14 |
ti fan
67
Rep 273
I have a spare set of Dinan plates if you want to buy some
05-29-2012, 10:55 PM | #15 |
43
Rep 440
I will keep that in mind, I may be serious about buying them within a couple week.s
05-29-2012, 11:40 PM | #17 |
650
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
So with Performance suspension, M3 control arms and Dinan plates I could expect something similar?
05-30-2012, 07:40 AM | #19 | |
111
Rep 810
With PS, pulled pins, M3 Bits, and Dinan Plates, I am at -2.3* I believe. 235's fit comfortable with only the mild PS drop btw. |
05-30-2012, 08:37 AM | #20 |
117
Rep 1,664
Drives: E82 N55 DCT
Okay... before this gets out of hand
Pulled pin: -1* Pulled pin and M3 control arms: -1.5* Coilovers, camber plates, lowered, M3 control arms: -3* I have KW V2 coilovers, Vorshlag camber plates, HPA endlinks, M3 control arms, M3 sway bars
05-30-2012, 09:33 AM | #21 |
240
Rep 462
With stock suspension and pins pulled, the most I could get was -0.6 deg in the front.
Yesterday I had Dinan camber plates, M3 tension rods and M3 wishbones installed, and was able to max out at -1.8 deg in the front. |
05-30-2012, 09:59 AM | #22 |
111
Rep 810
I believe M3 arms are widely accepted as giving about -.75* camber. Bogart, your numbers for the pin only are higher (more negative that is) than a home else I've seen here. Your numbers with pin and control arms looks about as expected.
In my opinion...starting from only a few tents negative while purely stock, this is about what I got with each mod: Pulled pin = .3* Performance Suspension: .5* M3 arms = .7* Dinan Camber Plates: .7* In terms of best order to install, I'd recommend M3 arms before camber plates because the arms get you the same camber but also stiffer bushings. |
