KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
05-28-2012, 12:07 PM | #1 |
221
Rep 2,339
265/30/20 possible on the front wheels?
Looking to try and fit a set of Michelin PSS on my HRE P40s. The wheels are 20x9 in front ET28 and I'm lowered on Eibach springs. It would be combined with 285/30/20 rears on 20x10.5 ET28.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
05-28-2012, 12:24 PM | #2 | |
2306
Rep 13,010
It will rub at the front when at full lock... and then the fender liner plastic in that particular spot will get shaved enough as not rub anymore after a 1000 miles or so. |
05-28-2012, 02:27 PM | #3 | |
221
Rep 2,339
So only rubbing at full lock? I notice your offset is a bit further out than mine but my wheel is .5" narrower. I wonder if that will cause an issue. Do you know exactly where on the liner it was rubbing? Was it further into the wheel well or closer to the fender? Front or rear of the wheel well? If it's that minor, I think I can deal with that for a month or so while the liner wears.
05-29-2012, 05:59 AM | #4 | |
2306
Rep 13,010
Rubbing is only at full lock, and it is an issue of diameter and not offset or wheel width: 265/30/20 is simply taller than OEM specs. |
05-30-2012, 03:03 PM | #5 |
Taiwan
11
Rep 122
808M
I'm runing nitto invo 255/30/20 and 295/25/20 No rubbing on the street, but on the track..... I'm going to get 18' for the track, but I'm also planing to replace my invo next month. I'm thinking 265/30/20 and 295/30/20 I know the rear is fine, but just worry about the front, 255/30 is 9mm taller than OEM, but 265/25 is 15mm taller..... Are you getting 265/30 soon? |
05-30-2012, 05:48 PM | #6 |
221
Rep 2,339
Not anytime soon. Maybe 6-9 months at the earliest.
06-04-2012, 11:55 PM | #8 |
221
Rep 2,339
295/30/20 is way too big. 285/30/20 is already 1/2" larger than stock.
06-06-2012, 11:16 AM | #9 |
45
Rep 867
06-06-2012, 11:40 AM | #10 |
221
Rep 2,339
I don't really care for the 295/25/20 option because the overall diameter is quite a bit less than stock so you'd actually be reversing the stagger by making your front tire diameter larger than the rear. 285/30/20 is the only size which would maintain the 0.5" stagger. 305/25/20 is also an option but its still smaller than the stock rear tire so again you'd be reversing the stagger. 305/25/20 also could cause problems if you're very low, have an aggressive offset, or run tires with very squared shoulders.
06-06-2012, 12:46 PM | #11 |
732
Rep 3,972
A 265/30/20 is 26.3" tall, while OEM is right at that height. I'm with Tech on this. It will rub possibly. Although, Malek ran the OEM rears on the front with a ET25 ZCP wheel and he didn't rub. I still don't know how as my 26" 255/35/19 is just a hair away from rubbing.
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
06-06-2012, 03:15 PM | #12 | |
221
Rep 2,339
