      05-22-2012, 06:27 AM   #1
GTex
Drives: 135I
Thermostat bad???
New guy here. 2008 135I with 44K miles. Car overheated last week when wife was sitting in driveway after driving home. I was out of town and did get a chance to look at it till Sunday night. After about 5 minutes of idling on the driveway, yellow high temp indicator came on. Shut down car and let it sit until Monday afternoon.
On Monday to check water pump, I did the air purge and can hear a series of "buzzes" I assume this is the washing machine sound described in other posts. So I think the water pump is working.
I also started the car for a few seconds and shut it down and heard what I think was the water pump continue to run for a few seconds. Bad hearing so I can't be positive.
After the pump purge, I had the local repair shop next door use his code scanner. Did not drive the car, he walked next door for me. No codes were found. He is not a BMW repair shop.
If in fact the sound I hear means the pump is ok, this would lead me to the thermostat. Is there a way to check this?
One other item of interest is that the cooling fan comes on in less than a minute and runs at high speed.
Any ideas? Should I just replace the thermostat?
      05-22-2012, 06:37 AM   #2
Focusedintntions
Drives: 2011 135i M-Sport :D
If you're under 50k call the dealer and take it in for service...should still be under warranty.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
      05-22-2012, 06:39 AM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
+1. bc a new waterpump and thermostat is over $1K!
Even IF your over 50K miles, I think the waterpump might be part of the powertrain warranty - and hence covered. On most cars the waterpump is considered part of the engine for powertrain stuff.
      05-22-2012, 06:56 AM   #4
GTex
Drives: 135I
I thought the waranty was over after 3 years?
      05-22-2012, 07:05 AM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
That is the free bmw maintenance warranty. The engine/trans (powertrain) is coverage for 4 years/50,000 miles. The HPFP is covered until 100K or 10 years(?). AND then there is the federal emissions warranty that is 8 years or 80K miles(I believe).
      05-22-2012, 08:23 AM   #6
GTex
Drives: 135I
Just talked to dealer, I have one month left on warranty. I will post what they discover. Thanks for the help.
