05-08-2012, 11:00 PM | #1 |
27
Rep 226
engine eating oil
Hi guys got the N55 at 5600 miles and it already ate a quart of oil and was giving me the low oil warning. Is this normal? doesnt seem so
05-08-2012, 11:04 PM | #2 |
480
Rep 4,154
Drives: 1/18 Monte Carlo Blue E92 M3
Yup. Had it happen to me as well. I think first at 7-8k miles or so. Then I did an oil change at 9-10k and had it come up again at 12k or so. So mine already ate 2 quarts or maybe I didn't fill it with enough oil when the change was done.
05-08-2012, 11:09 PM | #3 |
27
Rep 226
just a bit concerned with the low mileage and driving it with little oil in it. Can anyone confirm that the turbo is lubed from the engine oil or does it have its own supply.
05-09-2012, 09:08 AM | #4 |
or Rosencrantz
11
Rep 455
Drives: 2008 Montego Blue 128i
Sadly with a lot of cars (this included) the warning point is 1Q/1000 miles so your oil consumption is "normal" At 1 Qt low you are still good, but need to fill ASAP. The turbo does draw from the sump, but at a quart low there's still enough to do the job. Just don't dilly dally on putting more in. Why do you think they sell those nice Velcro backed oil bottle holders for your trunk.
Make a habit of checking your oil level once a week. |
05-09-2012, 09:34 AM | #5 | |
The Stig!
54
Rep 889
Drives: 2008 135i 6MT
2008 135i - FBO + JB4 15ohm + Water Meth
05-09-2012, 09:37 AM | #6 |
Resident Kerbalnaut
477
Rep 10,703
Mine has eaten 2 quarts in its 75K miles.
It ate 1 quart before its first oil change (I just assumed it was from break in) and the second one during my most recent oil change interval. So in other words unless it keeps up youre fine. |
05-10-2012, 03:33 PM | #7 |
34
Rep 770
Mine does not "eat" any oil in the 15k mile OCI that ive noticed.
Could be that your turbo seals are going bad or that you are burning it up from another engine related issue. 2 things I would do is first take an oil sample and send it out to Blackstone Laboratories. Go on their website and they will mail you a free kit. Take a sample when you change your oil and incluse 25 bucks. They will tell you EVERYTHING that is going on inside your motor and look out for any abnormal wear that may be going on. secondly, do a leak down test if the oil analysis comes back normal. if the leak down test also comes back normal un bolt the downpipe and look in the dowpipe before the converter to see if you can see any oil that is building up. Also look at the spark plugs for any signs of oil build up. If ALL of that comes back normal, then drive the car and dont worry about it. keep an extra qt of oil in the trunk and just monitor it. All of the above may be too much for the average person to care to do, but I wouldnt hesitate to do it if I were in you shoes. I would still do an oil analysis through blackstone. they are great people and have done numerous reports for me in the past and can literally pinpoint an issue, if there is one, before it becomes worse. You can look at a sample report on their website. I hope you find the cause of your issue and that it turns out to be just the car needing to be driven more. Keep us informed. |
06-12-2012, 04:18 PM | #9 |
41
Rep 1,177
Same here N54.. i change oil every 7K and i always notice that when i get close to 7K i see 0.75 QT is missing (according to the fancy onscreen dipstick)
Alpine White, Coral RED , Glacier Silver Aluminum trim, M sport, 6MT, NAV, HiFi, USB-iPod, Bluetooth
Performance: JB4|BMW PE|DP Cosmetics: BMW Sport Pedals|Black Kidney Grill |
07-30-2012, 11:18 AM | #11 |
968
Rep 3,323
Yes, but as a earlier poster said. According to BMW it is not excessive. My N54 has just started to eat oil at 50K. But, not enough to come close to having a warning light come on.
07-31-2012, 08:51 AM | #12 |
123
Rep 1,925
Drives: 2010 135i,1989 PRO3,2001 530i
tubro is lubed from engine oil
135i coupe 6MT TiAg ///M sport http://www.rhominnovations.com www.musicarNW.com www.unitedBMWonline.com |
08-13-2012, 06:33 AM | #14 |
368
Rep 3,547
Whenever you are low on oil, it is possible it got burned in the engine but the other possibility is a leak. I would look under the car too.
I do not have repair experience on a bimmer yet, fortunately, but on the other cars I have owned, oil burning occurs mainly because of valve stem seals. With a boosted motor, you have more pressure in the intake which may mean more pressure in the engine pushing oil harder at the seals. The shorter plug change interval for your motors would also be consistent with some oil consumption in the combustion chamber potentially fouling the spark plug (eventually). Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
06-10-2013, 09:07 AM | #15 | |
Rep 3
At the "granny" end
I'd heard rumour that a problem with the crank case ventilator can make this worse but have not been able to confirm or deny |
06-22-2013, 07:51 PM | #18 |
456
Rep 6,478
FML my turbos burn a quart of oil every like 1.5-2K miles stupid seals. It's like a get away smoke screen when the motor goes into vacuum coming to a stop. Once it heats up it's nowhere near as bad, but it still smokes.
Oh well STG2 turbos here we come
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
07-03-2013, 09:39 AM | #19 |
2394
Rep 6,083
Many new cars I've had over the years will burn a quart of oil at 3-5k miles, as the rings "seat" themselves, and then it stops. Prob not a problem. Be sure to use the appropriate weight synthetic oil, however - I buy the BMW oil from the dealer, as it tends to be the cheapest, strangely enough.
<OO (llll)(llll) OO>
07-20-2013, 11:11 PM | #20 |
170
Rep 955
was told when my engine was getting serviced that the oil filter housing area was leaking and that i needed to change gasket next time. but mine burns 1qt every oil change.
07-21-2013, 06:00 PM | #21 |
56
Rep 481
change your oil every 5,000 miles, and you will not get the warning >.>
2008 BMW 135i ///MSport Alpine White / Taupe Leatherette Cobb 2+ Aggressive | BMS Intake | ER Charge Pipe + Tial Q | ER FMIC | RR Downpipe | RR Exhaust | RR OCC | KWV1 | Apex ARC-8 245/18/40, 275/18/35 |
07-21-2013, 06:46 PM | #22 | |
27
Rep 226
