05-07-2012, 11:46 PM | #1 |
Riff Raff
32
Rep 368
Drives: 2014 8 spd bicycle
DCT: Transmission Mode "6"
I was watching some videos on the forums and confirmed a previous concern.
I have an 2011.5 e92. I had the 1,200 mile break-in service done, but the highest transmission mode that my M-Drive allows is still 5. Is there something that my servicing dealer missed? As I thought I understood, mode 6 is unlocked during the break in service, and is required to engage launch control. Thanks guys |
05-07-2012, 11:53 PM | #2 |
So Kewl Guy
49
Rep 619
Before anyone says it, read the manual.
For a quick answer, it can only be accessed when dsc is off.
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
05-07-2012, 11:56 PM | #3 |
59
Rep 1,250
05-08-2012, 12:43 AM | #5 |
471
Rep 2,991
2011.75 no longer allow DSC-Off to be set for M Drive. This means you can't access S6.
This sucks. You can, however, get it coded to remove that limitation... |
05-08-2012, 10:22 AM | #6 |
121
Rep 1,775
very true.
2014 M5 Comp Package.
05-08-2012, 10:44 AM | #7 |
259
Rep 949
I'm going to have to try this when I get in the car to confirm but my understanding is you cant slave it to the M button since you cant set DCS off but you can enter S6 manually.
05-08-2012, 11:23 AM | #8 |
471
Rep 2,991
05-08-2012, 01:22 PM | #11 |
21122
Rep 20,741
Drives: 2021 911 turbo
05-08-2012, 11:48 PM | #12 |
Riff Raff
32
Rep 368
Thanks for all the feedback guys. The whole DSC thing didn't even dawn on me. I probably had no intentions on using it (S6) anyways, just didn't want to feel that if my dealer missed one thing, they could have missed another..
All in all, probably a good reason why they disallowed it in '11.75 models anyways. Thanks again guys |
05-08-2012, 11:49 PM | #13 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Assuming one doesn't use launch control, how does using S6 increase wear on the transmission?
You have to be 100% behind someone before you can stab them in the back.
David Brent |
05-09-2012, 07:17 AM | #14 | |
59
Rep 1,250
Basically it shifts up without allowing the revs to drop 100% to match the next gear. So it feels like it "surges" forward when you shift. Personally I stick with S4 on track, still shifts very fast without bucking at all. S5 I've done before on track but the tiny decrease in shift time isn't worth the increased wear to me. |
05-09-2012, 07:52 AM | #15 | |
21122
Rep 20,741
I can see how it can be worse on a SMG. During a shift, the gears are loaded in the reverse direction while the clutch is disengaged and then they see a peak load back in the other direction when the clutch slams shut. The impact of this going back and forth on the gear backlash could start cracks in the gears and lead to low cycle fatigue. On a DCT, since the clutches slip against one another, the gears are always loaded in the same direction, minimizing the effect of backlash impact. The higher the shift mode, the more of the engine inertia from the RPM drop is recuperated to be converted in forward thrust, hence the surge. In theory, it should translate to more efficient shifts and better acceleration. I doubt that my limited driving abilities benefit from those hundreds of a second, however I do prefer the crispness and immediacy of the S6 shifts. Last edited by CanAutM3; 05-09-2012 at 08:54 AM.. |
05-09-2012, 09:49 AM | #16 |
259
Rep 949
It isn't just wear in the trans its the entire drive train that should be considered. There can be no question everything gets worked harder in higher S modes so the real question becomes does it make any significant difference to the lifespan of any of the effected parts? I don't have an answer but one thing that is telling to me is that they made S6 harder to access and that wasn't done without reason. If you start thinking about what that reason might be its hard not to put drive train issues or failure before the warranty expires at the top of the list.
Another thought is that it may not be the shifting level so much as driving style when at that level. It doesn't take long to figure out the aggressiveness of the shifting needs to match the way you are driving or else you end up with some rather unseemly clunkiness of the kind that you know isn't good. An example would be when stuck at low speed in traffic and you are shifting at low rpm and little load. I can get smooth shifts up to S4 in this condition but in S5 its hard to avoid the trans clunking into the next gear when I shift at times On the other hand I find S5 shifts fine with a hard but not clunky shift or bang when I'm driving in a more aggressive manner on the open road. You can pretty much figure there are people who bought these things and put it into the highest available settings in M drive and then keep the car in that mode even though they are not actually driving in a style that would be suited to the harder shifting. |
05-09-2012, 10:04 AM | #17 | |
247
Rep 640
Drives: G87 M2 [MT]
I'm speculating that in the case of S6 the harder shifts can increase the risk of lost traction which cannot be compensated by DSC, and could reduce overall performance and stability. I'm guessing this is why they allow access to S6 only with DSC off. |
05-09-2012, 10:08 AM | #18 |
11818
Rep 23,187
is there no longer a button the center console to turn off DSC?
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
05-09-2012, 10:27 AM | #19 | |
21122
Rep 20,741
Further, if you shift at low RPM with moderate throttle, you get pretty smooth shifts in S6. |
05-09-2012, 01:40 PM | #20 |
259
Rep 949
Yeah, that was what I was saying. The shift firmness needs to match the driving style or else you get into clunky land on the higher modes. Again my thought was that this kind of low rpm driving without adaquate throttle to get smooth(er) shifts is probably being done by some and could be the reason it was made unavailable to the M button rather than it being the shifts at higher rpms and loads where it actually shifts more smoothly. I don't know this, its just a thought.
As to DCS traction control by any name can engage pretty much whenever they do or don't want it in any amount on any car so there is no reason they could not have allowed some scratch on shifts or completely disable it momentarily with a kick in for yaw (potential loss of control) if it follows the scratch. It is strictly a programming choice and in no way a limitation of the system. I'm saying this also pointed at the post before yours BTW. For an example in a corvette you can do slides, burn outs, etc while in comp mode and still have traction control backing you up if things get too lurid. IMO there is little doubt about the ability of DCS to handle S6. It could have been incorporated into the MDM mode but was not and I believe this came down to a choice, not capability. |
05-09-2012, 02:15 PM | #21 | |
230
Rep 3,899
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold 2010 JZB E90 M3 DCT - Sold 2009 6MT E90 LCI 335i M -Sport - Sold |
05-09-2012, 03:55 PM | #22 |
You got my money?
3173
Rep 4,657
Drives: Ice Cream Truck
UM, My 2011.75 (12/2011) E92 M3 can program the M button to turn DCS off and put my DCT into S6? I do it everyday once its warmed up.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
