05-03-2012, 04:31 PM | #1 |
476
Rep 1,711
RB Rotors
As i promised i am going to talk about my impression of RB Rotors after the open track event at Thunderbolt NJ. On a picture above you can see a pic of one of them. I took a picture with my iPhone right after the last track session before i mounted street wheels. Second rotor looks exactly the same. As you can see, they look fine, no cracks of any size, but if you look carefully, you can see uneven deposits of the brake pad material. I use DTC70 pads for track days and i never had this problem with stock rotors and later with power slot rotors. I think i know why did it happen. This was an open track event which means you go on the track any time you want but it also means that when you think its time to pit, there is no way you can do cooldown laps, because other cars are going at full speed. I usually like to do a few cooldown laps but i couldnt do it this time, wich i think contributed to brake shudder due to uneven deposit of pad material. By the time i got home, the brake vibration was almost gone as DTC70 pad compound is more abrasive at lower temperatures and they cleaned up my rotors. This track is very technical with only one hard braking zone, which is at the end of the front straight. I was braking from 135 mph to about 65 lap after lap and i might have done more than 10 20 min sessions. So, RB Rotors worked for me for now, but the true test will come when i go to the WGI, wich is brutal on brakes and everything else. |
05-03-2012, 06:01 PM | #2 |
140
Rep 2,234
glad to hear they worked out. have your calipers turned yellow? takes a lot of heat to turn them yellow.
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
05-03-2012, 06:29 PM | #3 |
37
Rep 2,084
I guess time to cool down is the difference - unless Focused and I really did get a bad batch of rotors. At Summit Point I was braking from 135 to around 75 for turn 1, but I was also braking from around 95 to 45 going downhill for turn 5, so I don't think the rotors ever got a chance to cool down.
05-03-2012, 10:13 PM | #4 |
476
Rep 1,711
05-03-2012, 10:22 PM | #5 |
120
Rep 475
Drives: 2009 Crimson Red 135i
Have you checked your dust boots?
Mine looked like this: |
05-03-2012, 10:26 PM | #6 | |
476
Rep 1,711
Actually there are 3 more braking zones at thunderbolt, not as havy as discribed before, but still braking zones. Maybe you and Focused did get a bad batch of rotors. |
05-03-2012, 10:30 PM | #7 |
476
Rep 1,711
05-04-2012, 09:04 AM | #8 | |
18
Rep 254
cdv delete | clutch stop | bmw performance ssk | meisterschaft gt | berk mids | dinan cai | helix fmic | m3 subframe bushings, swaybar, front and back suspension bits | dinan stage 1 suspension | dinan cf strut brace |gc camber plates | dinan oil cooler | apex ec-7s w/PSSs | cobb stage 1 + fmic
05-04-2012, 09:29 AM | #9 |
37
Rep 2,084
05-04-2012, 10:04 AM | #10 |
105
Rep 2,696
My rotors looked like that after a single day at vir, summit is just really hard on the brakes is what I've come to learn. OP check very closely in the groves and holes in there fore spider cracking. Also mind posting pictures of your pads? Do you run any ducting?
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
05-04-2012, 10:53 AM | #11 | |
476
Rep 1,711
I will look closely when i have time, but i dont remove pads untill its time to change them. |
05-04-2012, 11:26 AM | #12 |
105
Rep 2,696
VIR has a couple hard stops, but there's plenty of time for the brakes too cool in between hard stops. I'm contemplating ordering another set of them to try out but I don't know.
05-04-2012, 01:59 PM | #13 |
476
Rep 1,711
Focused, dont order them yet. Let me try them at WGI first. If RB Rotors survive that track, then they can survive anything else. I am not sure when i am going there, but i will report back when i do.
05-28-2012, 03:01 PM | #14 |
476
Rep 1,711
Update. I went to Thunderbolt NJ yesterday with NASA, and tested my RB rotors again in 85 F weather. After beating on them in a very hot and humid weather, i am happy to report that these rotors look great, still no cracks at all, and i still have more than 60percent of DTC 70 front pads left after about 14 20 min sessions in two track days
I couldnt take any pics because my iPhone battery was dead. |
06-19-2012, 09:32 PM | #16 |
88
Rep 812
GP. I am re-reading old threads, and noticed that you mentioned you had Power Slot rotors before the RB ones. Did the Power Slot rotors you got have the curve vanes as advertised? Power Slot claims that curve vanes are only applied in some applications. Wondering if this includes the 135i rotors. Thanks.
Ground Control Camber Plates, Ferrodo D2500 w/ E86 MZ4 2 piece rotors, Dunlop Direzza ZII on Apex EC-7s
06-20-2012, 04:35 PM | #17 |
Freight Dawg
104
Rep 2,103
Ok I have a 325i with 135 brakes, RB Rotors, DTC70 pads. I got the spider cracking but it's just on the surface. It started at Laguna Seca which is extremely hard on brakes. I had been to Thunder Hill first which has some hard stops but after large stints of light braking so no cracking there. Not sure how much worse it will get. I'm just interested to see that some 135s aren't getting the cracks and you guys have WAY more power than me. I wonder if its as simple as just a bad batch.
I got the same hot spots on my rotor at first but they just went away eventually. Aside from the cracks the rotor surface looks good.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
06-20-2012, 05:02 PM | #18 | |
140
Rep 2,234
06-20-2012, 05:14 PM | #19 |
Freight Dawg
104
Rep 2,103
lol! What I was trying to say is that the wear and color are even. No big grooves hots spots or deposits. Just need to figure out how to stop it from cracking.
--Marcelo
06-21-2012, 09:50 AM | #20 | |
476
Rep 1,711
