BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
EXXEL Distributions
      04-27-2012, 11:06 AM   #1
PetrolFumes
351
Drives: Raptor, GT3RS,E92 M3,X5M50i
09 AW E92 - Oil issues
Guys,
just joined the M family earlier this week with an 09 AW E92 CPO with 46K miles. Car looks new cosmetically and rides like new.
you really appreciate that engine once you push it a little.
Anyway - i had the dealer I bought it from do all the service and top off the oil which was low when it first came back off lease from the ogirinal owner an di put about 150 miles on it since. The oil level was back to low yesterday and the dealer told me this is normal to add 1 -2 quarts every three months espcially in the heat. Does anyone else have this issue or should i bring it in to get checked?
Here she is below before picking her up at the dealer:
      04-27-2012, 11:13 AM   #2
m3an
m3an's Avatar
39
Drives: M3
yes my car uses oil like gasoline; approx 1 qt every 1200-1500 miles. I think using oil is fine; but my car seems a little much, but per BMW 1 qt every 900 miles is the threshold (which IMO is crazy)
      04-27-2012, 11:15 AM   #3
Nine
49
Drives: Not ZCP, FML.
Did you check the dipstick...fml.
Sounds excessive, never hurts to take it in, get it documented...
      04-27-2012, 11:16 AM   #4
m3an
m3an's Avatar
39
Drives: M3
no dipstick makes me want to get rid of the car, seriously. just that alone!
      04-27-2012, 11:31 AM   #5
socalm3lover
19
Drives: E92 M3
I have owned a '95, '03 and '08 versions. The 95 and 03 did not burn any oil, but the 08 burns some, (5,000+ or so). I do have a problem with the oil level sensor and plan on replacing it at the next oil change. I doubt that your car burns a quart within 150 miles or so with no indications, smoke, leaks, etc.
I had an advantage of driving 50K plus miles and establishing a history so that when I started getting low levels and eratic readings, we are sure the sensor is bad.
Regardless, congratulations on a terrific car and good luck with this issue.
John
      04-27-2012, 11:54 AM   #6
PetrolFumes
351
thank you. very good info.. its that damn beast of an engine.. its always thirsty.. i guess ill have to deal with it
John
      04-27-2012, 12:06 PM   #7
nbennettksu
1397
Drives: DV F80
In e46 or e90?
edit: I see your no dipstick post, question answered
Originally Posted by JBasham View Post
Caddy ATS . . . finally, a decent rental car option.
Originally Posted by kchu221 View Post
the wheels make me mad...
Originally Posted by mhabs View Post
It's one thing for some buffoon to put an M badge on something that doesn't deserve it...it's another for a multi-billion dollar corporation to do the exact same thing and keep a straight face.
      04-27-2012, 12:19 PM   #8
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
John
Since 95 and 03 were not the same engine as the OP, they are not really relevant.
OP, how much did they actually put in when you took it to the dealer?
1/2-1qt every few thousand miles is normal.
      04-27-2012, 03:09 PM   #9
PetrolFumes
351
according to my engine it's 1 quart every 150 miles !
      04-27-2012, 03:13 PM   #10
gallian93
gallian93's Avatar
Drives: 18 M3 cs/72 tii
+1
i kept track of mileage for the first few quart then figured "screw it" ... and just always have two quarts at home
PS...driving habits play a role too...
[/B]2018 BMW M3 CS (SMB) (Daily Driver)1991 E30 w S52 swap(New addition)[/B]1972 BMW 2002tii (ITS ALIVE)2013 X5M (Wife's DD) ,2009 AUDI A4 3.2 (Winter/Aupair) 2010 e90 M3 (Sold 2020),2011 X5 5.0i (Traded 2019),2007 335 IX(sold 2018),2008 Z4 MC (sold 2017 Still sad about it), 2011 X6M (sold 2015)2008 E93 M3 (Traded 2013), 2005 e46 M3(solidified affair)(wrecked 2010), 2002 330Ci (started love affair)(Sold 2009)
      04-27-2012, 03:14 PM   #11
THE TECH
THE TECH's Avatar
307
Better have the engine checked out then. Did you check any of the service records on this car before buying?
      04-27-2012, 03:31 PM   #12
PetrolFumes
351
yes oil changes were done every 15K
one at 15,267
one at 31,XXX
car now has 46,xxx miles
i havent been driving hard either.. i scheduled it to be looked at on Monday
      04-27-2012, 04:12 PM   #13
shendrick
Drives: 08 e90 M3, 05 e46 zhp, 07 X3
1Q every 1-2K miles is crazy. You really need to do some record keeping and keep a close eye on this. I did a very slow break in (more than what BMW says) and after 23K miles I burn 1L every 7,500 miles.
      04-27-2012, 04:21 PM   #14
THE TECH
THE TECH's Avatar
307
one at 15,267
one at 31,XXX
Actually I meant did you see if it had been in service for any sorts of issues.
      04-27-2012, 04:48 PM   #15
PetrolFumes
351
no oil issues at all.. just DCT lever malfunction
      04-27-2012, 04:49 PM   #16
PetrolFumes
351
i wouldnt think the oil burning would have anything to do with how you break it in???
      04-27-2012, 05:52 PM   #17
socalm3lover
19
Drives: E92 M3
Other than the numerous threads/comments about M3s burning oil.
John
      04-27-2012, 06:11 PM   #18
von_zoom
von_zoom's Avatar
30
Drives: 2010 Z06
My 09 E92 does not use oil. I am tracking it now, so this may change, but for normal street driving, no oil issue(s) at all
vz
Previous Track Toy
      04-28-2012, 12:00 AM   #19
Adriansideways
Drives: 2008 E90 M3
Depends on first 2000miles of running in when your rings seat = amount of oil used...unless there is a meck failure somewhere
      04-29-2012, 08:51 AM   #20
PetrolFumes
351
Turns out she checked out all good! BMW ran a diagnostics test on the engine as well and she's firing like she should be
      05-04-2012, 08:04 PM   #21
lookitsma
8
Drives: BMW M3 E92 Melbourne Red
Depending on how well you broke in the car seems to determine the level of oil that gets burned off it seems. This is speculation of course but I did start noticing a pattern.
I had my oil changed 2,000 miles ago. Since then it has not once dropped a single dot on my idrive sensor or on the dashboard. It is still right on the full line. I have never needed to add oil between my 7500 mile change. But I strictly followed the break-in procedure the first 1500 miles or so.
      05-05-2012, 07:08 AM   #22
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
I've never had to add oil. Changed the oil at 1200, 8000, 15000 miles. I did take the engine a bit over 5500rpms during breakin...I was on the autobahn. Couldn't help it.
I think if you are NOT taking the car to redline frequently then you will burn oil. Because there are very few trips where I don't spin it it to 8k.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
m3post
