04-21-2012, 08:07 AM | #1 |
2002
Rep 6,916
Can this or will this end the clay bar?
NANOSKIN Autoscrub 6 inch Pad - Better and Faster than Claying
Wow is all I can say about this new tool and new technology. I believe this will change the way most pro detailers and DIYers will prep their cars. This is truly a time saver and will pay for itself after a couple detail jobs. We have spent in some cases 1-2 hours claying and prepping a midsize sedan (in rough shape) we recently tested the AutoScrub on an Audi S8 and we were finished in about 15 minutes! You really won't believe this until you try it yourself. The AutoScrub will make you leave your clay bar behind. NANOSKIN AutoScrub works fast and achieves professional results with the new advanced rubber polymer technology, which replaces the use of clay bars. A dual action orbital polisher is required. AutoScrub will safely and easily removes paint over spray, water spots, tree sap, rail dust and other bonded surface contaminants from the surface of automotive paint, glass, moldings and plastic. AutoScrub works great with your favorite detail spray or clay lubricant. Unlike the clay bar, the AutoScrub can be cleaned by simply rinsing off the accumulated contaminates with water. If you drop the AutoScrub on the ground, no worries, just rinse the sponge pad clean and you're ready to keep using it. AutoScrub allows for sturdy and controlled handling, unlike clay bars where constant reshaping is required. Features - Lasts up to 4 times longer than clay bars - Glides on & off easily for a slick finish - If inadvertently dropped on shop floor, simply rinse clean - Up to 50-60 uses before you need to replace it Directions 1. Thoroughly wash vehicle free of dust, sand, and dirt. 2. Mist sufficient detail spray or clay lubricant onto the surface evenly. 3. Polish the surface with dual action orbital polisher using light pressure (Low Speed). 4. Wipe off residue and move on to compound and polishing or even go straight to your last step. Important tips: - Sufficient lubrication is crucial to the AUTOSCRUB application. - DO NOT use water - DO NOT use with rotary polisher. Take a look at the 3 offers we have. Pre Order Pricing is in effect, we should have the first wave by Friday. NanoSkin AutoScrub 3 inch Kit NanoSkin AutoScrub 6 inch Kit Nano Skin AutoScrub 6 Inch Pad Various photos of how the pad looks and works 3 inch pad kit 6 inch pad on the Griots on an Uber 5 inch backing plate |
04-23-2012, 08:55 AM | #10 |
2002
Rep 6,916
yes you can do this with PC or Griots Machine.
you can spray the detail spray on it to clean it off it needed. do it as many times as you feel comfortable with it. just make sure the panels are lubed well. |
04-23-2012, 04:05 PM | #11 |
bimmerphile, technogeek
998
Rep 3,785
Drives: 2012 E82 6MT Sport
The text in the first post says "A dual action orbital polisher is required," but then there's a pic showing hand application using the 3-inch pad..... ?
04-23-2012, 04:09 PM | #12 |
The Stig!
54
Rep 889
Drives: 2008 135i 6MT
Very Interesting! I may have to order this!
2008 135i - FBO + JB4 15ohm + Water Meth
04-23-2012, 07:25 PM | #13 |
2002
Rep 6,916
yes you can use the 3inch pad on a orbital polisher or with this hand applicator
https://detailersdomain.com/NanoSkin...Kit_p_696.html |
04-27-2012, 06:56 AM | #14 |
HUSTLE.... HARD!
27
Rep 340
Thanks Phil, mine arrived yesterday. I will use it this weekend and let you know what I think.
CURRENT: 2012 535I
RETIRED : 2011 135I RETIRED : 2003 540I RIP : 2003 M3 |
04-27-2012, 07:35 AM | #15 |
44
Rep 1,003
Ordered one the other day and can't wait to give it a go!
"The Camaro's V6 makes so much horsepower because them horses are trying as hard as they can to run the fuck away from that ugly ass car." -Golden3ye
04-27-2012, 08:04 AM | #16 |
A Zip an a Double Cup
80
Rep 4,462
Looks cool, I'll have to give it a try
PTF Tuned | RB's | AMS FMIC | AR DP's | HPF Exhaust | CP-E DCI | Apex Arc 8's | 235/275 Star Specs | |
