      04-20-2012, 09:40 AM   #1
TZANIDO777
73
Drives: 2011 E82 135i, 2015 F15 X5 35D
2020 BMW X5 40i  [0.00]
2011 BMW 135i  [0.00]
Help with p3 boost gauge
Okay so I got the p3 boost gauge, everything is good and I have no problems with the install. I am just trying to figure out whether or not I can use the green wire for the auto dimmer to tap my map sensor in order to get accurate boost reading.
I have a Jb4, N55 engine, and I received the most enhanced version of the boost gauge, so everything is easy plug and play...thanks to Rick ...so my question is, does it matter which wire I use on the harness? As long as I use one of them to tap the map sensor on the Jb4, or do I have to use the blue one to tap the map sensor? Because the blue wire is too short to reach into the engine bay and the green wire looks long enough to reach.
Thanks in advance for any help.
      04-20-2012, 10:01 PM   #2
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
If you want to read boost from the map sensor with jb4 tune and use the A.n55 mode you need to run a wire to the blue wire on the gauge... green is only for dimmer line.
You'll need to get a wire tap and some wire and a quick disconnect from radio shack. We plan to have a more plug and play option for that soon since there are quite a few people that use the gauge on n55 with a piggyback.
If you need more details feel free to hit me up at rick@p3cars.com
-Rick
      04-21-2012, 08:11 AM   #3
TZANIDO777
73
Thank you Rick, appreciate it.
      04-22-2012, 11:02 AM   #4
cmuro
Drives: 2012 BMW 135i
Sorry to hijack but i ordered one almost three weeks ago and received nothing. How long did it take to get yours from the time you ordered it?
      04-23-2012, 09:40 PM   #5
TZANIDO777
73
No problem, I was part of a groupbuy so it took a little bit longer than it should, really dont remember how long to be honest, must have been maybe a month and a half if I remember correctly.......but the guys over at p3cars are good guys so send them an email and im sure someone will take care of you
      04-28-2012, 09:18 AM   #6
Everfly
Everfly's Avatar
154
Drives: BMW
Just installed my p3 as well, just wonder what did you do with a bunch of extra wires and did you use the cap on the module where boost line go too. Also will install my Jb4 next week so i am interest how it turn out for you. Thanks
And another question is what is the vacuum reading sitting at?
      04-28-2012, 09:55 AM   #7
TZANIDO777
73
I received the enhanced version, so I only had to plug in the one wire into the obd port and that was it. Mine came with one additional green wire, blue wire and brown wire, which the green one is for the dimmer line, blue and brown is for anything else you might want to tap. In my case I needed to use the blue wire to tap the map sensor on the jb4, which is the brown wire, second sensor from the right. The only thing is, is that I have yet to make it work properly because i need to input the correct voltage or something like that for the sensor that I am tapping, into the boost gauge in the configuration menu to get the correct reading for boost and vacuum, so can not give you an answer for the last question yet, sorry.
      04-28-2012, 10:42 AM   #8
Everfly
Everfly's Avatar
154
Drives: BMW
Thanks
I have the same versions. I meant 3 extra wires blue green brown, i dont need dimmer. So i firgure the blue to tap the sensor for the JB4, my JB4 will be here next wed. Do you mind to share when you sort thing out. I doing exact set up like ur now
      04-28-2012, 03:26 PM   #9
TZANIDO777
73
Thanks
Sure no problem, I just need to find some time to contact Rick and ask about the configuration numbers for that specific sensor. If you have time and would like to ask him yourself, his email address is further up on this thread when he responded to me in the second post.
If not then no worries, Ill get it done by the end of the week.
      04-28-2012, 03:36 PM   #10
Everfly
Everfly's Avatar
154
Drives: BMW
Cool
I didn't want to ask the same question been asked by you. I appreciate that though
      04-28-2012, 03:58 PM   #11
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
BMW is on a 2-4 week delay for parts. If you are at 3 weeks it will be shipping this week.
-Rick
      04-28-2012, 04:00 PM   #12
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
Newest version has an A.n55 option for analog map sensor tap that takes care of all the settings for you, use the blue wire on the gauge for map sensor tap.
-Rick
      04-28-2012, 04:06 PM   #13
Everfly
Everfly's Avatar
154
Drives: BMW
-Rick
Op, do you know which wire is for the map sensor?
      04-29-2012, 12:20 AM   #14
TZANIDO777
73
I believe Rick just cleared that problem up for us, thank you Rick .
And you use the blue wire from the boost gauge to tap the brown wire on the Jb4 harness, which is the second sensor from the right........http://support.p3cars.com/attachment...me=harness.jpg here is a link to a picture of the wire you need to tap in order to get the correct reading for boost .
      04-29-2012, 12:34 AM   #15
Everfly
Everfly's Avatar
154
Drives: BMW
Cool. Cant wait
