04-18-2012, 08:25 AM | #1 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
How Necessary are Rear Camber Arms for Mild Drop?
I really don't want to get rear camber arms unless truly necessary seeing how they are a major PITA to install. I just wonder though will I really have that much excessive negative camber in the rears if I drop 1" or so? Assuming I go 1" lower, should I not be able to adjust it back using the stock arms?
04-18-2012, 08:35 AM | #2 |
Not a New Member
94
Rep 925
Drives: with both hands and both feet
the eibachs i had lowered the 3.0si about .75" in the rear... i was able to max the stock alignment and have whatever toe setting i wanted. while it is possible that going down an inch from stock would limit the same freedom of alignment choices, i don't think you'll have an issue with the stock arms.
#1498E86 | Sepang Bronze | Dark Sepang Leather | Carbon Leather Trim
04-18-2012, 08:48 AM | #3 | |
2286
Rep 12,565
04-18-2012, 09:22 AM | #4 |
Not a New Member
94
Rep 925
i can't recall. it's here in the forum somewhere... i'll start searching for it.
04-18-2012, 09:39 AM | #5 | |
Not a New Member
94
Rep 925
found it!
04-18-2012, 11:20 AM | #6 | |
CarbonFiber Engineer @ ZeroMassMotorsports
40
Rep 1,481
04-18-2012, 12:07 PM | #7 |
Not a New Member
94
Rep 925
yessir... from ZSP susp to the eibachs. the pro kit was much less "crashy" than the stock springs, but i don't have an accurate compairison because i switched from 225/40r18 frt and 255/35r18 rear RFT's, to 235/40r18 frt and 265/35r18 rear non-RFT's at the same time the springs went on. so basically, softer and taller tires, which was most likely the biggest improvement in ride. if i had to do it again, i'd go to -1.7ish for front camber on the same wheel, tire, and spring setup to combat the very minor front liner rubbing that seams to plague the non-///m cars.
04-18-2012, 03:18 PM | #8 | |
40
Rep 1,481
