New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      04-17-2012, 09:41 PM   #1
Mayhem
22
Drives: 2012 Z4 sDrive35is
Z4 fusebox access... well that was no fun..
So the fusebox on the 2012 Z4 is under the glovebox. Remove three screws, pull off the panel to access. No problem. Only, the phillips screws defy unscrewing with several screwdrivers I try... the slot angle is just odd. But ok, once it's off, I look for the fusebox and find that it is tucked up high in the dash. I figure out you have to turn a retaining screw and then you can pull it down. Only, the wiring harness is somewhat short and you have to work on your hands and knees crouched in the passenger well. Ok, so I do all that. Just put it back together right? Nooooooooo.... it takes me an hour to line up the retaining screw with the hole so I can secure it again.
Next time, I am just going to take it to the shop and let them deal with it.
Ugh... a five minute job turned into an hour and a half.
      04-18-2012, 05:55 AM   #2
jparnes1
jparnes1's Avatar
245
Drives: 2016 340i, 2012 Z4 35i
Brand new car, bad fuse?
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      04-18-2012, 06:58 AM   #3
Andrew*Debbie
Drives: Z4 sDrive20i
Could it be that the screws are Pozidriv and not phillips? I'm seeing more and more Pozidriv screws turn up.
Pozidriv screws should have little marks between the slots
Like these. . .
http://en.wikipedia.org/wiki/File:Sc...v_IMGP0880.jpg
      04-18-2012, 01:15 PM   #4
Mayhem
22
I was having an odd issue with my Navigation and wondered if it might be related to a fuse. Yesterday, my nav window closed on me twice while driving.
I pulled the related fuses, checked them, and put everything back together. It has not happened since. I was thinking maybe a fuse had burned out, but maybe it just wasn't seated all the way down.
Anyways, if you ever think you might change a fuse by the side of the road, think long and hard.
      04-18-2012, 07:41 PM   #5
baldguyj
baldguyj's Avatar
Drives: 2010 Z4 e89 35i Sdrive
Yep I was too big to tie my Radar Detector that way, went another route.
      04-20-2012, 03:06 AM   #6
flpnout
flpnout's Avatar
Drives: 2010 Dinan S3 Z4-35i
2010 E89 Z4  [7.83]
Haha. I've fiddled there too once. Easy to remove, but a pain to put back.
2015 BMW i3 REX
      07-26-2014, 03:07 PM   #7
Hujan
Hujan's Avatar
Drives: M3
Any one have a fuse map for the E89? The A/C in our car stopped working all of sudden and I want to try to replace the fuse before we take it in.
      07-26-2014, 03:55 PM   #8
Bob20124
Retired and Enjoying it
Bob20124's Avatar
Drives: 2011 Z4 35i Alpine White 6MT
found this a while ago. Hope it helps
2011 35i BMS High & Low side OCC, Custom tune, CDV delete, Eldor coils, ER Charge Pipe w/Tial BOV, ER Comp. FMIC, K&N drop in,40W LED Halo, LCI side markers, M-Factory LSD, NGK plugs, Racing Dynamics strut brace, Stubby, Windrestrictor
      07-26-2014, 06:26 PM   #9
Lurcher
Lurcher's Avatar
Drives: 2012 z4
3 fuses associated with this (known issue). My AC started working again after I popped out all 3 and reset them.
Good luck
      07-30-2014, 09:29 AM   #10
COOLZ4
Secret Agent
Drives: 2011 sdrive35is
It's seems like the simple jobs end up giving us the most trouble. I'm glad my 35is doesn't have the navigation system. One less thing to screw up.
      07-30-2014, 05:26 PM   #11
Hujan
Hujan's Avatar
Drives: M3
Thank you, Bob! You're a gentleman and a scholar!
Good luck
Thanks. Glad to know there's some precedent for the fuses being the fix. Fingers crossed!
      10-16-2015, 02:53 AM   #12
uluwatu06
22
Drives: 2021 F44 BMW M235i xDrive
Managed to bring down the fuse box by twisting the shiny fastener.
zpost
