BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
Mporium BMW
      04-15-2012, 07:03 AM   #1
quads
70
Drives: bac mono
APR GTC-300 wing and Splitter on E90 M3 :)
Don't worry I used a spare trunk All of this is removable without a trace. I'm prepping for One lap of america. After which they'll all come off for daily driving!
      04-15-2012, 07:05 AM   #2
Eugene-TAIWAN
Eugene-TAIWAN's Avatar
Taiwan
249
Drives: E92 M3 Coupe
Lots of downforce for sure
Past: Gintani stage3 M3, Cayman GTS
present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW
      04-15-2012, 07:35 AM   #3
NFAM3
Drives: 2011 M3
Thank God!
2011 BMW M3
      04-15-2012, 07:40 AM   #4
warp10
warp10's Avatar
776
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
2011 M3  [10.00]
2011 28i X3  [0.00]
I know that gas station! See you up at AMP next weekend.
      04-15-2012, 07:42 AM   #5
quads
70
Drives: bac mono
Congrats on membership! Are you sure it's the weekend or perhaps this week? I need to balance the downforce at speed. It's too dangerous on the street
      04-15-2012, 06:51 PM   #6
DjZotic
DjZotic's Avatar
12
Drives: none
u animal !
      04-15-2012, 08:04 PM   #7
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
Looks great. Hard to tell from the pics, but if there is a gap between the splitter and the lower front bumper you should seal that to allow the splitter to do it's job properly. I would expect a lot of high speed understeer otherwise because the GTC300 provides quite a bit of downforce.
      04-15-2012, 08:19 PM   #8
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
I heard friday and Saturday
      04-15-2012, 08:19 PM   #9
quads
70
Drives: bac mono
You are absolutely correct sir! I need to plug those two holes - any suggestions welcome.
The idea is maximize the effect of the splitter and then work my way up with the wing until balance is achieved
      04-15-2012, 08:28 PM   #10
Porschefile
59
Drives: E92 M3
Exactly. I had a similar issue on my E36 racecar, way more wing than my splitter could handle.
I don't know how much you care about being able to put it back to stock looks, but I would just put gorilla tape over the front there as a temporary solution. The problem is you need the front to be flush or close to it-airflow is a fickle thing.
I'd also look in to dive planes, I'm sure someone makes some for these cars.
      04-15-2012, 08:31 PM   #11
tightie
JOSH SHOKRI.
tightie's Avatar
Drives: 991 GT3RS, 964, Raptor
2008 BMW M3  [7.90]
+1
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict
      04-15-2012, 08:38 PM   #12
quads
70
Drives: bac mono
I'll just use gorilla tape to close it up then. (goo gone cleans up residue easily)
Maybe I'll get something firm to back it up so it's flush.
I'm not sure I'm ready to add dive planes or canards yet - that involves some bumper drilling and bracing... I've got a few more weeks so I'll think about it.
What about gurney flaps? I know it's for trailing edge - but what if I put it on the leading edge? hmmm...
Yeah I'm not even getting close to the potential of the wing. It's set at the lowest angle right now (1.4 degrees) and according to specs it's delivering close to the zero degree 150lbs of downforce, 17lbs of drag at 80mph.
I've got to get more frontal downforce
Last edited by quads; 04-15-2012 at 08:40 PM.. Reason: edit - not canards - I meant gurney flaps
      04-15-2012, 08:50 PM   #13
Porschefile
59
Drives: E92 M3
Gurney flaps are for the rear wing, and don't work on APR style wings anyway. They basically just clean up the airflow and increase the wing's downforce, but I don't think it'd work up front. Definitely tape up those holes though.
That amount of downforce will be noticeable but not crazy, but at 120mph it should produce 400+ pounds and that will really plant the car. Even an enormous front splitter probably won't make as much as your wing will make, my goal was always just to get close(r). Good luck in the one lap, I've always wanted to run that.
      04-15-2012, 09:06 PM   #14
quads
70
Drives: bac mono
thanks!
Here's the specific data on the wing
http://www.aprperformance.com/index....sk=view&id=181
at 120mph theres 345lb of force and 39lb of drag
      04-15-2012, 09:28 PM   #15
creaminz
creaminz's Avatar
Drives: E90 LCI
Reminds of turb0mike's track e90 335i
      04-16-2012, 03:07 AM   #16
Eugene-TAIWAN
Taiwan
249
thanks!
I wonder how much top speed that will kill
      04-16-2012, 03:44 AM   #17
jonasaurus
jonasaurus's Avatar
United Kingdom
76
Drives: E90 M3 [Sold]
Bad ass wing and splitter. Look forward to hearing how they perform for you in one lap.
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
      04-16-2012, 04:56 AM   #18
quads
70
Drives: bac mono
I'm sure it will kill some of it. With an acceleration of 60-130 in 6.1s which gets me to 130 in less than 10 at tracks with longer straights I'm lifting to avoid going too fast because the car becomes unstable with the aero.
Recently at VIR I hit 160 at the end of the back straight. Huge pucker factor.
With aero it should be me a little more confidence at those speeds as well as help with high speed sweeping turns - helps keep the sticky side down
      04-16-2012, 07:30 AM   #19
Porschefile
59
Drives: E92 M3
Not a whole lot actually. The wing I had was rated for similar downforce and drag (slightly less drag and slightly less downforce), and cost me only 1-2 mph at most tracks peak speed. You come out of the corner faster coming on the straight typically because of the extra grip, and that amount of drag is not very much. A wing like that is good for 2 seconds a lap at VIR once you get used to it.
A E36 LTW wing, on the other hand, is an anchor.
      04-16-2012, 07:31 AM   #20
Porschefile
59
Drives: E92 M3
That's awesome, I only did 150 in mine and 160 in a GT-R, what power mods do you have?
      04-16-2012, 09:02 AM   #21
quads
70
Drives: bac mono
I have the ESS vt2-625 and Akra evo exhaust. HP is just at 650 crank, dynoing at 560whp. It's kind of scary "floating" at 160mph without aero!
I may go to VIR again for UTCC.
The APR wing is actually extremely lightweight since it's all CF.
      04-16-2012, 09:45 AM   #22
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
how much did this set you back?
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
m3post
