04-03-2012, 05:46 PM | #1 |
111
Rep 919
Drives: BMWs
Garage List 2008 E60 M5 6MT [0.00]
2019 G01 X3 sDrive30i [0.00] 2007 E86 M Coupe [0.00] 1997 E36 M3 [10.00] 2006 E53 X5 4.8is ( ... [0.00] 2006 E85 M Roadster ... [0.00] 2002 DINAN 5 (sold) [0.00] 2013 E89 Z4 sDrive3 ... [7.00] 2011 E92 M3 (sold) [0.00] 2001 E46 M3 (sold) [0.00] 2007 R56 Cooper S ( ... [0.00] 2002 996TT (sold) [10.00] 2009 E82 135i (sold) [9.00] 2006 E85 Z4 M (sold) [6.00] 2007 B7 A4 2.0T (re ... [0.00] 2003 E46 M3 (sold) [0.00] 2002 E46 325Ci (sold) [0.00] |
Which swaybar for 135i?
Which sway bars do you guys recommend? I've read H&R, E9X M3, Hotchkis. What else is there? Should I go a complete set (front/rear) or front only or rear only?
TIA |
04-04-2012, 08:34 AM | #2 |
31
Rep 409
Drives: 2008 Montego Blue 135i
It depends on what suspension you want to go with. Most go for the M3 bar and you don't need a rear bar unless you are putting an LSD.
I got the Eibach front sway, so I will probably get same for suspension when decide to switch.
There are no impossible deeds, only incapable men.
Eibach frontsway,BMS JB4,AFE Drop InBerk Street Axleback, H&R SPORT SPRINGS,Active Autowerke DP's ,Active Autowerke BOV,Active Autowerke FMIC , BMWPEDALS.COM, JB SPEED Black Grills,Alpina B3 TCU Flash |
04-04-2012, 05:18 PM | #3 |
Rep 218
I just installed a 3M front sway a couple weeks ago. So far I like it a lot.
08 135i |Alpine White w/ Terra Boston Leather|Sport Pkg| Premium Pkg| Shadowline| Gloss Black Trim| Nav| Comfort Access| Active Steering| Steptronic| Htd Seats| Prem. Sound/Sirius| Park Distance| PPK 1|BMS 4LED|M3 Sway Bar
04-05-2012, 07:07 AM | #4 |
2452
Rep 7,341
I did the M3 vert swaybar and like it. The most amazing thing is the quality of the parts used on the M3 vs the 135i. M3 pieces look like they're ready for war while ours look like flimsy Chinese-made imitations.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
04-05-2012, 07:50 AM | #5 |
Former Opel GT Pilot
327
Rep 771
I have been wondering about this too. However, for me the desired result is flatter cornering without a harsher ride. Because the M3 sways are so heavy, would they create the much stiffer ride that I am trying to avoid?
All informed opinions welcome.
So, that's it. I am doomed. There is no patch, no methadone, no substitute. Curse you BMW. Curse you and your seamless power delivery. Curse the incredible sense of road feel. Curse the comfort, the luxury, the envious looks from the masses. I am... hopelessly addicted.
04-05-2012, 07:58 AM | #6 |
2452
Rep 7,341
Swaybars do NOT change the ride quality of the car - they simply reduce the roll in corners. You would never be able to describe a car with stiff or heavy swaybars as having a harsher ride.
04-05-2012, 11:15 AM | #7 |
606
Rep 873
This is incorrect. By going with a thicker, bigger sway bar you will feel more of the road bumps as the suspension on each side is not permitted to flex as much independently.
04-05-2012, 11:34 AM | #8 |
116
Rep 1,158
So you're saying sway bars limit the amount of flex/roll in the body when you're turning AND make your suspension not rebound as much? Huh, I'd like to see where you found this information at.
04-05-2012, 11:39 AM | #9 |
Rep 93
I've installed the front H&R bar and love it. It's solid without the middle crimp. The stock bar was indeed a joke. I tossed it in a scrap metal recycling bin. lol
I did not notice any extra harshness in ride quality after the change, just the incredible flatness in the turns. |
04-05-2012, 12:39 PM | #10 |
736
Rep 3,274
The only way I could ever see a sway bar affecting ride quality in the way explained above is MAYBE if you hit a bump with only the passenger side wheels and as a result of the stiffer swaybar linking between the driver and passenger side, the driver feels the bump more than normal. But I don't see this as really being an issue, even if it works that way (which I am honestly not sure about, I'm not that well-versed in this area). It reduces roll by reducing flex, but I don't think that flex reduction really influences the transmission of road shocks from one corner to the other. You hit a road imperfection with your passenger side tire, it extends/compresses then rebounds. It doesn't transmit to the other side... (at least I don't think so. It doesn't make sense to me that it would.. correct me if I'm wrong).
The weight difference between the M3 sway and the 135i sway is negligible because they are both hollow, and even though the M3 one is indeed thicker, since it's hollow you're not really adding much mass to the bar. But even if it wasn't, it really wouldn't matter. The H&R bar is indeed solid and not hollow, and even that one has no detrimental effects to handling. The only negative effect I can even forsee is if the front is much more stiff than the rear, this can increase understeer. For fixing this, I really like this web page: http://www.nyracer.com/overunder.htm
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
04-05-2012, 12:56 PM | #11 | |
89
Rep 257
Drives: 2013 128 Coupe 6MT
SOLD: 2013 128 Coupe / 6MT / Premium / M-Sport / Cold / Xenon / HK Audio / CDV Delete / M3 RSFB
SOLD: 2009 128 Coupe / 6MT / Premium / Sport / Cold / Xenon / HK Audio / CDV Delete / M3 Suspension |
04-05-2012, 01:40 PM | #12 |
2449
Rep 3,575
Fatter bars *will* change the ride in certain situations, as mentioned.
If you live in Florida and your roads are dead flat, you won't feel a difference. If you live in MN and the roads are full of holes, bumps from patches, and all kinds of other crap then you most definitely will notice. You're right that you feel it only if you hit a bump with one side and not the other. The thing is, for some people, you just described what sometimes seems like every square inch of road surface! Obviously it's not that bad here, but it is noticeable. I'd agree however it's more than worth the trade-off and not really worth worrying about. Anti-roll bars don't affect body flex, not sure where you read that. He didn't say it. He said each side can't react as independently as it did before a thicker bar was installed and that is correct. The bar ties the sides together, a thicker one makes a stronger tie between the two. When one side wants to move up or down, it tries to take the other side with it. If you understand suspensions there's not much confusion here. |
04-05-2012, 03:09 PM | #13 | |
18
Rep 260
Drives: 2011 BMW 135i Coupé
2011 135i Black Sapphire Metallic / Coral Red
04-11-2012, 05:23 PM | #15 |
2449
Rep 3,575
04-11-2012, 06:38 PM | #16 |
44
Rep 1,265
I have the E93 FWB and debated on putting on the rear while doing my subframe bushings. I decided against it. I have HP Autowerks Koni coilover kit with swift springs, M3 front control arms and Dinan camber plates. And yes, I do have an LSD. Autox'ed the car this past weekend and it felt great!
04-14-2012, 11:17 AM | #17 |
4207
Rep 5,728
Drives: 2019 M2 Competition
04-14-2012, 12:03 PM | #18 | |
164
Rep 2,556
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
04-17-2012, 07:19 PM | #19 | |
Rep 26
http://www.1addicts.com/forums/showthread.php?t=677455 |
04-20-2012, 10:59 PM | #21 |
Rep 846
Drives: 2014 F10 M5
Whiteline!
