03-31-2012, 11:57 AM | #1 |
///M
160
Rep 1,867
Verstraβe Extended Aluminum DCT Shifter Paddles
I drop by SonicMS last night to get an alignment done since my alignment was off from the KW SLEEVE install.
I always wanted to check out the paddles in person before purchasing one, after looking at all the color options i decided to go with dark brushed gun metal. Darwin offer to do the install since i was there hanging out anyways, it took him 15-20mins to complete the install while i was talking to him about the Track Car Build that was there. The paddles are worth every penny, it should have came like this from BMW! its so much easier to shift gears and feels great compare to OEM paddles. Only regret is i should have gotten it sooner hahaha
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI |
03-31-2012, 03:39 PM | #2 |
Rep 39
They look great! I've been mulling it over and just order them online.
I have the same color interior as you, and was going back and forth on the finish I'd get. Like the look of the gunmetal from your pics, so that's what I'm going with Hopefully the airbag doesn't deploy in my face when I attempt to install them!!! |
03-31-2012, 06:30 PM | #3 | |
///M
160
Rep 1,867
Yeah I look at all the finish and pick gunmetal because I it matches Better with my interior, it's worth every penny!
04-14-2012, 01:14 PM | #6 |
///M
160
Rep 1,867
i was debating but when i saw it in person i had to pick up a set, it just feel so much better also!
04-14-2012, 04:23 PM | #7 | |
213
Rep 899
To the thread, I also purchased the gunmetal. There are few mods that I would give an unqualified recommendation for but I would this one. Its more than they look kick ass, it gives you more area to tap the paddle when your off center such as corner exit when the wheel isn't fully unwound yet. They also have a much better tactile feel to them. They seem a bit pricey for what you get but I have yet to see anyone regret dropping the ching and I don't think there will be too many that do. |
04-16-2012, 12:38 PM | #8 | |
Rep 39
04-16-2012, 02:09 PM | #9 |
///M
160
Rep 1,867
^ +1
i just love the extra reach you get with these paddles
04-29-2012, 11:08 AM | #11 |
_______
169
Rep 1,088
I swapped out my paddles in my 335i to M3 paddles. Not a bad do it yourself.
Step 1 Disconnect battery so the airbag doesn't go off Step 2 feel under the side of your steering column for little divets. Insert a jewelry flat head screwdriver, press against the spring and push the airbag up. Do the other side. This step is a pain in the ass. Step 3 tape the airbag up so you don't have to disconnect it Step 4 unscrew the steering wheel cover Step 5 unscrew the paddles and disconnect Step 6 reassemble the paddles with the new paddles Step 7 put it all back together This was from memory, should be pretty close.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
04-29-2012, 05:22 PM | #14 |
///M
160
Rep 1,867
You can PM Cal w/sonicms or you can order straight from their website SONICMS DOT NET
04-30-2012, 03:18 PM | #15 |
430
Rep 4,650
You can order directly from our site in the below link.
https://www.sonicms.net/index.php?ro...tegory&path=41 |
