ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      03-27-2012, 12:51 PM   #1
3002 tii
3002 tii's Avatar
2286
Drives: Z4 M, X5, GX460
How Often Should You Rebuild Calipers?
Whether it's by mileage or years... just curious. I know some people never do and just buy remanufactured ones later... thoughts?
Follow for latest mods
      03-27-2012, 12:56 PM   #2
davesz4mc
25
Drives: 2007 z4mc
No reason to unless you are having issues with your brakes. Like a broken seal or something. Just clean up the floating pins during pad changes and you should be good.
      03-27-2012, 01:44 PM   #3
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
No need to rebuild calipers unless the dust boot is cracked or has seperated from the caliper housing. Front caliper rebuild kits as well as guide bushing kits are relatively inexpensive. I buy my Ate rebuild kits from Autohaus AZ.
The Z4M rear caliper rebuild is a PITA and much more challenging than the front calipers as illustrated here:
http://www.bimmerfest.com/forums/sho...6&postcount=11
The kit, P/N 34 21 6 753 682, must be ordered from a dealer and it isn't cheap and you'll need the special tool, P/N 83 30 0 492 459, to press on the dust boot.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      03-27-2012, 10:26 PM   #4
RichardTS
RichardTS's Avatar
Drives: 335i E92 & Z4 M
Originally Posted by jmillet
[SIZE="3"][COLOR="Blue"]No need to rebuild calipers unless the dust boot is cracked or has seperated from the caliper housing. Front caliper rebuild kits as well as guide bushing kits are relatively inexpensive. I buy my Ate rebuild kits from Autohaus AZ.
http://www.bimmerfest.com/forums/sho...p;postcount=11
The kit, P/N 34 21 6 753 682, must be ordered from a dealer and it isn't cheap and you'll need the special tool, P/N 83 30 0 492 459, to press on the dust boot.[/COLOR][/SIZE]
I have a 1973 MGB and the calipers have NEVER been rebuilt or touched internally in any way. Bone dry right now with no stuck pistons. Might be because they are fixed and not floating.
Dont know about BMW's though.
      03-28-2012, 08:21 PM   #5
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
Drives: 2011 E93 335is
Only car I ever had to do this on was a 73 vette. Only reason I saw for it was lack of engineering. Piston diameter vs bore was laughable. Pistons rocked in the bore there was so much difference.
2007 Z4Si(gone)
Couple E30 Verts (DD)
2003 330i
2011 E93 335is - current fav
      03-29-2012, 11:38 AM   #6
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
I have a '79 Harley that still has the original seals and it's strong. I would see no reason unless there's an issue. As mentioned above.
      03-29-2012, 12:09 PM   #7
3002 tii
3002 tii's Avatar
2286
Thanks, when I checked the parts list for the front/rear brakes, the diagram & list mentioned rebuild kit was suggested for cars older than 4 years which is why I asked...
zpost
