03-25-2012, 01:24 PM | #1 |
397
Rep 1,303
installed lux h8 v3 angel eye kit, that heat sink gets HOT!!
So the install was a pain in the ass like it seems most peoples goes, but it only took me about 25-30 minutes...what i did notice that scares me is that the head sink part of the bulb/module gets pretty damn hot even after running the DRL's a few minutes...this is normal right?
03-25-2012, 02:45 PM | #2 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
You haven't done any coding to your angel eye voltage have you?
Only thing I can think of, other than a faulty set of lux
03-25-2012, 02:59 PM | #4 |
Ninja
390
Rep 4,014
heat sink does get hot..IIRC I remember luxangeleyes posting to let the bulbs/sinks cool for a few minutes after running if you do plan on handling the lux unit...
have you pm'd/contacted lux directly?
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
03-25-2012, 09:51 PM | #5 |
49
Rep 1,437
I was thinking of getting lux and did coding was I not suppose to?
AW 2014 M5 ZCP | SG 2013 GL550 AW 2009 M3 (sold) | AW 2011 535xi (sold) | AW 2011 M3 6MT (sold) | OB 2009 GT-R (sold) | AW 2008 335i 6Speed (sold) |
03-27-2012, 08:33 AM | #6 | |
24
Rep 926
Drives: '08 E92 M3
03-27-2012, 08:43 AM | #7 | |
687
Rep 6,845
the brightness won't increase with more voltage but the LED drivers will need to dissipate more heat, which is not a good thing i was actualy interested in seeing what the minimum voltage for them to work is, and lowering my voltage to that. the lower the voltage, the cooler the heatsink the better for the headlight
03-27-2012, 08:45 AM | #8 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
FYI, that's the purpose of a heat sink.
03-27-2012, 11:24 AM | #9 |
469
Rep 4,938
Exactly!!!!! the aluminum heastink is designed to get hot and dissipate the heat away from the LED's. the LED's we use are high powered so therefor they draw Lots of current. most of that current is converted to light, but the remainder is converted into heat. The aluminum heatsink is designed to get hot but keep the LED's at a safe operating temperature.
Our recommendation - not to touch the heatsink if it has been on for more then 10-15 minutes. Let it cool down for a while first.
03-27-2012, 04:37 PM | #10 | |
24
Rep 453
03-27-2012, 11:43 PM | #11 |
28
Rep 275
+1. I was not careful either. Do I need to go back in?
2012 BMW E93 M3 | Mineral White | 6MT
2013 BMW X5 xDrive35i Sport | Black Sapphire 2015 BMW F10 M5 | MCB | ZCP| MPE (On Order) |
03-28-2012, 09:03 AM | #12 |
24
Rep 926
Drives: '08 E92 M3
03-28-2012, 10:18 AM | #13 |
268
Rep 1,883
Drives: 2011 E92 M3
I was not careful either. I am pretty sure wires are touching the heat sinks. I installed them a long time ago and left them. Pulled them open about a week ago just to see and I saw no evidence of burning or melting. I think it'll be fine even if it's touching.
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel |
03-28-2012, 12:37 PM | #14 |
469
Rep 4,938
No the power supply will not be affected if it is touching the heatsink. It would be better to make it not resting directly on top of it, however sometimes its unavoidable.
03-29-2012, 09:48 AM | #15 |
24
Rep 453
I have the power supply out of the way but what about the wires? Can they rest across or touch the heat sink?
