03-21-2012, 05:48 PM | #1 |
102
Rep 614
HELP! Performance Steering Wheel Rev lights not working...
Hi...
I had the dealer install my BMW Performance Steering wheel Version 2 on my 2010 E92 M3. Everything works perfectly except for the shift lights on the wheel. When I boot up the car, the led lights self test perfectly, but when I rev the car, the shift lights don't light up. For an example, see this youtube video Mine does not light up. The dealer is telling me that this wheel is designed for a 335i and I do understand this, but I've seen it work on a M3 just like the video above. Anyone have any hints on how to make it work so that the shift LED lights on the steering wheel function? Thank you!!! Chris |
03-21-2012, 07:28 PM | #3 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
Just my educated guess
Dealer tech is an idiot
03-21-2012, 08:13 PM | #4 |
127
Rep 1,604
Perhaps a setting that you need to program.
2014 Alpine White 328i M Sport | M Performance Exhaust | M Performance Front Splitter | M Performance Carbon Fiber Spoiler | M Performance Grills | M Performance Pedals[/SIZE]
______________________ |
FrozenM3nace36.00 |
03-21-2012, 08:29 PM | #5 |
109
Rep 1,292
Do some research on this forum. It's a very common problem. In short, don't wire the wheel for power out of the jb3 module as per the instructions. Go straight to the fuse box with a fuse that has constant power
03-21-2012, 08:32 PM | #6 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Do you have the settings set correctly?
09-06-2016, 08:37 AM | #8 |
15
Rep 32
hi
I have the same problem in fact the wheel is reading the RPM 10 times less than real value When you go into the Correction Factor settings, what does you steering wheel read when the car is idling? 500-600 or 50-60? mine reads 50-60 so for the wheel to read 1k rpm, i need to rev it to 10k |
09-10-2016, 01:24 PM | #9 |
41
Rep 147
Drives: E92 M3
I have the same problem,
Everything works perfectly except for the shift lights on the wheel. When I boot up the car, the led lights self test perfectly, but when I rev the car, the shift lights don't light up. When I go to settings to change the rpm threshold the indicator that normally shows the current rpm it reads 0. It just happen to me, used to be working Any suggestion ? |
09-14-2016, 11:32 PM | #10 |
Lord Scrip
1813
Rep 3,013
Drives: 2011 M3 Coupe
The batteries died!
