New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      03-21-2012, 02:10 PM   #1
rfx45
rfx45's Avatar
Drives: E89
2012 BMW Z4  [8.50]
Any DIY for Changing the Courtesy Lights?
Search but didn't come up with anything. I tried removing the door courtesy light but couldn't figure out how to remove it and didn't want to force it and break something. I'm thinking of switching it all to LEDs (footwell, courtesy, map lights, trunk) and any guide or tips would be helpful.
Thanks!
2012 Z4
http://e89.zpost.com/forums/image.php?type=sigpic&userid=32142&dateline=132899  8397
      03-21-2012, 03:23 PM   #2
jparnes1
jparnes1's Avatar
245
Drives: 2016 340i, 2012 Z4 35i
Bimmian.com has DIY videos for light replacement. Check it out.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      03-21-2012, 03:30 PM   #3
rfx45
rfx45's Avatar
Drives: E89
2012 BMW Z4  [8.50]
Found this guide from Bimmian: http://www.bimmian.com/elements/page...ht/IXB/IXB.gif
Thanks for the help JP!
2012 Z4
      03-21-2012, 05:22 PM   #4
z4z4z4
z4z4z4's Avatar
Drives: 2002 M3
Door Lamp &*@%^
WARNING: The door lamps (in my '11 Z4) are wired with exactly NO extra length of wiring to the lamp fixture. When you remove the fixture to access/change the bulb, the socket unplugs and the wiring is no longer accessible. I believe it was the better part of a couple hours to make a hook out of safety wire to lasso the socket and pull a few millimeters of slack to allow me to plug in the new bulb and reinstall the fixture.
I switched all my interior/trunk lamps to LED. The footwells, trunk and door lamps are the configuration shown here.
I drove to the ijdmtoy storefront in Rosemead and got good service/information/product.
http://store.ijdmtoy.com/BMW-E89-Z4-...uro_smd_18.htm
Sold 2011 Z4, kept 2002 M3
PM for various e89 parts 4sale.
      03-21-2012, 07:11 PM   #5
rfx45
rfx45's Avatar
Drives: E89
2012 BMW Z4  [8.50]
That is disappointing to read, now I'm afraid to replace it myself.
2012 Z4
      03-22-2012, 06:44 PM   #6
fre2bpowerless
India
Drives: Yes. :D
Dont do it yourself, i had to pull apart one of the door card to fix the plug.
The dealer replaced all the other lights for me at no charge.
      03-22-2012, 10:45 PM   #7
rfx45
rfx45's Avatar
Drives: E89
2012 BMW Z4  [8.50]
The dealership will likely charge $200 for installation of 7 bulbs.
2012 Z4
      03-23-2012, 09:51 AM   #8
z4z4z4
z4z4z4's Avatar
Drives: 2002 M3
I have not helped you by scaring you. I need you to go to the trunk light to practice first. The trick for the doors is that the fixture design allows the lense to come off WITHOUT removing the entire fixture. You can read that in the bimmian guide also. It helps to have the hinsight to understand the written instruction. Again....only remove the sliver of the lense and do not remove the entire fixture. Practice on the accessible footwells or better the trunk light. Good Luck!
      03-23-2012, 02:55 PM   #9
bmwmick
bmwmick's Avatar
Drives: '97 Z3,'11 Z4 35i,'90 C4 Vette
Thanks!
Don't bother changing the map lights or the single dome light. They will constantly give you errors and refuse to work if you use the standard 5 smd LED's. The footwells and the door lamps are NOT monitored for current flow so they will not throw errors.
The doors on my wife's car had very short wire leads too. I just popped them out and twisted 90 degrees to remove the bulb holder from the housing.
Mick
2011 35i 6-speed, ///M Sport, Deep Sea Blue, Black leather, Carbon trim, Cold Weather package, Premium package, 6CD changer. Delivered 7/15/11. Michelin Pilot SuperSport tires 10/24/12
Tucson,AZ/Santa Paula,CA
      10-24-2012, 03:11 PM   #10
motobike
Drives: BMW
Front Map Lights
Has anyone recently tried just swapping out the front map lights (from yellow to white)?
I called up ijdmtoy and they said that the following (error-free-LED) should work:
http://store.ijdmtoy.com/Mercedes-Er...ree_t10_2r.htm
Has anyone tried this?
Thanks
      10-24-2012, 03:44 PM   #11
bmwmick
bmwmick's Avatar
Yellow must have been an option, ours were all clear halogens. The super-white LEDs were nice when they worked, I have not tried the newer ones with the built-in load resistors.
Mick
Mick
      10-24-2012, 03:51 PM   #12
bmwmick
bmwmick's Avatar
Mick
Mick
      10-27-2012, 06:51 PM   #13
BMWE934me
BMWE934me's Avatar
Drives: '11 335i E93 Alpine White
2011 BMW 335i  [10.00]
Thanks
I just bought this set from eBay "7000K XENON WHITE LED BULBS BMW Z4 E89 INTERIOR CAR LED LIGHT BULBS KIT" and will start installing them by Monday. They look to be very good quality. I'll report results.
      10-28-2012, 09:43 AM   #14
mpbruin108
Mpbruin108
mpbruin108's Avatar
187
Drives: I'm a hypermiler
I don't have any problems changing the map lights. NO errors...now taking off the cover was a pain in the you know what. I had to enlist the help of the crew at EAS. There is a lot of elbow grease needed and balls because I was afraid of breaking it trying to take it off. But it can be done.
Floorwells are the next thing for me.
So Cal Drivers: Get your Tires from us to get them QUICKLY (same or next day) and at a GREAT Deal.
2244 Tyler Avenue, South El Monte| Call: 626-443-8539
Active: 2015 BMW i8, 2024 BMW iX, 2018 Mclaren 720s
      11-03-2012, 12:06 PM   #15
BMWE934me
BMWE934me's Avatar
Interior LED DIY
I just replaced all of my interior lights with LED's. Took about 15-20 minutes to change out the trunk, doors, underdash, glovebox and map/dome lights.
As stated in a previous post, it is best to start with the trunk so you can see what you are working with clearly and also, the lamp housing does not come out like the doors and underdash do.
I have added a few pics with details to help out, as it sounds like many are apprehensive to do this upgrade for fear of dsconnecting their harness from the door lamp and having to remove the door panels. Check out the pics below and the notes and you will have no problems.
Name:  Tools and LEDs.jpg
Name:  Under dash lamp.jpg
      11-05-2012, 12:39 AM   #16
motobike
Drives: BMW
Great Thanks. Any pictures and instructions on how to remove the dome and map lights?
Attachment 776017
Attachment 776018
Attachment 776019
Attachment 776020
Attachment 776021
      11-05-2012, 08:47 AM   #17
BMWE934me
BMWE934me's Avatar
It is really simple. I will post a DIY this afternoon. This is where it helps to have a cheap set of plastic trim removal tools so that you don't mark up the trim.
      11-05-2012, 01:07 PM   #18
BMWE934me
BMWE934me's Avatar
Courtesy & Map Light LED Replacement DIY
Here is a quick DIY for replacing the coutesy & map light bulbs with LED's that I put together. Like I said, I put this together quickly and there are a few spelling errors I hope you can overlook, but I hope it is helpful just the same.
Name:  Courtesy & Map 1.jpg
Name:  Courtesy & Map 2.jpg
Name:  Courtesy & Map 3.jpg
Name:  Courtesy & Map 4.jpg
Name:  Courtesy & Map 5.jpg
Name:  Courtesy & Map 6.jpg
Name:  Courtesy & Map 7.jpg
Name:  Courtesy & Map 8.jpg
Name:  Courtesy & Map 9.jpg
Name:  Courtesy & Map 10.jpg
Name:  Courtesy & Map 11.jpg
Name:  Courtesy & Map 12.jpg
      11-05-2012, 11:11 PM   #19
motobike
Drives: BMW
Wow. THANK YOU.
PS. Are you using an LED that built-in load resistor? I just wanted to replace them with a different bulb but now that I your instructions, I'm tempted to replace all 5 lights with this: http://store.ijdmtoy.com/BMW-E89-Z4-...0brands_18.htm
      11-06-2012, 08:43 AM   #20
BMWE934me
BMWE934me's Avatar
Wow. THANK YOU.
http://www.ebay.com/itm/261079090066...84.m1438.l2649 This is the kit I used. It is a more complete kit and it also replaces the trunk, both doors, both courtesy under dash, glovebox, both maps and courtesy lights. It is a high quality kit and they have resistors in them so that you will have no problems with codes or messages due to improper voltage draw. I hope this helps.
      12-20-2012, 04:19 AM   #21
SchweiZ4
SchweiZ4's Avatar
France
52
Drives: F15 X5 M50d
Do it!
Thank you BMWZ44me! I did it yesterday and it is awesome! What a beautiful white atmosphere in the car now. so much better than the old yellow.
I bought the same kit from the same seller and everything went perfect.
Here are my impressions on the kit:
  • All leds are matching perfectly their location:
    10 LEDs for: trunk(x1)/doors(x2)/foot(x2)/Front Dome & Map(x3)/Glove box(x1)
  • Packaging makes it easy to understand which one goes where
  • I got an extra led (10 LEDs instead of 9)
About the installation:
It took me 1h to do. It was easy but I took my time not to break/scratch anything in the car. However you need to be careful of some locations: i.e. under the door, the light cable is very short and it could be difficult to put the light back in place after changing it. My tips is to pull cable slowly (not to break it) to try to strech it out. It works most of the time.
So for $50 you got a nice white lighted car: better looking and better visibility.
      11-07-2014, 11:26 AM   #22
instantfob
Car ADD
instantfob's Avatar
Drives: G30 530e PHEV
Great instructions. Thanks!
I bought these from online and turned out OK.
http://www.aliexpress.com/item/-/1927352154.html
zpost
