ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      03-20-2012, 06:40 PM   #1
ocsdgirl
Drives: Z4
Question Z4 question
I have 17 inch wheels/tires, can I put 18 inch wheels/tires instead? That would fit right?
      03-20-2012, 06:43 PM   #2
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
The sport package came with 18" wheels stock
Straightaways are for fast cars, Corners are for fast drivers.
      03-21-2012, 02:18 PM   #3
DerekSelmanRacing
DerekSelmanRacing's Avatar
Drives: 05 Z4 3.0 SMG, 01 530
Yes (see above), but why? Unless you plan to track the car, it will ride better and there will be less tendency for wheel/tire damage with the 17's.
      03-21-2012, 04:26 PM   #4
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Also depends on the tire profile. the second number in the tire specs.
For example: 275/45/18. 45 is the height of the tire based on the percentage of the 275.
So if you put 18s on, you need to adjust the tire sizes so the entire wheel and tire isn't much larger or smaller than your 17s wheel and tire. Did I make sense?
      03-21-2012, 04:39 PM   #5
Hawkeye
Hawkeye's Avatar
2070
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Some people enjoy the cosmetics of an 18" wheel over a 17" wheel. Myself included.
I believe even 19" fit on the Z4 although there may be slight rubbing issues with 19" at full turn.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      03-21-2012, 05:12 PM   #6
v3.2mc
Not a New Member
v3.2mc's Avatar
Drives: with both hands and both feet
2007 ///M Coupé  [10.00]
this thread has everything you need.
http://www.zpost.com/forums/showthread.php?t=398990
and welcome to zpost!
_
#1498E86 | Sepang Bronze | Dark Sepang Leather | Carbon Leather Trim
      03-22-2012, 05:02 AM   #7
DataStream18
45
Drives: 2003 ESS TS1 Z4
I have stock 18's and I dropped my Z on its belly basically, I only rub with a big bump and can turn from lock to lock (all the way left, all the way right) with no rubbing.
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit.
zpost
