ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      03-12-2012, 04:56 PM   #1
sho-one
MMA fighter and F1 test driver
Drives: Z4///M coupe bulletproof
At Dealer for Inspection I
Well my M coupe is at the dealer for inspection I. Probably my last inspection before the warranty runs out in August. I got a 135 for a loaner. So far so good I guess, Detailed report to follow.
During the initial inspection, they found the power steering was leaking (I' never noticed or would have suspected) and are replacing the power steering hose.
NOW:08 M.Coupe SMB #102/248 #1669/1815
:|MORRVS8|APEX8|SS.X-pipe|SS.PW.Loop|AFE.intake|Matte.grill|short.ant|Z HP.knob|interior.LED|bulletproof
09 Audi Q5
THEN:96Accord|98Camry|04TSX SC|06 M3|06A4|05Civic Si|05Imprezza|05S2000|08FJ
      03-12-2012, 05:06 PM   #2
Finnegan
Dog Listener
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Seems that's not uncommon with the PS. Mine had the same issue (fixed under warranty when with the prior owner). Someone on our board (can't recall who) lost a day at the track fairly recently due to this as well.
My indie shop recommends a change of fluid to help prolong the life of the pump and hoses (hoses in particular). I don't recall the details, but something about the older fluid tends to be unkind to the hoses. There's a DIY on this somewhere around here I think. Seems like a procedure that's probably a good idea to do every couple of years, don't think it's that pricey. At the very least something to check on as part of the overall health and safety check of the vehicle along with other checks (like oil).
So, I have to ask, did you give them the valve inspection worksheet and ask to see what the clearances were and what shims were used? No need to answer now--you can roll that up in the detailed report to follow post.
      03-12-2012, 05:11 PM   #3
sho-one
hmm might have to look that up and check before every track day. I did not give them a valve adjustment worksheet, but i did mention I would like to know the before and after of the valve adjustment...hopefully that will be enough, we shall see.
09 Audi Q5
      03-12-2012, 05:25 PM   #4
Finnegan
Dog Listener
Finnegan's Avatar
Yeah, I need to find the DIY. In any case, adding "check power steering hoses and general condition" to the technical inspection checklist is a must I think.
      03-13-2012, 08:15 AM   #5
mhughett
25
Drives: 2007 Z4 M Coupe
You are lucky they noticed this on your car. I thought my dealer was pretty good but they really let me down here. My warranty ran out in January, two months after I got my Inspection I. Three weeks ago, I pro-actively replaced the engine mount bolts and while I was down there, I noticed that my PS hose had quite a bit of fluid on it and you could see that it had dripped on the panel below. The next time I was at the dealer I asked my SA why they didn't check and/or replace the PS hose while the car was in for the Inspection 1. He first looked very puzzled and when I told him how I found the leaky hose his comment was "I didn't know the M cars had hydraulic PS". Makes me wonder if the tech that did the Inspection I ever removed the panel to check. The PS resevoir sits down so low, if you aren't looking for it you probably won't find it. Oh well, what can I do now?
2013 Audi TT RS (Tech Pkg, Sport Exhaust, Heated Seats, Sirius)
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2.
      03-13-2012, 01:19 PM   #6
Incompatible
Drives: 07 AW Z4C 3.0Si
Find a good indie or at least another dealer.
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
      03-13-2012, 01:54 PM   #7
mhughett
25
I don't need a dealer or an indie to take care of things like this as I'm good enough with a wrench and have enough tools to fix minor things like this myself. It just pisses me off that this was missed during the Inspection I/warranty period and now the bill is on me.
      03-13-2012, 02:41 PM   #8
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
The PS hose had a supersession in design and part number a few years back due to leaks.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      03-13-2012, 04:48 PM   #9
davebho
Drives: 06 M Coupe
i had leaks in 3 places
so i just got my car back last week, had oil leaks from valve cover, from timing chain gasket or something like that, and differential fluid leakage thru the seal...49K miles...
Inspection 2, so had to get valve job and did the differential fluid and tranny fluid while we were at it...they also found that i had some cracked belts so that was done too, along with spark plugs. it was a pretty fat bill. Good thing I still have warranty to cover the leaks.
I had a 335 vert as a loaner...not bad, hard top vert, is nice. Wife loved it compared to the m coupe
      03-13-2012, 10:42 PM   #10
sho-one
wow...hmm maybe I should get an extended maintenance warranty, however I don't think I'll put another 25k in two years. Good thing you got it taken care of though.
I got a 135 vert for a loaner, mixed feelings about it. the tq is nice, but its power delivery is not very linear and the sterring feels weird when you turn. kinda artificial. Back seats are a joke, might as well not have them.
09 Audi Q5
      03-14-2012, 04:10 PM   #11
Ron Stygar
9
Drives: 2006 Z4 M Coupe
If interested, you can see the power steering leak.
http://www.bimmerfest.com/forums/sho...+steering+leak
      03-14-2012, 04:15 PM   #12
Z4MLover2012
Drives: 2008 Space Gray Z4M Coupe
That's a great write-up and the pictures are of great help. Excellent work!
      03-14-2012, 05:41 PM   #13
sho-one
car is ready for pick up, dealer "inspected the engine bolts" and said they were fine, I was hoping to get them replaced as a precaution. I'll see what the inspection paper says, dealer stated that "valves were adjusted". I work the rest of the week so I won't see my baby until Sat. Guess I better learn how to do everything myself. = )
Thanks Ron for the post!
09 Audi Q5
      03-14-2012, 05:44 PM   #14
sho-one
hmm right up says after replacement the part should be fine (power steering fluid tube)
I wish there was a way for me to losen the engine bolts so they could replace them with better bolts >=(
09 Audi Q5
      03-14-2012, 06:34 PM   #15
santov
santov's Avatar
64
Drives: 2007 Z4 3.0si White over Beige
If they really did a valve inspection check your paperwork for the valve shims to make sure they actually adjusted something.
Search around here for part numbers.
      03-14-2012, 06:44 PM   #16
Huz-Z
Huz-Z's Avatar
851
Drives: Z4 3.0si, 328 XDrive, X5 35i
I think I would go back to the dealer, remind them that you have been a good and loyal customer for years, and politely but firmly suggest to them that, as this should have been picked up By them in the inspection and replaced under the warranty, they should look after it now.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package.
      03-14-2012, 07:42 PM   #17
Shota15
Shota15's Avatar
Drives: 07 Z4 M Coupe
Here is a video on replacing the power steering reservoir and filter also, although it is a 3 series it is the same technique, not to difficult.
http://blog.bavauto.com/7568/changin...ini-diy-video/
      03-14-2012, 07:53 PM   #18
Finnegan
Dog Listener
Finnegan's Avatar
Cool! Thanks!
      03-15-2012, 12:11 AM   #19
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
Power steering leaks are common on BMWs with hydraulic steering. My M5 has been extremely reliable, but has had three power steering leaks over the 8 years that I have owned it. I bought my Z4M coupe with 9K miles...yes, it had a power steering leak. That said, I'll take the leaks over the electronic steering offered in the F10 5 series any day of the week.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
      03-15-2012, 01:42 AM   #20
BMW Maniac
Drives: Former Z4M coupe owner
My '91 E30 leaks....my 97 M3 leaks.....I will check to see if my Z4M is now leaking.
On the 91 and 97, the problem are the one time clamps. Replace them with regular hose clamps and you should be good to go. Looking at that power steering line for the Z, looks like the same, BMW clamp that fails....
Its like every 5 years this needs to be replaced~!
1997 /// M3 Coupe Arctic Silver CES STAGE IV (651rwhp/615rwtq)
1999 /// M3 Convertible Techno Violet
      03-15-2012, 08:00 AM   #21
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
My power steering hose has slight weepage that I noticed when I was replacing my engine mount bolts a couple of months ago. My build date is 12/06. It will be on my to do list in the near future. I haven't noticed any added spray on my pan in the last few hundred miles.
      03-17-2012, 06:40 PM   #22
sho-one
hmm i can't get a straight answer. I asked the dealer if they did a valve adjustment, they said they did. I asked how come there are no shim parts on the invoice, they said they kept those in stock and its not a part they have to order so didn't put it on the invoice. They said they adjusted it because the Profile-Gasket:118522 was replaced.
the only parts listed on the invoice were:
Profile Gasket 118522
TWS Syntehtic Oil
Oil Filter
Microcarbon filter
Preformed brake flush
brake fluid
replaced M mobility sealant tire inflating bottle.
Power Steering:
Expansion Hose
Gasket ring
Grr, I dont know if I should just take they word on that, but it just doesn't sound right unless all the valves were in spec (even borderline) and they didn't have to adjust them.
Plus they didn't replace the motor mounts cause mine were fine, even though I asked them to because they are gonna fail, its just a matter of time. What's it to them though, its all under warranty?
I need to learn how to do all this SH*t myself or find a rep indie guy.
09 Audi Q5
zpost
