ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      03-07-2012, 12:42 PM   #1
Mirko
Mirko's Avatar
182
Drives: E86 Z4M, E90 328i, E84 X1
Weird rear end sound
My car was completely quiet in the rear, was out in a bad snow storm and didn't hit anything or go into any ditches. Drove to a friends house, car was parked and as I left was driving down the street a few blocks away and a weird clunk sound from the driverside rear. I thought at first it might be snow build up and ice so washed the car and the sound seemed to occur less frequently. However sometimes it will return driving slower speeds usually on a crappy road or bumps in the road. Checked the RSM a few days later once the weather warmed up. They look okay.
This past weekend got under the car and pulled on the suspension components and nothing would replicate it the sound. Bushings don't look damaged or worn and nothing seems loose. Checked sway bar links as well.
A more recent sound has become apparent. Driving around 60-100km/hr even on a smooth road it sounds like popcorn popping in my trunk. It's faint but you can hear it. Have tried with radio off, heat off, even in neutral and the sound is there.
I wonder if the RSM bushing is gone and as the car goes over the surface it goes up and down similar to what others have described as the metal and rubber clanking over each other.
Taking the car to BMW next week to get checked out as its still under warranty. Note that I did install the Stromung exhaust but this was a month or two before this noise came so don't think its an exhaust leak.
Coles notes: Rear end clunk over bumps at low speeds at times and at higher speed it sounds like popcorn popping while driving.
Anyone else run into a similar issue? Thanks
      03-07-2012, 02:54 PM   #2
boondocksaint
Penfold, shush!
boondocksaint's Avatar
Drives: 07 Z4MC
Exhaust hangar/clearance?
Strut mount?
Wheel bearing? Not the usual noise associated with this, but they're weird sometimes.
Diff mount?
For some reason, I'd want to check the interior panels and make sure some of the plastic fasteners haven't backed out.
      03-07-2012, 04:17 PM   #3
Etch52
Most roads are too short and too straight
Etch52's Avatar
Drives: 2007 M Coupe - Premium Package
Had this happen while driving my Honda Pilot...
Turned out to be ice buildup above the crankcase area. The touch-less car wash didn't clean it out.
Same sounds .. quieter on acceleration.. guess the ice was moving around.
It doesn't take much to make a lot of noise inside.
2010 Honda Pilot Touring, 2013 328i xDrive Luxury Edition, 2007 M Coupe
      03-08-2012, 06:29 AM   #4
MHeavNC
Turd in the Punch Bowl
MHeavNC's Avatar
Drives: 2007 Z4 3.0i /// 2008 M Coupe
Had a popping sound coming from the rear end once.. Thought something was loose but found out that the trunk liner/cover was making the sound.. It wasn't pulled out at the time.. I opened the trunk and pulled it to cover the trunk back up, and no more popping sound.. It also hides my golf clubs... I hope your noise is as simple and nothing serious...
      03-08-2012, 07:59 AM   #5
Mirko
Mirko's Avatar
182
thank you guys .. will take a look at the panels/liner on Saturday to see if it's all tight. Will also take the car to a power wash and try to get under the car. Also going to check passengerside rsm and under carriage.
I wonder if its wind related, it has been windy these past two days. Could be a gap somewhere in the molding.
      03-13-2012, 11:29 AM   #6
Mirko
Mirko's Avatar
182
The weird popcorn sort of sound is due to the window rubbing on the rubber. BMW is currently replacing the window regulators on both the driver and passenger sides.
They are also checking my suspension, so will report back if they find anything there. I think maybe the coil spring broke at the bottom as per the norm for these cars but thats idle speculation.
      03-13-2012, 04:08 PM   #7
Huz-Z
Huz-Z's Avatar
851
Drives: Z4 3.0si, 328 XDrive, X5 35i
I get the same thing when I eat certain veggies.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package.
      03-13-2012, 04:27 PM   #8
Retrodog
Drives: 2003 Z4
Did you find and remove it, or just wait for the spring thaw?
I have German friends, drink German beer, and shoot German guns. So it was only a matter of time till I started driving a German car.
      03-13-2012, 07:06 PM   #9
Etch52
Etch52's Avatar
Dropped by the dealer. They found the ice. Problem solved.
I have lost a tooth in a rear diff before.. (not the Honda). I was prepared for the worst.
      03-13-2012, 07:19 PM   #10
gcochard
24
Drives: 2011.5 E90 M3
2011 BMW M3  [0.00]
The worst, courtesy of my e36 m3:
zpost
