03-02-2012, 06:08 PM | #1 |
197
Rep 1,278
Cleaning Alcantara
Hey guys,
A lot of people have asked about cleaning Alcantara fabric accessories. While there are cleaners on the market specifically for Alcantara, there is a much simpler way of going about cleaning this fabric using things around the house. What you need: 1. A toothbrush (preferably electric) 2. Damp terry cloth 3. 1 Lemon or some lemon juice In this case, we will be cleaning a steering wheel. First, while the steering wheel is dry, use your toothbrush and work in a circular motion around the wheel. It's much easier when you divide the steering wheel into sections. Clean each section at a time. Make sure to hit the sides and back of the wheel as they are the most prone to dirt/grease. Second, squeeze a bit of lemon juice (for scent) into your damp terry cloth. Start off by making straight line movements across the fabric. Try not to bring the cloth back and forth. After you make your forward or backward stroke, life the cloth off of the fabric and repeat. You can damage the fabric by creating too much friction. Lastly, hit the same section you just made damp with your toothbrush again. You will surely see the fibers start to come back to life. Do this a few times over a couple of days and your steering wheel will look brand new See attached picture. The toothbrush head on the left is brand new. The one on the right is after 15 minutes of cleaning. Check out the rag, too! I've only used this wheel for 6 months! Lane
PAST 2007 Black Sapphire E90 335i, 2010 Jerez Black E92 M3, 2012 Mineral White E92 M3, 2013 Singapore Grey F10 M5, 2016 Azurite Black F80 M3,
CURRENT 2017 Oxford White GT350 |
03-02-2012, 06:12 PM | #2 |
70
Rep 920
any before and after pictures of the wheel?
09 E92 M3,AW/FR. MODS:Performane Kidney Grills,Side Gills,Exhaust Tips,BMW Performance Pedals,359 Satin Black GTS Wheels,275/35/19R & 255/35/19F PSS's,Dinan Stage I Suspension,Macht Schnell Spacers 12mmF,5mmR,Rear Fogs,Euphoria 6k,LCI Tails,LUX v3,OEM IND Painted Alpine White CF Performance Spoiler, Front Splitters, and Front Reflectors,Gloss Black Hood Vents,M Performance Steering Wheel.
03-02-2012, 06:50 PM | #3 |
248
Rep 6,125
+1.
So if I don't for the scent, can I just use damp microfiber towel and electric tooth brush?
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
03-02-2012, 07:05 PM | #4 | ||
197
Rep 1,278
Will post after pictures once the wheel dries! Quote:
A terry cloth does a much better job at rejuvenating the fibers. I've tried using a microfiber towel and havent gotten the best results.
03-05-2012, 02:08 AM | #5 | |
248
Rep 6,125
I thought Alcantara stressing wheel (PSW I electric version) was totally worn out but actually it was just built up hand oils and it and didn't know it can be so fresh!!!! I used mix of electric tooth brush (Oral-B rounded one) regular tooth brush then damped microfiber as I don't have terry cloth. Honestly, I didn't expect too much since my Alcantara looked pretty bad but man- it came out great! Thanks for sharing!
03-05-2012, 05:53 AM | #6 | |
*_*
808
Rep 3,160
Before and after pictures?
03-05-2012, 02:01 PM | #7 |
248
Rep 6,125
Sorry, no before/after but will take some pics of current condition (after cleaning) soon and post.
It really works!
03-05-2012, 07:33 PM | #8 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
I use a chamois brush and a spray bottle of alcohol to dissolve finger oils
Works great I'd be worried lemon is a bit too acidic on the fabric
