BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
EXXEL Distributions
      02-24-2012, 05:39 PM   #1
Wendall
***Major MammelToe
Wendall's Avatar
Drives: E92 M3 SG coupe
Chinese Splitters from Ebay
Just installed my with 3m tape, and factory screw on each splitter.
The splitters look great for the price $135. Fitting it on the car was a little work. The construction is okay but the underside had blobs and bulges of resin that i had to grind down with a dremel and lightly sand.
There were small gaps on both sides that are towards the center of the car. I think if i was to sand a little more i could get it to fit a bit better. I filled the gaps with metallic grey silicone.
Here are the results..sorry if the car is a little dirty.
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
      02-24-2012, 05:49 PM   #2
Wendall
***Major MammelToe
Wendall's Avatar
a side shot
      02-24-2012, 07:28 PM   #3
E90M3-SG
E90M3-SG's Avatar
9
Drives: 2016 M5 CP
2010 BMW M3  [10.00]
Looks good...waiting on mine to arrive.
      02-25-2012, 12:38 AM   #4
zibawal
Drives: 2012 X5D
For how much? And link?
      02-25-2012, 01:21 AM   #5
Wendall
***Major MammelToe
Wendall's Avatar
I purchased it for $135 on ebay from cnbjautofans.
This was the original link. Not sure if its still working.
http://www.ebay.com/itm/160565471917...84.m1497.l2649
There are plenty of others on ebay. The weave is okay some minor flaws but looks great for the price and it fits decent with just some minor sanding.
Here is another one:
http://www.ebay.com/itm/BMW-M3-E90-E...item1c241cb4d4
      02-25-2012, 07:35 PM   #6
zibawal
Drives: 2012 X5D
How is the quality ? Did you install your self? Would it fit on E93?
More so if material is real CF or synthetic look alike?
      02-25-2012, 08:11 PM   #7
Raptor251
ESS Dreaming
Raptor251's Avatar
Drives: 2011.5 e92 m3/Ford Raptor 6.2
After having owned two sets of OEM splitters I say yours fit really well. If I have to do it again I think I know what Ill be doing!
      02-25-2012, 08:32 PM   #8
Wendall
***Major MammelToe
Wendall's Avatar
The quality is good but not perfect. The carbon fiber looks great but has some slight distortions but nothing noticeable to the passerby.
Yes, I did the install myself its pretty easy. Use 3M molding double sided tape. You only need a strip on the top and a strip across the bottom.
Yes, It fits all E9x M3s
Yes, its real carbon fiber.
The only negative is you need a little sandpaper to rub out some lumps on the underside of the splitter. If you take some time, it could fit perfectly.
Not a bad deal for a fraction of the OEM cost and I assume I will be replacing these annually due to rock chips and what not as a daily commuter.
      02-25-2012, 08:35 PM   #9
Wendall
***Major MammelToe
Wendall's Avatar
Thanks Raptor. I think it looks pretty good but not as good as OEM. But for a replacement item, i cant justify paying 600+ for these splitters. So i aim satisfied with them.
I suggest you try them next. Just sand the interior bumps and it should fit near OEM.
      02-25-2012, 08:37 PM   #10
sycd
sycd's Avatar
Drives: G87 M2 [MT]
2023 BMW M2 [MT]  [0.00]
2020 BMW X3M  [0.00]
Why you would buy an M3 and then slap on this cheap crap is beyond me.
      02-25-2012, 08:45 PM   #11
Wendall
***Major MammelToe
Wendall's Avatar
Why spend 600 bucks on a item that you will replace every year or so (its my daily driver on a rock chip infested hwy) . Also, Its a component that lets me gauge if you can deal with the slightly lower clearance.
In fact, if the clearance works for me I will consider doing the arkym lip next. Nothing wrong with saving a little money.
I waste enough doing trial and error on audio systems.
      02-25-2012, 09:00 PM   #12
Alex07M3
82
Drives: E92 M3, Evo X MR, A4 Allroad
Because as opposite of the M3 , you pay a lot for the name when you buy the OEM splitters , the ratio quality/money is a lot better on these replica !
      02-25-2012, 09:06 PM   #13
Wendall
***Major MammelToe
Wendall's Avatar
100% agreed
      02-26-2012, 01:46 PM   #14
Mike Lu
Z
Mike Lu's Avatar
43
Drives: E92 AW M3
2010 BMW M3  [2.00]
2009 BMW/M3  [10.00]
Most of those replica CF parts from mainland China or Taiwan aren't real CFs, just some cheap CF paint , I happen to know some guys either works for the factory that makes those replicas or sells them in China. That's why their pricing are so competitive but still makes a pretty good margin. The quality varies from parts to parts even coming from the same batch, same as the fitment. I grabbed one when I was back home for the summer break last year for something like 600 RMB, roughly $9X in US dollars.
Challenge V-weave Front Lip & Mirror Caps | WSTO painted AW front grill & Mag Blue side grill & Mag Blue Tow Hook & Mag Blue mirror inner ring | Te-37 Mag Blue wrapped with R-S3 | Kreissieg F1 exhaust & X-pipe | KW V3 | Vortex EVO X GT-wing | Tinted LCI taillight | Nadi steering wheel & IND shift extension |
      02-26-2012, 03:59 PM   #15
Longbow64
_______
Longbow64's Avatar
169
Drives: 15 M3, 13 X3 35i MSport
This is a great alternative if you're going for color-matched. If you're worried about the weight of real or not real carbon fiber, I think there's other places to save weight. I still don't understand why there aren't more non-carbon fiber options for lips/splitters/diffusers.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat
      02-26-2012, 04:06 PM   #16
TTG
TTG's Avatar
Drives: M340
+1 they look great....
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      03-01-2012, 01:59 PM   #17
HK8888
HK8888's Avatar
Drives: '08 E92 M3
2008 M3 Coupe  [10.00]
I wouldn't like that kind of fitment for sure.
      03-01-2012, 02:05 PM   #18
tibra1
127
Drives: 2011 ZCP M3 - 2007 335i crashd
^This...if people are thinking they will get real CF for $115..then I have a bridge to sell ya.
      03-01-2012, 05:26 PM   #19
tlr
tlr's Avatar
Drives: 2011 M3 E93
Agreed. When I first got my car I thought I'd save a little money by buying cheap CF parts that on the surface looked fine, but I'm inevitably replacing all of them.
The quality just isn't the same. They either don't fit correctly, or the finish will degrade over time in the weather.
      03-01-2012, 06:08 PM   #20
Wendall
***Major MammelToe
Wendall's Avatar
Mine were real CF. You can actually see it from the rear when i sanded down some spots to pre-fit the piece to the car. But either way, I will test them out for a bit. I am already thinking of going challenge lip next since I am no longer worried about the clearance after driving around with the splitters.
      03-01-2012, 06:36 PM   #21
Bosna
Picking fights with sharks
Bosna's Avatar
Drives: 2011 M3 ZCP
I have the OEM splitters on my car, installed by the dealer, and honestly, the fitment is not perfect. It's like 90%, but not perfect. Kudos for saving a few bucks; I definitely would not get the OEM ones over the replicas if I had to do it again. Also, they weigh like half a pound, if that; it's not really a great piece to save weight on.
2011.5 M3 Coupe DCT
2007 Lotus Exige S 6MT
2005 545i 6MT
Fast is subjective.
      03-01-2012, 08:26 PM   #22
AlteredBe4st
First Pride
AlteredBe4st's Avatar
110
Drives: M4
Paying $600 for oem splitters is just insane, congrats on saving a few dollars and all that matters is that you are happy with them. Not because you pay more for something does not always mean it's worth it. I am looking for a front cf spoiler but refuse to pay an arm and leg.
Modded M4
m3post
