02-24-2012, 01:06 PM | #1 |
10
Rep 57
TPMS sensor questions
Hi everyone. I'm going to be getting new rims soon and I know I needed to get a TPMS rebuild kit to have the existing TPMS sensors on the old wheels put on the new wheels. However, when I looked online, there seems to be several such kits that all say they fit my Z, but there are different "colors".
They will say they are gray, black, yellow, orange, or green rebuild kits. Does anyone know how I tell which ones work for my car? Below are 2 examples of the different "colors". Example 1 Example 2 Thanks!
02-24-2012, 02:21 PM | #2 |
Dog Listener
704
Rep 7,850
Looks like there are several part numbers for the stem. Take a look here. Looks like different colors too? (Black, green, yellow.)
At about 14 bucks for 4 of them (according to Realoem), I'd just get them from the stealership and let them figure out which color to source. |
02-25-2012, 11:35 AM | #3 |
55
Rep 1,224
From looking at the pics in the OP's links, it appears that the difference is in the stem length. With aftermarket wheels it would appear that you have the option of ordering the ones which look/work best for your new wheels.
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
02-26-2012, 11:54 AM | #4 |
Rep 136
You may be better off just buying a complete new set of sensors. If I remember correctly they have batteries and will go dead after 6 or 8 years (or something like that).
That would be a major pain to have just installed the old sensors with new stems in your new rims and then have a sensor battery go dead, so you'd have to unmount the tire again just to replace the sensor. It's easy to replace them all now and start from brand new all around. That's what I would do. I think it's about $200 for a complete set of all 4 sensors and stems. Don't buy direct from BMW as they will be more expensive. I believe we have the 433MHz Beru sensors, which you can find online. For example, I quickly searched and found this: http://www.bavarianx.com/BMW_TPMS_Ti...wz4-r8-kit.htm |
02-26-2012, 12:22 PM | #5 | |
460
Rep 4,531
Anyways, I sold the sensors for $170, picked up new ones for $150. They are pretty cheap these days on the used market. |
02-27-2012, 11:32 PM | #6 |
92
Rep 278
Ok so wait, I'm getting new wheels soon as well and was told I could just use the old sensors, but you guys are saying in order to do that I now need to also get a rebuild kit??
Good things may come to those who wait, but only what's left by those who HUSTLE!"
-George Washington |
02-27-2012, 11:39 PM | #7 |
460
Rep 4,531
02-28-2012, 01:22 AM | #8 |
17
Rep 219
Drives: 2007 BMW Z4 M Coupe
Garage List 2000 Volve S70 se [0.00]
2000 Triumph Dayton ... [0.00] 2007 Husqvarna TE250 [0.00] 2002 Ducati Monster ... [0.00] 2007 BMW [0.00] |
Yes. All BMW TPMS sensors are 433mhz... but I believe the 1st generation send an analog signal, while the newer ones are digital. So they're not interchangeable.
02-28-2012, 05:34 AM | #10 |
187
Rep 2,138
Drives: Me
02-28-2012, 11:48 AM | #11 | |
Rep 136
I just know I would get all new sensors so I wouldn't have to fix them only after a year or two - right now, mine are almost 6 years old. The extra cost of having to dismount and remount the tire to put in a new sensor (which you will have to buy at that point, anyway) may be equivalent to just starting out with new sensors on new wheels. |
02-28-2012, 11:50 AM | #12 |
24
Rep 784
Drives: 2011.5 E90 M3
So glad I have an early production that uses the ABS for this!
02-28-2012, 03:11 PM | #13 |
1138
Rep 2,867
Drives: Anything
02-28-2012, 04:40 PM | #14 | |
187
Rep 2,138
Drives: Me
Up to and including MY 2006, the DSC MK60 is used to detect a pressure delta. The best that the system can resolve is a 30% drop in pressure. 30% of 32psi is about 9.6psi. On MY 2007 and up, BMW switched to DSC MK60E5 unit which is also used in the E90+ series abet with different software and that software is upgradable. The new system also takes into account tire temperature and can resolve down to a 5.8psi delta. |
02-28-2012, 08:51 PM | #15 |
1138
Rep 2,867
Drives: Anything
Thanks for the insight! Since we have individual sensor in each wheel, just wished that it could have at least display the pressure coming from those wheels or at least tell you which wheel is low
03-02-2012, 07:13 PM | #17 |
379
Rep 1,002
Drives: 2007 Z4 M Coupe 2012 e93 M3
+1. It is just a waste to have these sensors since u have to check each tire to find out which one needed air. These types of technologies sounded great at first but then they are became impractical once implemented (like got rid of the oil dipstick)
