BMW M3 Forum (E90 E92)
Mporium BMW
      02-15-2012, 10:43 AM   #1
CSanto
638
Drives: 2015 BSM/SO M3
KW Sleeve kit vs Dinan Stage 1
Okay so title states it all. I'm looking for a more aggressive stance but nothing crazy as I live in NY.
My summer set-up is 19" P40s. 255/35/19 9" inch fronts +22 Offset
Rears are 295/30/19 10.5" +25 Offset
I have an 09 so no ZCP. My rears have 1 finger gap. So I'd only like to drop it MAX .5" in the rear. The front is about 2 fingers, so again probably .5" will do.
Whats overall better for performance and ride quality?
Thanks all.
      02-15-2012, 12:03 PM   #2
Mr.MichaelM3
Mr.MichaelM3's Avatar
Drives: 2022 M3XC
Deff go with the S/O kw kit. Im not to sure about the dinan. Are the adjustable?
2010 E90 M3 ESS-vt1 550 SOLD but never forgotten
2015 F80 M3: JB4 and MPE
2022 G80 M3CX: At port
      02-15-2012, 12:07 PM   #3
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
i would say go with the dinan because it sounds like exactly what you are looking for. cant say much on the kw. first two posts are giving you exact opposite advice hahahah
      02-15-2012, 12:12 PM   #4
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
I have my KW adjusted to max ride height. It is about the same height as the Dinan setup. Rides good and less expensive than Dinan!
http://www.m3post.com/forums/showthread.php?t=638732
At max height:
      02-15-2012, 12:39 PM   #5
isugoo
isugoo's Avatar
Drives: 991.2 GTS
At max height:
first time seeing kw s/o at the max height.
looks pretty good.
Dinan front seems tiny bit lower than KW and Dinan rear def. sits lower than your KW.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3
      02-15-2012, 12:49 PM   #6
Z K
Z K's Avatar
1889
looks pretty good.
Yeah, the rear at max height is almost stock height for the rear of the M3. It only lowers it 0.25 inch. At max in front it is lowered 0.5 inch over stock.
Given the KW allows you to customize the height and is less pricey over the Dinan, it was a no brainer for me. The increased roll stiffness makes a difference too when cornering. Definitely less body roll and it tightens up the suspension which felt a bit vague in stock form.
      02-15-2012, 01:40 PM   #7
macavant
always on the "M" button...
macavant's Avatar
Drives: BMW M3
How is it with the streets of SF ? I'm in the BayArea Peninsula and contemplating on the same setup as yours. Wanted to see how it holds up in the city.
Spritzig Graphit Metallisch | 16mpg of unadulterated M goodness ...
      02-15-2012, 03:00 PM   #8
Z K
Z K's Avatar
1889
I wrote a short review here:
It smooths out smaller bumps and larger bumps feel rougher. In the city, about 80% of the time, it feels the same as stock. The other 20% when you are going through rutted out potholed streets, it feels rougher and I have to drive slowly and crawl through it. Some steep driveways and ramps I have to take at an angle to not scrape. On the highway, it rides as stock does.
      02-15-2012, 03:06 PM   #9
Brainofjjj
Astronaut
Bahamas
64
Drives: car
I have my KW sleeve kit sitting at about the lowest setting. I'll get some pics up sometime soon.
The car is stiffer, not extremely but noticeable for sure. I'm having to get GC camber plates now though to get my front evened out. I like the way the car sits but until i get my height and alignment figured out I can't give a good review.
      02-15-2012, 06:19 PM   #10
Richard@M-World
Richard@M-World's Avatar
Drives: NASA TTA #92 M3
KW's kit will ride very similar, if not identical to stock, because the spring rates are only slightly stiffer.
Dinan S1 will ride very similar as well based on personal experience.
Performance improvement for either kit will be marginal compared to stock.
Authorized AiM Dealer - Solo/Solo DL | SmartyCam HD | www.m-world.us
      02-15-2012, 06:26 PM   #11
tlp
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
KW Sleeve kit sitting in the middle of the adjusters. I call the drop "Performance Practical" with the ghetto setting on false.
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
      02-15-2012, 06:42 PM   #12
isugoo
isugoo's Avatar
Drives: 991.2 GTS
you win.
do you now how much they dropped from the middle settings?
      02-15-2012, 07:51 PM   #13
PAKMAN
PAKMAN's Avatar
North Korea
360
Drives: 2011 E92 M3
2011 BMW E92 M3  [9.50]
2006 e90 330i  [5.50]
Thats middle for you???? man i have mine set on full low front and 3/4 low on rear and its about the same.
stock car
      02-15-2012, 09:11 PM   #14
tlp
I noticed that if you don't hammer in the front sleeves thoroughly they can stop short on the sleeve. I kept making some sharpie marks on the strut to monitor the sleeve pounding process until I knew it would go no further.
you win.
Sorry, I didn't take any measurements beforehand. I had stock ZCP previously.
This was the stock drop....
      02-15-2012, 09:15 PM   #15
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Looking good!!
      02-15-2012, 11:36 PM   #16
edu09
edu09's Avatar
1511
Drives: 2024 M2, 2022 GT3, 2022 SF90
2022 FERRARI SF90  [10.00]
2024 BMW  [10.00]
2022 PORSCHE 992 GT3  [10.00]
mine is dropped about 70% on KW sleeve kit, it feels a bit stiffer but great handling, no bouncing at all, love this kit ( had to edit these crappy iphone pics)
2024 BMW M2, 2022 Porsche 992 GT3, 2022 Ferrari SF90, 2023 BMW M1000R comp pkg
      02-16-2012, 08:07 AM   #17
THE TECH
THE TECH's Avatar
307
Nice car!!
      02-16-2012, 09:26 AM   #18
CSanto
638
I was just reading that someone with my spec wheels rub with the dinan suspension. It's probably due to the offset. It would be nice if I could leave the rear on max and get .25 and do .5 on the front. It would probably be the perfect stance for my car.
      02-16-2012, 09:49 AM   #19
chris s
chris s's Avatar
1251
Drives: 2022 Dravit G80 M3
I think KW is a no-brainer over dinan b/c of the height adjustment and the lesser cost. Both seem to offer similar performance.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD
2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten!
2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD!
      02-17-2012, 10:45 AM   #20
Giccy
Giccy's Avatar
33
Drives: like he has much to learn
Seems like a lot of KW s/o users claim a noticeable performance improvement.
What am I missing? I'm considering the K/Ws as I'm looking for slightly lowered ride height, better handling but would like to keep my EDC.
I know coils are the best for performance but I'm no track superstar so I'm looking for the poor man's bargain.
      02-17-2012, 11:00 AM   #21
THE TECH
THE TECH's Avatar
307
My issue is that based on KW's information, these are not meant to lower any further than a good set of springs will. This is why I'm not sold on them. So unless you plan on making tons of adjustments to utilize the "coilover" capability then I don't see the need to spend the extra cash. Just my opinion.
      02-17-2012, 11:24 AM   #22
Z K
Z K's Avatar
1889
The problem with lowering springs is they all lower the car too much if you are only looking for a slight lowering with a performance increase. The exception is the Dinan springs. There isn't anything out there until someone else makes a Dinan equivalent spring without the Dinan price. I don't count Eibach Pro Kit as their springs are too soft and not performance oriented.
m3post
