02-09-2012, 12:02 AM | #3 | |
Supreme Allied Commander
3885
Rep 54,481
Drives: F80 M3
12mm is okay for the rear, but no more. Once lowered and at stock camber settings, anything more than 12mm will rub. If you plan to run more, you will need to add negative camber and anything more than -2 on a street car will start eating up the inside of your rear tires. |
02-09-2012, 06:45 AM | #4 | |
52
Rep 275
02-09-2012, 10:51 AM | #6 | |
3885
Rep 54,481
Drives: F80 M3
As long as the tires are right around the same diameter of the OE you will be okay. We are mostly concerned on diameter on the front with a 255 or 265. Rears at 295 will be a tight fit and you will have to try it. 12mm rear will work fine. 5mm works on the front, 10mm will work with some rubbing on the vents. |
02-09-2012, 09:06 PM | #7 |
61
Rep 234
Momo, I had been running around with 12mm rears and no spacers in the front -with that set up the front looked really "inset" . Today I added 10mm to the front and it looks "right". I am very happy with the 10mmF/12mmR. I personally think the 12mmF/15mmR that some are running looks too agressive or "gangsta" But to each his own!
02-10-2012, 09:52 PM | #9 |
61
Rep 234
