01-10-2012, 08:40 PM | #1 |
21
Rep 704
Drives: '08 MC
any ideas on what caused this?
Below is a pic of the front driver side brake caliper, clearly some corrosion or abrasion took off the grey paint finish on the caliper. The other pic is the rear, that looks to be in fine shape. Its cosmetic on the front, as the brakes work fine.
Anybody else ever see this, or know what would cause it? Going to need to get this cleaned up, hate seeing it. |
01-10-2012, 09:29 PM | #2 |
2432
Rep 11,667
for starters they're supposed to be black no grey.
Someone used a corrosive cleaner on them?
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
01-10-2012, 09:32 PM | #3 |
#dubspec
6337
Rep 5,201
A strong acid cleaner would do that for sure. But the calipers are in fact supposed to be black, so the previous owner may have had them repainted at one point
01-10-2012, 11:59 PM | #4 |
18
Rep 94
if it was repainted, they used non-high heat paint. constant high temp/cooling down will cause most paint to flake off metal surfaces. (we use heat guns to remove paint from steel work, they literally flake themselves off)
repaint them with caliper paint or engine spray paint and it should last a long time. |
01-11-2012, 06:59 AM | #5 | |
21
Rep 704
Drives: '08 MC
Good point on the hi temp/cooling impact. Makes sense as I am starting to see the same paint corrosion on the other front caliper too, but much less so that the one shown above. I am only investigating so I can prevent it from happening again after I fix it. All this begs the question... do I want to just have them repainted properly, or put some different calipers on there. |
01-14-2012, 09:10 PM | #6 | |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Me personally, I'd wait till next time I have to swap pads/rotors and try the G2 stuff then. You could let the caliper hang and not have to worry about rebleeding. Or find a used set of calipers on fleebay and send those to get powdercoated. |
01-14-2012, 09:48 PM | #7 |
21
Rep 704
Drives: '08 MC
Properly but not necessarily professionally unless im feeling lazy and dont want to do it myself. Yes, Would try to coincide it with other brake work too. Good call on G2 thats an easy and cheap solution.
Didnt even think of the powdercoating route. interesting idea as well. And then there is the 'all new' route. |
01-19-2012, 04:30 PM | #8 | |
10
Rep 167
Drives: 2003 Z4 3.0i, Black Saphire
01-21-2012, 10:48 AM | #9 |
21
Rep 704
Drives: '08 MC
Yep, I like your thinking.....
ZHP/Zeck CDV/VT engine mounts/RE trans mounts;clutch stop/Stubby
