BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
BPM
      01-07-2012, 12:22 PM   #1
Wanna Race?
Wanna Race?'s Avatar
Drives: 2011 E92 M3 DCT Interlagos Blu
Very strange shift happening?
Has anyone had a problem with an almost complete loss of power for about 1 second when switching from first to second gear on a DTC? It has happened to me about 5-6 times since I got the car in July, it only happens while I am shifting while slightly turning and the car is cold. It almost feels like the traction is kicking on and then there is a delay for a second before the engine puts power to the tires again. ANy help or comments are appreciated. Thanks
01 E46 LSB 6 Speed (Gone), 05 545I (Gone), 08 550I (Gone), 11 E92 M3 Int blue DCT- Megan Exhaust, Drop in BME Air Filter, CF wing and splitters.
      01-07-2012, 12:59 PM   #2
MSPORTWORLD
MSPORTWORLD's Avatar
Drives: '11 M3 MW/FR - '12 M3 FO/SC
1 second is a pretty long time...when cold there does seem to be a lag in power application for the 1-2 shift. It goes away by the time I leave the development though. Normal from what I can tell.
      01-07-2012, 01:20 PM   #3
IMG's Avatar
Drives: E36 M3 Track car,Ess E90 M3 DD
What year is your car ?
      01-07-2012, 01:42 PM   #4
CBS
CBS's Avatar
Drives: F10535, E90M3, E30M3, E28M5
2017 Alpina B6 GC  [0.00]
2014 535xi M Sport  [0.00]
2014 X3 3.5 M Sport  [0.00]
2011 M3 E90  [9.74]
2007 Z4 M Coupe  [7.00]
1990 M3  [9.50]
1988 M5  [10.00]
I thought the same thing since I had a 2008 M3 w/DCT but OP lists he drives a 2011 M3 w/DCT. I am at a loss for a suggestion.
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes
      01-07-2012, 02:57 PM   #5
Wanna Race?
I have a 2011, ZCP. It only does this while I am slightly turning and accelerating. It does not happen driving strait.
      01-07-2012, 04:46 PM   #6
IMG's Avatar
You might want to get your cars to the dealer and get the latest DCT tune. some of the 08s have a lag between shifts which the newer DCT tunes fixes that but BMW just released a new DCT tune to fix other things and may be you might want to get that !
      01-07-2012, 05:10 PM   #7
VictorH
433
Drives: '09 M3
I wonder if you are talking about the bucking that some people have (I get it sometimes too) when the car is cold and you are just starting off. It might be exacerbated by shifting from 1st to second gear. I never had this problem until I got the latest software "update" and I'm willing to bet it's the cold start engine enrichment that has been leaned out for emissions reasons so that when the engine is cold and it's cold outside the motor doesn't really have enough fuel and cuts out. I've experienced this but only on rare occasion and it's certainly not one second long, perhaps a quarter second and the car bucks pretty hard.
      01-07-2012, 05:26 PM   #8
Wanna Race?
Ok, maybe the timing was off, but it was exactly what you explained and it happens very rarely as well. I do have the latest software, I worked at he dealer for a year and just left, also I live across the street, thank god.
      01-08-2012, 06:23 PM   #9
MKE_M3
MKE_M3's Avatar
Drives: 2011 e90 M3
probably is traction control
      01-09-2012, 11:02 AM   #10
Novus
Lurking Member
Novus's Avatar
Drives: 2014 i3 REX
I've had the same thing happen to me and I just had the DCT software updated in December. It only occurs when shifting from 1st to 2nd during a sharp (90deg) turn and trying to accelerate, let's say briskly. I've had it happen both when the engine is cold and at normal operating temperature. I do not remember seeing the traction control light come on. The clutch feels like it is fully engaged, but the throttle control seems to cut out. As soon as the front wheels are pointed in pretty much the same direction as the rear wheels (say ~5deg) everything returns to normal.
It does not feel like traction control normally does when it kicks in. There seems to be some slip allowed when traction control turns on normally. This is very different as it is a nearly complete loss of power for a good second as the OP described.
It could be some kind of perfect storm as far as the system is concerned (Engagement of 2nd gear, desired throttle position, steering angle, etc.) where everything comes together to make it think there is some catastrophic loss of traction. However, I am not an expert on the intricacies of the traction control system.
My temporary solution is to remain in 1st until the wheels are pretty much pointed in the same direction or to shift to 2nd much earlier in the turn if the opportunity to do so is there.
I work with software developers and there is always the chance that fixing a major issues like the original DCT software issues uncovers or causes some undesired secondary issues. Maybe this is one of those cases.
I'll ask my dealer about it the next time I go in, but it's good to know that this isn't just me.
Driving: 2014 i3 REX
Family: 2018 X5 40e
Retired: 2014 AH3 M-Sport EBII
Retired: 2010 E92 M3 LeMans Blue on Bamboo
m3post
