01-04-2012, 11:46 PM | #1 |
Supreme Allied Commander
3856
Rep 54,414
Drives: F80 M3
>>HP Autowerks<< aFe Stage 2 Intake
This Stage 2 cold air intake system out-flowed the factory intake by 98%. Includes a durable 16 gauge, powder-coated heat shield; this air intake system features a washable/reusable conical air filter. This intake system also features a heat-insulating molded plastic tube that replaces the stock intake tract and directs increased air flow with improved volumetric efficiency for maximum performance. One-piece heat shield requires little or no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
Pro 5 R Filter (Blue) This filter outflows the factory intake by 33%, increases performance and MPG. Constructed with 100% polyurethane on all four sides, this high flow, oiled OE replacement performance filter will outflow stock paper filter for improved horsepower and torque. Five layers of progressively finer mesh cotton gauze media provide maximum airflow for best performance results. Washable and reusable for multiple cleaning cycles, the tall open evenly space pleats provide excellent dust holding capacity for longer service cycle between cleanings. Integrated urethane bump seal insures tight, no leak seal over the life of the filter. Pro Dry S (Gray) This filter outflows the factory intake by 33%, increases performance and MPG. Constructed with 100% polyurethane on all four sides, this high flow "oil-free" OE replacement performance filter will outflow stock paper filter for improved horsepower and torque. Two layers of progressively finer mesh synthetic media provide maximum convenience and easy maintenance. Washable and reusable for multiple cleaning cycles, the tall open evenly spaced pleats provide excellent dust holding capacity for longer service cycle between cleanings. Integrated urethane bump seal insures tight, no leak seal over the life of the filter. Price: $359.00 Order Here: http://www.hpashop.com/aFe-Stage-2-D...one-e82-1m.htm Last edited by HP Autosport; 02-05-2012 at 12:51 AM.. |
01-17-2012, 03:35 PM | #3 |
3856
Rep 54,414
Drives: F80 M3
02-05-2012, 12:35 AM | #4 |
Rep 33
I'd like to place an order of this & the chargepipe, do you mind giving me your email address because I need to get it shipped over here in Indonesia?
Thanks |
02-09-2012, 10:00 PM | #5 |
3856
Rep 54,414
Drives: F80 M3
03-20-2012, 05:37 PM | #8 |
3856
Rep 54,414
Drives: F80 M3
03-30-2012, 04:21 AM | #10 |
31
Rep 515
Does this creates a typical intake sound?
"... on the smiles-per-mile charts, the 1-series M coupe can't be beat. It is a challenging piece, a triple-X-rated driver's machine for semi-professionals. Its handling balance provides an open invitation to indulge in latent oversteer, and provides an opportunity to separate the men from the boys. It is an absolute hoot on the track and an addictive plaything on your favorite twisty back road. "
03-30-2012, 03:04 PM | #11 |
3856
Rep 54,414
Drives: F80 M3
06-20-2012, 11:50 PM | #13 |
3856
Rep 54,414
Drives: F80 M3
Please allow 3-5 days lead time for shipping after you place your order.
12-03-2012, 05:43 PM | #20 |
3856
Rep 54,414
Drives: F80 M3
