01-04-2012, 07:13 AM | #1 |
1099
Rep 2,286
Dinan Software 8600 rpm redline
Just wondering if the Dinan software which raises the redline to 8600 changes the rpm\'s at which the S65 makes maximum hp or torque? I know that with the OEM software 295 lb/ft is reached at 3900 rpm, and max hp of 414 is reached at 8300...
01-04-2012, 07:16 AM | #2 |
Grown Azz Man
430
Rep 3,021
Here you go.......directly from Dinan..................Phil
Dinan E9x M3 Engine Software raises the factory rev-limit from 8400 to 8600 RPM*, endowing the V8 with a broader power band and greater road speed potential in each gear. The software also removes the top speed governor, enabling the cars to attain their ''natural'' top speed; and the V8 will pull right to red-line in top gear! Changes to the throttle mapping help soften throttle tip-in for a sportier feel and improved modulation capabilities. The combination of Dinan's re-calibration of ignition timing, fuel delivery, and cam timing produce a maximum gain of 9 hp @ 6000 rpm and 8 lb-ft @ 6000 RPM. Peak horsepower is increased from 414 to 421 at 7900 RPM. Rev-limit raised from 8400 to 8600 rpm in manual mode only for cars equipped the M Double Clutch Transmission. The rev-limit is unchanged for the M-DCT in automatic mode.
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
01-04-2012, 06:52 PM | #4 |
Rep 349
You're right. Their software for the E46 M3 did in fact ramp up the throttle quite a bit. However, on the E9x's there is just a barely noticeable difference when you hit the sport button. The HP/torque boost is barely noticeable if you have a sensitive rear end. Ah, but the additional 200rpm is nice...
01-05-2012, 01:40 AM | #6 |
135
Rep 3,293
Top speed (delimited) is 286kph (178mph) so with 6% error that translates to a 'natural' top speed of about 307kph (191 mph) [this is the value we would see on our speedo]. If anyone has gone above this with a stock engine then I'd love to know.
01-05-2012, 01:56 AM | #7 | |
156
Rep 580
01-05-2012, 11:08 AM | #9 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
I find the E9X M3 throttle to be very touchy. I think softening up the electronics makes perfect sense.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-08-2012, 09:30 PM | #10 | |
923
Rep 15,818
but, the random M3 that I happen to drive somewhere in Mexico did have a pulley, filter, akra evo, OE tune.
01-08-2012, 11:36 PM | #12 |
220
Rep 905
I made no judgment one way or the other, I was referring to the ol trick of upping the tip in to increase the sensation of power. Its a common thing with tunes from many outfits with many different cars. If you want a judgment in my mind it bodes well that they didn't take the cheap shot.
01-09-2012, 01:09 AM | #13 |
432
Rep 4,567
Not sure if serious...
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
01-09-2012, 01:39 AM | #14 |
15
Rep 122
Why take the time to post this?
Of course I was serious. It looked like in the posters sig he drove a vert and the vert is 400-500 pounds heavier. Therefore I was guessing that if he hit that speed in his vert than a coupe weighing 500 pounds less should potentially hit an even higher speed? Maybe not, and maybe its all about aero at those speeds and little to do with weight of the car but I would think weight still has something to do with it. |
01-09-2012, 09:08 AM | #15 | |
21
Rep 326
01-09-2012, 10:13 AM | #16 | |
88
Rep 1,105
We are talking about a post which stated he hit a certain top speed and was in a vert. My question was with the same tune and rpm and unlimited top speed the coupe/sedan potentially could be faster given a 500 pound difference. Before you tell me to read you may want to read more carefully! |
01-09-2012, 11:05 AM | #17 |
268
Rep 1,883
Drives: 2011 E92 M3
I would think weight only factors in when you're talking about acceleration, i.e. how quickly you can get to that speed.
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel |
01-09-2012, 11:31 AM | #18 | |
432
Rep 4,567
And very, very few production cars can reach 200MPH, and the M3 is not on that list.
01-09-2012, 11:52 AM | #19 |
15
Rep 122
Are you sure about that? While weight does not have nearly the same impact as it does when accelerating at lower speeds since the acceleration is much greater than when accelerating in very small increments when you approach 160 plus mph, it nonetheless still takes power to accelerate a mass regardless of which speed you are at. The effects are much smaller at high speeds because the acceleration is quite minute as you are accelerating very slowly as you inch up to higher speeds above 160 compared to the acceration of 0-130 mph or so.
Maybe 500 pounds does not effect things that much but was just curious! |
01-09-2012, 12:34 PM | #20 |
471
Rep 2,991
Top speed is only power and aerodynamic drag. Weight only affects acceleration.
(there are minor effects, such as tire/friction due to extra weight but largely unimportant) |
01-09-2012, 12:55 PM | #21 | |
15
Rep 122
How do you think you get to top speed? You need continued acceleration and acceleration is proportional to mass so it definetly has an effect. As I said at those speeds with the very low levels of delta in velocity on a second by second basis, the acceleration is relatively low and thus you probably do not notice the effect of weight as much but nonetheless it is still a component of the equation and an important one at that. |
