01-03-2012, 10:31 AM | #1 |
344
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
Need help adjusting Akra muffler height
is this difficult to do? do i have to uninstall the whole side or is there a way i can just push it up and tighten it at a different height?
Ok, so when im standing in the center 1 ft away from the rear bumper and i look directly down towards the tips, i can see that they are completely aligned and flush with the bumper..which is how i wanted it.. But, when i move 10ft back and look at the tips, i can see that the right side is about 2mm lower than the left side. Its not much and u probably cant tell the difference much but it bothers me to death. I know its not the tips because those ive measured and they look even, plus i know those are easy to adjust, just loosen the bolts and twist. What Im concerned about is how to adjust the height of the right side muffler part and move it higher like 2mm. thanks for the input. heres a pic. notice right side is lower slightly |
01-03-2012, 10:34 AM | #2 |
276
Rep 2,216
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
Loosen the tips and move them to the desired location. Very easy and effective.
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
01-03-2012, 10:36 AM | #3 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
There isn't much, if any, adjustment in the muffler height. You could always slot the holes on the brackets but that would mean you'd have to remove them.
01-03-2012, 10:36 AM | #4 | |
344
Rep 2,928
Its the Height of the right muffler section. |
01-03-2012, 10:39 AM | #5 |
307
Rep 13,093
You can also try loosening all of the clamps in the system and retightening.
01-03-2012, 10:40 AM | #6 |
344
Rep 2,928
if there isnt much adjustment in muffler height, what would cause this larger gap on the right side? u can clearly see it in the picture above. it is slight but its there and that bugs me
01-03-2012, 10:41 AM | #7 |
276
Rep 2,216
You can adjust the tilt as well without effecting the length. Loosen it, push it up, tighten it, done.
01-03-2012, 10:44 AM | #8 | |
344
Rep 2,928
i think it could the tilt, right side pointing slight down maybe a few degrees |
01-03-2012, 04:10 PM | #9 |
471
Rep 2,991
yeah, it's almost definitely the tips. If you push them too far in, they start to angle down, you don't need them smashed into the bend coming off the muffler.
01-03-2012, 05:26 PM | #10 | |
344
Rep 2,928
There was no way to tilt the tips up and down as a previous poster wrote. This is annoying. any other thoughts? is there a way to adjust that red hanger in the center? like loosen the bolt, push it up, and re-tighten the muffler? |
01-03-2012, 05:45 PM | #11 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
Do exactly what was mentioned above..... Loosen the clamp at the midpipe to muffler connection, adjust the muffler to where it looks right and then tighten the clamp back up. I had to do this to my Akra a few times to get it right when I installed it.
You are right in thinking it is not your tips, there is not enough adjustment on them to effect the angle that much. |
01-03-2012, 07:33 PM | #12 |
235
Rep 1,334
I'm pretty sure it's your tips. There is definitely enough play in the tips (angle up and down) to adjust it so its even. Try loosening the clamp more, then adjusting it, and then tightening it. I would probably angle the medial drivers side tip down a TAD bit more and the passenger side medial tip up a TAD.
E92 M3 - DCT - 20" BBS LM-R - KW Clubsport - Akrapovic Exhaust - Powerchip Tune - Arkym Aero Kit - HID Halo |
01-03-2012, 07:49 PM | #13 |
276
Rep 2,216
That's another alternative. Loosen the mid pipe clamp on the passenger side and rotate the muffler 2 degrees clockwise and tighten it up.
01-03-2012, 08:46 PM | #14 |
471
Rep 2,991
I bet you'll find this to be the problem. Try loosening the clamp that attaches the connecting pipes to the midpipe, then hold the muffler when you tighten it back up. obviously easier on a lift.
01-03-2012, 10:54 PM | #15 | |
Grease Monkey
295
Rep 2,646
P.S.: If you are super particular (like I am) you can lay a straight edge across all four tips to ensure they are perfectly straight and level with one and other. |
01-04-2012, 05:32 PM | #16 | ||
344
Rep 2,928
Because I tried first to loosen the 13mm bolt on the red hanger nearest the bumper cover but that was tight as hell. I couldn't even turn the bolt 1 degree and got scared I'd strip the bolt so I quit. |
01-05-2012, 08:22 PM | #17 | |
Grease Monkey
295
Rep 2,646
