01-01-2012, 11:15 AM | #1 |
108
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
Bleeding clutch after Track Days
For those road course junkies like my self. Do you see the need to have to bleed the clutch ater ever track day sessions? I still have stock clutch / pressure plate. Mine gets a bit mushy after every session, and seems to build up some air. Using the Motive power bleeder I get a considerable amount of bubbles after bleeding it every track day.
I hadn't really noticed much after the day itself, but after driving it for a couple of weeks after wards. Any of you guys see the same behavior? Thanks for any feedback
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
01-06-2012, 07:21 PM | #2 |
winter mode
62
Rep 2,057
Drives: 08 135i, 88 M3
weird...i never seemed to notice that
88 M3: BMWCCA J Sport
08 135: because streetcar |
01-06-2012, 08:40 PM | #3 |
108
Rep 1,973
I really started to notice it when using ATE Super Blue; don't really remember it with Motul RBF 600.. I think the fluid just boiled a bit too much maybe?
01-06-2012, 08:45 PM | #4 |
NCOIC of Kickin It
78
Rep 946
it shares the reservoir with the brakes, so i could see how the fluid would boil. if your brakes got mushy, it makes sense for your clutch to get mushy.
01-06-2012, 10:31 PM | #5 |
108
Rep 1,973
That was kinda of my thought process too, though not sure how likely that is. I was going to go back to RBF 600, just tried ATE Blue to try something else but it really can't hold up to the heat from these brakes.. while Motul did just fine.
01-09-2012, 09:45 PM | #6 | |
winter mode
62
Rep 2,057
so i get what you mean...the clutch bone's connected to the brake bone, but i don't think your soft clutch is from boiling brake fluid
02-12-2012, 04:35 PM | #8 | |
Supreme Allied Commander
3890
Rep 54,597
Drives: F80 M3
02-12-2012, 07:45 PM | #9 |
140
Rep 2,234
I flush my system once a year with rbf 600 and bleed twice a year. brakes never went soft on me. going to srf this year. btw, if you haven't already swapped in ss brake lines, you should.
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
02-13-2012, 02:34 PM | #10 |
108
Rep 1,973
I put in SS lines a while ago, guess it was a one time thing, been out twice already and clutch feels fine.. maybe I already had air, didn't know.. or didn't flush completely last time.
