12-27-2011, 03:37 PM | #1 |
5234
Rep 10,616
Relocate Rear 02s on X-Pipe with HFCs?
I have noticed that x-pipes with high flow cats eliminate the primary cats from the stock position at the beginning of the x-pipe and replace them with high flow cats in the location of the stock secondary cats before the x in the x-pipe. However, none appear to relocate the rear 02 sensor to after the new and relocated high flow cats. A new bung and an extension harness could do this.
Anyone tried this? Is the ECU so good that the rear 02 must measure the AFR just 16 inches after the front 02 to avoid readiness or other codes? |
12-29-2011, 12:17 AM | #2 | |
721
Rep 3,964
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
12-29-2011, 09:44 AM | #3 |
5234
Rep 10,616
Is it because the HFC were located further back that the front and rear 02 differential was too great?
Or is it because the HFC were too HF? In other words, is there any evidence that 200 cell cats are insufficient but 300 cell cats work? The stock primary cats are probably 400 cell. |
12-30-2011, 01:06 PM | #4 | |
34
Rep 372
A proper readiness tune is calling your name. Stock wiring. |
12-30-2011, 04:40 PM | #6 | |
721
Rep 3,964
You could probaby get away with running HFCs in the secondary position and run the 02 sensors back there but with an extender and it may work..no one I know has done this successfully. Keep in mind the OEM secondary cats are 200cpi... Dave
12-30-2011, 07:11 PM | #7 |
5234
Rep 10,616
I do not think secondary cats do anything for readiness since they are located past the secondary 02s. Readiness will be determined by the cats preceding the secondary 02, wherever each are located.
200 cell cats may be marginal. Some of the HFC x-pipes use 200 cell (AA, Fabspeed), some 100 cell (Akra), and probably some 300 cell. Most of them don't help OBD2 inspection because the HFC are located after the secondary 02. I'd like to find something that works. M3DCTBT says he has a combination that works. |
12-31-2011, 01:16 AM | #8 | |
721
Rep 3,964
Dave
