BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
BPM
      12-25-2011, 01:17 PM   #1
twin turbo
twin turbo's Avatar
Drives: 2020 M340i xdrive
Just tried to install new BMC filter...
The part number is FB 577/08. I purchased it from Eagle Day and I told them my car was a 2011 M3 coupe. The filter does not have the female cylindrical extension that slides over the male tip that is in the air box. It has a flush circle on the end of the filter with a foam padded disc where the cylindrical extension should be. I assume Eagle day must have sent me the wrong filter. Can anyone elaborate on this? Thanks in advance.
2020 BMW M340i xdrive
2016 BMW M4 (sold)
2015 BMW M4 (sold)
2014 Audi RS5 (sold)
2012 Audi TT RS (sold)
      12-25-2011, 01:49 PM   #2
Ateam
88
Drives: M3
Thy sent u wrong one. Happened to me. Its annoying. You can
Make it work with a ms extender but its a hassle. Return
it and get right one with longer extension for 2010su and above
      12-25-2011, 01:52 PM   #3
///M3///
Drives: '11 E90 M3
Mine was like that too. although the foam is there it gives a bit and was in there really solid.
      12-25-2011, 01:57 PM   #4
BMW Fanatic
135
Drives: slow
Post a pic, we can tell you straight away if it is the correct filter or not.
      12-25-2011, 02:21 PM   #5
twin turbo
twin turbo's Avatar
2016 BMW M4 (sold)
2015 BMW M4 (sold)
      12-25-2011, 02:26 PM   #6
twin turbo
twin turbo's Avatar
Here is a link to Eagle Day's site with a picture of the filter. The filter they sent me does not look like that.
http://www.eagleday.com/bmwm3v820ebm.html
2016 BMW M4 (sold)
2015 BMW M4 (sold)
      12-25-2011, 03:32 PM   #7
Smokescreen
Drives: 2011 M3 E90
should work, that's how mine looks. Once the foam is centered, it's a snug fit with plenty of pressure to keep the filter in place. Enjoy the sound!
      12-25-2011, 04:01 PM   #8
Moxie
Moxie's Avatar
Drives: AW 328d Touring/SG 335d
The male end is spring loaded. Push it in & slide the filter in place.
      12-25-2011, 04:08 PM   #9
cole328
15
Drives: 2011 M3 Convertible
Intriguing....I have an '11 vert would solely changing an air filter make a noticeable difference in any regard to an otherwise stock car?
      12-25-2011, 05:47 PM   #10
twin turbo
twin turbo's Avatar
I will try again, but there was a pretty big gap between the filter and the spring loaded piece. The foam piece would not even touch the spring loaded piece. The filter would not stay in place because there was nothing holding it. The picture on Eagle Day's website has the extended cylindrical piece just like the factory filter. I don't understand why this one is different. I was doing some internet surfing regarding BMC filters and I came across a couple of for sale threads. They stated that the airbox changed in 2010 and that the filters were different for 2008-09 cars. Is this true?
2016 BMW M4 (sold)
2015 BMW M4 (sold)
      12-25-2011, 06:17 PM   #11
twin turbo
twin turbo's Avatar
In this thread, they talk about a euro adaptor being needed for a 2010 car. I think that is what I need.
http://www.m3post.com/forums/showthread.php?t=358520
2016 BMW M4 (sold)
2015 BMW M4 (sold)
      12-25-2011, 06:27 PM   #12
twin turbo
twin turbo's Avatar
Here is the adapter that I need. I guess Eagle Day did not know this is necessary.
http://www.europeanautosource.com/pr...2010-us-models
2016 BMW M4 (sold)
2015 BMW M4 (sold)
      12-25-2011, 06:35 PM   #13
GIdriver
GIdriver's Avatar
Drives: 2014 E63 AMG-S
You don't need an adapter. The part number you look for is FB 536/08. Your car uses the EURO version. BMC has this filter and there's no need for the adapter. Contact Eagle so they can send you the correct one. Believe me I have one. I will no longer use it though.
      12-25-2011, 06:37 PM   #14
Ateam
88
Drives: M3
guys this is clearly the wrong filtere Also someone said he would not buy an "eagle filter" and to go with KN. THis isnt and eagle filter, its a bmc distruted by them.
I had the exact same thing. That one WILL NOT fit and will rattle in your box.
The proper "euro" one is about an inch longer and will tightly fit into the box v. the one you have does not fit because the peg is too short.
I would not buy an adapter but rather send it back and get them to send the right one. Adapter has more chance to rattle around too. Just get the right filter because the proper one has the little "penis" that is much longer and solid v. the adapter which is another piece to the system that can creak and rattle. Trust me on this I tried both ways.
      12-25-2011, 06:50 PM   #15
GIdriver
GIdriver's Avatar
I would not buy from that site again. I may be wrong but to my knowledge there is no 2007 e9x M3. MY starts 2008. FYI you can find the filter cheaper from other sites. I bought mine for $116
      12-25-2011, 06:50 PM   #16
twin turbo
twin turbo's Avatar
Why aren't you using the filter any more?
2016 BMW M4 (sold)
2015 BMW M4 (sold)
      12-25-2011, 06:58 PM   #17
GIdriver
GIdriver's Avatar
http://www.m3post.com/forums/showthread.php?t=626643
Post #18
      12-25-2011, 07:11 PM   #18
twin turbo
twin turbo's Avatar
Now you got me rethinking the whole air filter thing. Thanks for your input.
2016 BMW M4 (sold)
2015 BMW M4 (sold)
      12-25-2011, 07:31 PM   #19
GIdriver
GIdriver's Avatar
You're welcome. I don't want to scare you or anything. Do your research.
      12-25-2011, 09:36 PM   #20
tibra1
127
Drives: 2011 ZCP M3 - 2007 335i crashd
As I stated K&N and AFE are tried and proven air filters..AND they are much cheaper..new K&N is $60 new AFE is $80..
      12-25-2011, 09:50 PM   #21
Jaypod
Jaypod's Avatar
125
Drives: Frozen M3, AM V8V, 991 GT3
I would put a BMC filter in my car before K&N and AFE any day
      12-25-2011, 10:07 PM   #22
GIdriver
GIdriver's Avatar
Here we go again......
m3post
