      12-13-2011, 06:51 PM   #1
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
confirming the confirmed: N55 midpipes swap
yesterday took out the midpipes from the 2012 135 and swapped with the 1M. no change for the 135 but a good amount of pop and rumble for the 1M with the N55 pipes! perfect remove and bolt swap too.
highly recommended simple mod to the OEM exhaust setup!
      12-13-2011, 07:02 PM   #2
Oaktree
Oaktree's Avatar
Drives: 2012 X5 - 2010 M3 - 1999 M3
Can you explain more? More backfire type sounds, deeper tone, 25% louder at all speeds?
      12-13-2011, 07:17 PM   #3
mrow
Drives: AW 1M
VIDEO!
      12-13-2011, 07:24 PM   #4
Vrumpkin
Seymour J. Vrumpkin
Vrumpkin's Avatar
15
Drives: BMW 1M
Originally Posted by mrow View Post
VIDEO!
This.
Please
      12-13-2011, 07:44 PM   #5
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
VIDEO!
+1
      12-13-2011, 07:45 PM   #6
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
JUST DO IT! ok ill do my best for a vid soon
      12-13-2011, 07:46 PM   #7
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
all correct!
      12-13-2011, 07:53 PM   #8
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
Originally Posted by ianf View Post
So the 135i got the 1M's pipes? Maybe I should swap mine over
yes just make sure its a N55 car you're doing the swap with
      12-13-2011, 08:08 PM   #9
keinz
Drives: 2011 1M ~ too be
where can one find n55 midpipe for sale?
      12-13-2011, 08:12 PM   #10
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
.. don't the 1M mids have cats?
Yep..2 centre cats identical to the N54 135i.
      12-13-2011, 08:37 PM   #11
Oaktree
Oaktree's Avatar
So adding 2ndry cats to the N55 can't be a good thing?
I can't imagine it is.
      12-13-2011, 09:32 PM   #12
Papethova
225
Drives: '08 135/ '11 1M
hahaha convinced yourself in mid sentence??
      12-13-2011, 09:40 PM   #13
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
Well I have my N55, with 1M coming. What did it do to the noise of the 135i... don't the 1M mids have cats?
135 was fine, ill drive it more extensively this weekend to see if it negatively affected it
      12-13-2011, 09:41 PM   #14
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
quoting samleeyy, itll make the N55 135 a SUPER GREEN car
      12-14-2011, 12:04 AM   #15
ZCP M3
19
Drives: 2011 VO 1M Coupe #759
So you still have the downpipe cats correct? Wonder if it still passes emissions...
      12-14-2011, 02:10 AM   #16
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
yes correct. exhaust fumes do smell different now but nothing too obnoxious. its my understanding with these midpipes the car will still pass emissions
      12-14-2011, 02:19 AM   #17
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Ahhhh.. Don't think so.. that's why the 1M ( N54 ) has mid cats OEM..
And the 135i ( N55 ) has no mid cats..different emissions for different engines..
      12-14-2011, 11:23 AM   #18
smug01
Drives: 1M VO, '97 Land Cruiser
The secondary cats are required to keep the vehicle emissions in check while the diagnostic is run on the rear O2 sensor. This is required each drive cycle, where the ECU modifies the fuel air mixture into a region that makes the primary cats less effective in reducing emissions. I believe this revised diagnostic was implemented in 2010 regulations.
Once the diagnostic is complete, the primary cats are sufficient to meet emissions. Since this diagnostic will likely complete within the first few minutes of a drive cycle, you should have no problem passing a smog check, based on emissions measured.
      12-14-2011, 12:51 PM   #19
smug01
The N55 primary cat should have been designed with the rear O2 sensor integrated mid length so it can complete its diagnostic without the use of a secondary cat.
      12-15-2011, 12:18 AM   #20
mrow
Drives: AW 1M
My understanding is there is no O2 sensor past the first set of cats.
      12-15-2011, 01:16 AM   #21
smug01
Correct. The rear O2 sensor I was referring to is the one right downstream of the primary cat. It is the one that needs the diagnostic...which causes emissions breakthrough of the primary cat.
      12-15-2011, 01:23 AM   #22
smug01
This means that the secondary cat is only necessary to contain emissions for a very short duration during each drive cycle.
So yes, removing it will increase emissions a small amount for a short period of time, but this will not be detectable with a sniff emissions test (since the test is on a warm engine after the diagnostic would have completed).
It is still, technically illegal to remove the secondary cats for on road use, per the letter of the law.
