BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
Mporium BMW
      12-12-2011, 12:21 AM   #1
Fentanyl
///Mazing
Drives: E90 AW M3 6MT
2008 E90 M3  [0.00]
Possible BIG problem!!!
Hi everyone, just recently I've found that when I drive over 60kph (38mph) my steering wheel begins to shake and gets worse as I go faster. I've tried to get into the shop but it looks like the 20th is the soonest. I checked to make sure my wheel lugs were torqued correctly. Any thoughts as to what it might be?
      12-12-2011, 12:31 AM   #2
saeedg48
Drives: Porsche 991.1 GT3
caster adjustment.. not a big deal at all
2015 Porsche 991.1 GT3
2015 F80 M3 -- Individual; Space Grey
      12-12-2011, 12:56 AM   #3
LateBraking
Drives: Relatively Quick.
I would be guessing bent wheel or a wheel weight that fell off first....
      12-12-2011, 01:02 AM   #4
BMRLVR
Grease Monkey
BMRLVR's Avatar
295
Drives: 2011 E90 M3,1994 Euro E36 M3/4
I highly doubt it is caster and here are two reasons why: 1) Alignment problems don't usually cause shaking issues, usually they cause handling issues and abnormal tire wear. 2) There is no reason for the caster to suddenly change and cause a shaking problem, unless you hit something really hard.
Go to a tire shop and have them spin all four wheels/tires on a wheel balancer. This way you will be able to tell if the tires are in need of balancing of if you have a bent rim. You don't need to go to a dealer for this...... any reputable tire shop can do it for you.
One other possibility is: If you guys got snow recently then a build-up of ice and snow on your wheels can cause this problem also.
2011 E90 M3 ZCP - Individual Moonstone/Individual Amarone Extended/Individual Piano Black With Inlay:LINK!!!
1994 Euro E36 M3 Sedan - Daytona Violet/Mulberry:LINK!!!
      12-12-2011, 01:10 AM   #5
boosted43
boosted43's Avatar
Drives: 2017 C43 AMG
2015 BMW 335i  [0.00]
tire bubbles perhaps? or as a previous poster said, maybe bent or cracked wheel. could be a few things. but good luck and hope you get it fixed sooner. better safe than sorry...
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
      12-12-2011, 06:19 AM   #6
J08M3
J08M3's Avatar
Drives: 2011 M3 COUPE
this, the wheel weight part. probably an imbalanced wheel.
      12-12-2011, 09:30 AM   #7
nchan50
7
Drives: 2009 JzB/FR e92 M3
Are you running spacers?
      12-12-2011, 09:54 AM   #8
VSmotorsports
VSmotorsports's Avatar
157
Drives: e92 M3
Like others have said the wheel balance sounds like the issue. Bad Alignments don't cause the wheel to shake.
      12-12-2011, 10:40 AM   #9
Krozi
Krozi's Avatar
Drives: 2008 E92 ///M3 Alpine White
Either a very big wheel weight fell off or bent wheel...
2008 E92 ///M3 Alpine White//Fox Red//6MT//
Florida Bimmer - Join us on FaceBook!
      12-12-2011, 01:57 PM   #10
Fentanyl
///Mazing
2008 E90 M3  [0.00]
Thanks for all the posts guys. Just to note I have not hit my car recently so I don't see how the wheel can be bent and I do not have any spacers either. I'll try to get into a wheel shop to check on the wheel balance. Hopefully that's the problem.
      12-12-2011, 02:15 PM   #11
turbo8765
61
Drives: very fast
Wheel weight... no biggie
      12-12-2011, 05:31 PM   #12
Twinbo
Twinbo's Avatar
14
Drives: ....
Shake in the wheel = front wheel balance issue
Shake in seat of pants = rear wheel balance issue
Just a basic piece of advice that has served me well since I got it
      12-12-2011, 05:54 PM   #13
turbo8765
61
Drives: very fast
BTW... why do you go by fentanyl?
Some people might find that a little concerning
      12-12-2011, 06:32 PM   #14
mshab356
Go ///M or go home
mshab356's Avatar
Drives: 2015 F80 M3 6MT
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT
      12-12-2011, 07:12 PM   #15
Fentanyl
///Mazing
2008 E90 M3  [0.00]
Haha. Well I'm sure you all know what fentanyl is and if you don't its a great drug that can really help ppl (that's if you don't abuse it). Does that answer ur question turbo8765?
      12-12-2011, 07:13 PM   #16
xchosun1x
Track Duty
xchosun1x's Avatar
Drives: Track build 08 E92 M3 DCT
+1
      12-12-2011, 07:24 PM   #17
iDRIFT
10
Drives: Fast!
was it snowing? could be snow stuck on or around ur rotor or can be as simple as a wheel alignment or a wheel weight fell off, dont worry not that big of a deal, take it in to a independent shop locally if the wait is that long, easy fix
      12-13-2011, 01:08 PM   #18
Fentanyl
///Mazing
2008 E90 M3  [0.00]
Update:
Went to a wheel shop and they found one of my tires forming welts or bubbles when the went to do a tire balance. They didn't really give me a good explaination as to how or why it happened most a tire defect they say. Keeping in mind I've been using these tires for about 3 winters. Well hopefully this doesn't happen to the other tires. Thanks again guys
m3post
