BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
European Auto Source (EAS)
      12-09-2011, 08:49 PM   #1
Ateam
88
Drives: M3
A surprising extra benefit of ACM exhaust
I cannot speak to many of the other ones out there, but I am sure most of them are a "straight pipe" to some degree with varying amounts of absorption material and different size/shape hemoltz resonators however the ACM mod is 2 straight pipes basically through the hemoltz resonator. This is such a more direct path than the zig zaggin tight turns of the OEM exhaust. SO obviously its nice and loud and sounds good BUT
I actually picked up 2 mpg on the freeway-was able to hit 27mpg going 70mph on the same road I go on almost every day, same temps out, same gas etc. I have driven over 25 times with this car and always try to see how much economy I can get on the long stretch of 20 minutes on the freeway. Consistently 25 is the highest i hit and usually end up at 23-24. I never saw 26 even for a moment, let alone 27!
I would like to take a longer trip and watch the mileage. I only went about 10 miles and then a HUGE long tunnel was coming up and had to have some fun so dropped the mpg down to 16 quickly!
Anyway anyone else get better mpg with the exhaust? Since I assume that means much less back pressure and more engine efficiency, I am curious if there is some decent hp gains with this (decent I mean 4-6hp for a rear which is good!) I know MOST cars do not make much power with a rear only but the zig zag stock design really must do a number on exhaust velocity at the end of the muffler system and cause some degree of back pressure that is alleviated with 2 straight pipes.
      12-10-2011, 09:50 AM   #2
Bart@AUTOcouture
BimmerPost Supporting Vendor
Bart@AUTOcouture's Avatar
1007
Drives: F95X5M | E46M3 | E92M3 | E60M5
Awesome observation. Glad you are enjoying it! I love mine
      12-11-2011, 08:13 PM   #3
Ateam
88
Drives: M3
Wow, thought more people would be pretty stoked to gain an extra 2mpg on the freeway if they were commuters!
I would assume this is "proof" that airflow is better and less restricted which also should have a good effect on power.
I would be curious if some of the other exhausts that do not use a straight pipe also help mpg
This exhaust sounds like a lambo (only at much lower volume) its awesome!
m3post
