12-06-2011, 08:04 PM | #1 |
11817
Rep 23,187
clutch pedal movement
can someone with a 6mt comment on the side to side motion of the clutch pedal assembly. if i get down there with my hand and move it i can move it from side to side about 1 inch. is this normal or from use and abuse at the track.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
12-06-2011, 08:27 PM | #2 |
337
Rep 1,489
Chriszeh, I can move mine about a 3/4 of an inch. It does not move easily and I don't notice it while driving.
12-06-2011, 08:38 PM | #3 |
11817
Rep 23,187
are you saying it requires some force to move it. mine wiggles rather easily. i thought at first my pedal set was loose but it is actually the pedal motion.
12-06-2011, 08:42 PM | #4 |
Rep 59
Mine moves a bit but only after the spring removal DIY - much prefer it this way however...
AW E92, Innotech Evo, Evolve Tune, CAI, Pulley, ZCP Wheels, CF Cosmetics.... Done for now.
12-06-2011, 08:42 PM | #5 |
326
Rep 3,882
Did you take the clutch assist spring out? I hear it's typical of that mod. Don't know if it's detrimental or not, but so far I haven't noticed anything out of the norm after many track days. That wriggle has been there since the day I pulled the spring out.
12-06-2011, 08:46 PM | #6 |
11817
Rep 23,187
yes i did do the spring removal DIY. will ask next time in for diff fluid and spark plugs if they can have a look. was just curious if that was a normal thing. thanks.
12-06-2011, 08:58 PM | #7 |
337
Rep 1,489
12-06-2011, 09:09 PM | #8 | |
337
Rep 1,489
See video I made just for you lol. I just posted so it may take a minute. http://www.youtube.com/watch?v=viUMrdVXjn4 |
12-06-2011, 09:36 PM | #9 |
trollololol
148
Rep 878
Very normal, don't even worry about it.
12-07-2011, 01:48 AM | #10 |
29
Rep 843
Since you have the spring removal completed, see if the two telescoping shafts are still installed. At first I took these out, but the pedal was too loose and sloppy, so I put them back in less the second spring, and lateral play is very minimal now.
12-07-2011, 09:36 AM | #11 |
11817
Rep 23,187
Those run inside the coils of the spring correct. I did remove those as well.
12-07-2011, 04:23 PM | #13 |
11817
Rep 23,187
Will do possibly. Hate trying to climb around under the dash area as there isn't any comfortable way to get at it.
12-17-2011, 02:04 PM | #14 |
11817
Rep 23,187
i ended up having one nut on the back of the BMWpedal from EAS that was slightly loose which made a light sound when releasing the pedal which caused me to think something was wrong. just retightened and all good.
