New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      10-21-2011, 08:31 PM   #1
entrepreneur177
из Кремля
entrepreneur177's Avatar
Russian Federation
15
Drives: Z4 35s, CLS63 AMG
KW 1 coilovers
Hey everyone!
Anyone tried KW variant 1? Any opinions on that coilover kit?
      10-22-2011, 01:15 PM   #2
timber511
13
Drives: BMW Z435IS
kw v serious is way too soft if you want to improve the handing and track the car.
I will suggest cks coilover. If you want to stick to kw ,you could switch the spring .
      10-22-2011, 04:39 PM   #3
RichardC
Sleepy
Drives: 2011 e89 Z4 sDrive35i
I'm on KW V3, and it's a good balance for a daily driver.
      10-26-2011, 02:28 PM   #4
ModBargains.com
Drives: JB E92 335i
The KW V1 coilovers will give you the ability to adjust the height of your car with pre-set damping. It's definitely a great choice for an everyday street driven vehicle!
      10-27-2011, 12:32 PM   #5
bootboot
Drives: E89 Z4 sDrive23i, F10 520i
I'm on V1's and love them. They will firm up your ride a bit without being overly harsh.
      05-04-2012, 01:16 PM   #6
themush1326
25
Drives: 2014 335xi
What are the height range adjustments, compared to stock?
Does it go higher than stock and lower than stock?
      11-19-2013, 08:40 AM   #7
shlai
Hong Kong
Drives: 2009 Z4 E89 3.5i DCT
The damper of kw v1 is preset. It is set by the expert of kw, the german said. could anyone brighten me on this? how do kw's engineer know what wheels I am fitting in my car? bmw factory wheel weight can vary a lot across different wheel sizes and wheel model, not to mention if I put aftermath wheels. I put Advan wheels to my car and each of them is at least 9 pounds lighter than the factory 296. Thanks!
      11-19-2013, 02:23 PM   #8
andrewyfang
Drives: 09 35i
Not too sure where you're getting this from. Maybe the V1s are a little soft since they are introductory variants of the KWs. My V3s are set up super stiff and I don't think the normal consumer would even be able to tolerate how stiff my car is.
With that being said, the V3s are worth the extra money over the V1s.
      11-19-2013, 02:24 PM   #9
andrewyfang
Drives: 09 35i
From my understanding, I don't believe wheels/tires play a significant factor on how the suspension behaves. It has more to do with the weight and distribution of the car rather than the wheels/tires.
      11-24-2013, 10:17 PM   #10
chudinovvn
Drives: z4 e89 sdrive30
And what about quality of V1 and V3, does V3 significantly more durable than V1 or they are the same?
      11-27-2013, 04:19 AM   #11
entrepreneur177
из Кремля
Russian Federation
15
well now that i have KW1 for over 2 year period, i can state that it's what i need.
Car is more siffer, agile not to mention the ability to drop the car.
Im planning to go Moscow raceway track next season, will see how it behaves in proper conditions )
      02-10-2014, 06:28 AM   #12
shlai
Hong Kong
i installed mh kw v3 for two weeks. the rear springs keep making knocking noise. at first, it is on the right, then on the left as well. but after a week, the right makes almost no noise but the left continues. some paint starts to chip off from the spring end at the top, where kw perch is in direct contact with the spring with no rubber in between. the handling is great but the knocking noise is really annoying. i search many discussion forum and i think this is called spring bind, in which the coil of spring hit each other. my shop sad the only solution is to wrap the coil with plastic.
i play around with the compression and rebound setting and it seems kw recommended is the best. i dont track so i think i should have bought the cheaper kw v1. of course, i didnt know aftet trying myself
      02-10-2014, 06:33 AM   #13
shlai
Hong Kong
first shot is when the car is jack up with wheel taken off. the coil of spring is almost touching itself. the second is when the car jacked off with wheel on. the coil is touching itself. i feel for the miney i have spebt, kw design should have been better
      02-10-2014, 06:35 AM   #14
shlai
Hong Kong
discussion forum said spring bind is very common for progressive spring. dont know if kw v1 is runing progressive
zpost
