10-05-2011, 02:02 PM | #1 |
Rep 60
Exhaust tips melt?
I'm thinking of getting my exhaust TIPS powder coated but the guy at the powder coating shop said if the temp get over 300-400 degrees they will melt. Do you think this will happen? Do the tips even get that hot?
10-05-2011, 02:15 PM | #2 |
145
Rep 3,329
thread title is mad misleading lol
I believe powder coating may begin to fade away after some time that is why most companies do ceramic coating for exhausts.
F80 ///M3 6MT Avus Blue ZCP |
10-05-2011, 02:21 PM | #3 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
With cats, you should have no issues I would think.
10-05-2011, 02:29 PM | #4 |
4th down; 4th quarter? Renegade.
87
Rep 3,850
I know some people have had issues...not sure if they were catted or not.
You could get them coated with ceramic, but your color options will likely be limited. |
10-06-2011, 04:03 AM | #6 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
Not true...... a Catalytic Convertor causes an exothermic reaction which means it creates heat. Catalytic Convertors make the exhaust stream hotter therefore it would be more harmful to the tips.
To the OP..... as others have said the way to go in this case would ceramic coat! Ceramic coating is available in a variety of colors these days and is almost impervious to heat. |
10-06-2011, 08:51 AM | #7 | |
307
Rep 13,093
10-06-2011, 03:33 PM | #8 |
Grease Monkey
295
Rep 2,646
Cats need to warm up to start working (hence the catalyst heating cycle upon cold start-up) however once they are heated to light-off (the temperature where the catalytic reactions start to occur) they then start to produce their own heat through the exothermic catalytic reaction taking place.
10-06-2011, 03:43 PM | #9 | |
307
Rep 13,093
10-06-2011, 08:41 PM | #10 |
Rep 60
How much does the ceramic coating cost? Does anyone in So Cal recommend any shop? Would it be cheaper and less of a hassle to just buy a OEM set off a vendor? Thanks for the advice, def not going with the powder coat.
10-06-2011, 09:31 PM | #11 |
Grease Monkey
295
Rep 2,646
