10-02-2011, 12:56 PM | #1 |
2021 X3MC
258
Rep 779
Drives: X3MC / R8V10 Gated
Quick question about 2nd gear not engaging
Hey guys,
Just a quick question. Last night, I pulled off a red light pretty quick and when shifting into second, it seems as the gear was not engaged. The stick was in gear but It was as if the car was in neutral. This is probably a horrible explanation but I tried my best to explain. This has never happened before nor did it do it for the rest of the night. Any ideas? Sorry if this is a stupid question as I\'m not quite the professional mechanic as most of you are. Thanks a bunch, Nicolò
10-03-2011, 07:40 AM | #2 |
2021 X3MC
258
Rep 779
Anyone..?
10-03-2011, 08:14 AM | #4 |
145
Rep 3,329
this car is known to have notchy first to second when at high rpm. You need to ease into second gear instead of slamming it otherwise you might think your in gear but your in neutral or engaged half way and it will grind.
F80 ///M3 6MT Avus Blue ZCP |
10-03-2011, 09:13 AM | #5 |
M-Flight Member
38
Rep 1,085
DCT FTW!!!
Sorry guys, couldn't resist. Anyways, was it repeatable, or only a one time thing? Sometimes the 6M can be a bit finicky/notchy. Was the transmission still cold?
2011 Le Mans Blue M3// Black extended Novillo w/ Blue Grey Aluminum trim/DCT/ZTP/ZCW/ZPP/ZCP Premium Sound ///Akrapovic Evolution Exhaust
2015 Audi S4 Prestige, Brilliant Black S-tronic 2012 Le Mans Blue 135i M Pkg DCT |
10-03-2011, 09:59 PM | #6 |
2021 X3MC
258
Rep 779
yes, i let go of the stick and it remained in second before i put it in 3rd hoping it would work (which it did). no grinding or anything. quite weird but it has yet to happen again. i was just curious to see if anyone knew of a reason this could happen. i have absolutely no complaints with the car.
