09-21-2011, 05:45 PM | #1 |
8
Rep 169
Titanium Exhaust + OEM Exhaust Weight
I have search and searched and found nothing. I have heard every exhaust out there and none can give me what I`m looking for. So I have narrowed it down to keeping my OEM Exhaust (possibly modified) and upgrading my stock midpipes.
I have checked my options and most midpipes are about $2500 for stainless steel. A bit too heavy and price too steep for my taste. I contacted Akaprovic and their x-pipe is $2,400 but requires adapters to fit the OEM exhaust which are over $400 and have secondary cats, and I`m interested in full catless. BTW, weighed the OEM exhaust and: OEM Mufflers: 51 lbs OEM Midpipes: 40 lbs Total weight: 91 lbs! I have contacted several other companies so let's see what they say. Any other recommendations?
"All our knowledge has its origins in our perceptions."
-Leonardo Da Vinci |
09-21-2011, 06:04 PM | #2 |
56
Rep 783
Most catless x pipes from reputable companies are around $1,600 - $2,000.00; some even less. I highly suggest you look into the Challenge Race X Pipe or the Gintani Catless X Pipe as those seem to be the two most popular on the forum and have proven gains.
I believe both Alekshop and IND make the adapters for Akrapovic, they may have a cheaper price than $400. Akrapovic also makes a catless X pipe, but from what I hear it is a special order item. Good luck with your car!
2021 M3 6MT Brooklyn Grey/Silverstone
Previous: 2009 335i ZMP 2013 M3 6MT ZCP Space Grey/Fox Red |
09-21-2011, 07:00 PM | #3 | |
4th down; 4th quarter? Renegade.
87
Rep 3,850
But it doesn't hurt to try the minimal mod, and then adjust ; ) I think the Tubi rear section sounds amazing, but only a few people have it. Won't save much weight with it though, which is also a nod to the akra if you want to drop that much cash. I would also coat the tubi cans because they show. I can tell you the akra stuff is amazing in your hands - you will be shocked with the quality. Good luck! |
09-27-2011, 07:28 PM | #4 | |
8
Rep 169
09-27-2011, 07:37 PM | #5 |
8
Rep 169
So here an update. It's been about a week since I started my quest for titanium xpipe and so far it only led me to the Akrapovic which is almost $2,500 and requires an adapter directly from Germany that cost another $400. On my quest to find x-pipes for a reasonable price I got a response from a company in Japan that has them for $1800 shipped to my door! Weight is only 10.0lbs. So figure a 30lbs weight reduction and 15-20whp. Not bad. I`ll let you know as I find more information about this.
09-27-2011, 07:44 PM | #6 | |
23
Rep 148
09-27-2011, 07:56 PM | #7 |
8
Rep 169
Yes, but then you need adapters and then modify it the xpipe to make it work.
09-27-2011, 08:10 PM | #8 |
111
Rep 395
we weighed our E92 stock rear muffler on a UPS shipping scale and floated between 53-54 pounds...our DRB exhaust systems weighed in at 27 pounds...pretty good weight savings for a T304 stainless setup, one of lightest on market...
09-27-2011, 08:28 PM | #9 | |
337
Rep 1,489
I have been in the same boat and am trying MRF x pipe. It is modular so you can replace the the pipe the removes the cats with their HFC version. You may or may not like sound but it is of top quality and less than 2Gs. I am not affiliated just a customer and know what you are going through.
Check this thread for my own clips "Here is a clip of the stock exhaust and X pipe". Quote:
09-27-2011, 09:05 PM | #10 |
8
Rep 169
Sounds really good btw.
09-27-2011, 09:27 PM | #11 |
223
Rep 979
Akra evo saves 53 lbs over stock
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts |
10-11-2011, 08:48 PM | #13 |
8
Rep 169
Found an UK company that can make the X-pipe in Titanium for $1,600. Weights 10lbs.
