08-05-2011, 12:07 PM | #1 |
8
Rep 185
Houston, we have a problem!!!
Driving from Laredo to houston and suddenly got an engine error. Now reduced output... I just recently installed an intake and I don\'t know if that had anything to do with it... My engine SOUNDS LIKE SHIT!!!! I will try to make it to Houston. Where can I take it..??
08-05-2011, 12:09 PM | #2 |
327
Rep 3,882
Highly doubt it's the intake unless there was some install error involved. Check my sig, I "don't" run as non-stock of an intake design as you can get off-the-shelf right now, and after 7 track days, 0 problems....
Edit: I see that you drive a 2008. Sounds like your idle valve finally decided to let go? Have you ever had your idle valve replaced? Some people (like me) have it go out early (4,XXX miles) and some people (a friend) have theirs go out late (26,XXX miles). Last edited by LateBraking; 08-06-2011 at 12:02 PM.. |
08-05-2011, 12:19 PM | #3 |
Putcha ang ganda...
281
Rep 5,441
Dang i currently have 45k miles on mine and this shit scares me... no issues with mine so far...
Keep us updated POGI...
08-05-2011, 12:27 PM | #4 | |
327
Rep 3,882
Hell, it might even be covered out of warranty? It's a super common problem on 2008's. |
08-05-2011, 12:37 PM | #5 |
8
Rep 185
I was just driving when this happened. Funny you should mention idle valve because for the past few days I've noticed a slightly higher idle at start and what I thought to be less throttle response. I was thinking that it was my intake. I'm still driving now passing three rivers. Not from the Houston area but considering leaving my car there to get seen. Any suggestions..?
08-05-2011, 12:41 PM | #6 | |
327
Rep 3,882
BTW, by intake, what do you mean? Filter? aFe? Macht Schnell? Dinan? Or something closer to what I "don't" have according to my sig? Oh, and btw, feel free to call BMW roadside if you're trip to the dealer is going too slow....(no idea where you're out at and where you're headed). They'll tow your car there. Just be careful that the dealer won't blame you for something that would normally be covered on your intake just because you have one (they do stupid things, as you know). |
08-05-2011, 03:20 PM | #7 | |
Putcha ang ganda...
281
Rep 5,441
08-05-2011, 04:16 PM | #9 | |
327
Rep 3,882
If you go in maybe twice, and complain, then if it breaks out of warranty (I have no idea why yours has lasted so long) at least there will be a precedent for it. But of course, I in no way condone the above. Seriously. |
08-05-2011, 04:27 PM | #10 |
93
Rep 1,064
So many people have this idle control valve issue it's unreal.
You are not alone.... the V10 guys suffer from it aswell. The problem can get worse with a software write to the ECU or any type of flash at that.... even if it's just a speed limiter removal or dealer update. If you experience any type of idle roughness or limp mode get it seen to rather than panick. |
08-05-2011, 05:44 PM | #11 | |
588
Rep 15,818
IG:d.violet.m3
08-05-2011, 08:48 PM | #13 |
Bored at work....
891
Rep 5,393
Does anyone have the TSB number?
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
08-06-2011, 12:31 AM | #14 |
Putcha ang ganda...
281
Rep 5,441
well i have an appointment with BMW on Monday will be dropping the car off Monday night then ill find out what happens still dont have the error or engine light.... but my idle does flactuate for some reason, my idle is higher than normal now... almost at 1k cold or hot... traffic or not...
about a month ago my RPM just shoot up 3 times and now im worried. i cant wait on monday hope they will replace it even though its not showing a cel code... ill update... sorry to jack your thread bro.
08-06-2011, 12:36 AM | #15 |
Bored at work....
891
Rep 5,393
^^ No no, we all learn for this.
08-06-2011, 10:29 AM | #16 |
136
Rep 1,274
08-06-2011, 11:05 AM | #17 |
Heavy Footed..
18
Rep 206
i JUST hit 50k and almost cried.. i had a valve spring fail at 36xxx and havent had a problem since.. im going to put my faith in german engineering and just keep doing the proper maintenance on time. Does anyone know who has the highest mileage on their 2008's? i currently have 50009 and shes running strong
IB E92 - DCT - MS Stage 2 Intake - RPI exhaust - AiB - Matte black badges - Matte black grills - Reflector delete - Hardwired V1 - Loaded
Previous: '05 STi @408 awhp ~ Gone but definitely not forgotten... |
08-06-2011, 02:38 PM | #19 |
Bored at work....
891
Rep 5,393
08-09-2011, 08:26 AM | #21 |
8
Rep 185
Updates: drove for some time in limp mode then pulled over for a little break from driving. When I started her up again, limp mode was gone and everything seems fine. Made it to Houston and even drove back home to the rgv without anymore issues. I have since replaced my oem intake and filter and will be taking her in for service today. Truth be told I will be mentioning the icv. Thanks for everyones help..
