08-04-2011, 07:57 PM | #1 |
Rep 67
Acceleration problem...
Sometimes can be jerky between 2.5k to 3k rpm but not always, seems to pull ok between 3k-4k rpm but as soon as it gets a little above 4k rpm there is a pronounced jerk (dip in rpm) and instead of the engine pulling hard to redline it seems to just sputter along (reduced torque). Crazy thing is car is showing no codes what is going on here? Anyone have anything like this happen to them?? Car is an 03 Z4 3.0i with an AA tune.
08-04-2011, 08:11 PM | #2 |
2432
Rep 11,667
did it happen right after the tune?
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
08-04-2011, 08:24 PM | #3 |
190
Rep 2,431
most likely bad gas and the dme is pulling timing...if you want to quick check it then I recommend
NOS octane booster race formula, the one that raises 60 points<--and no I'm not kidding...the n54/55 guys have been using it to substitute race gas for their tunes...most pepboys have it
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
08-04-2011, 10:11 PM | #5 | |
Rep 102
http://members.rennlist.com/951_race...omparison.html |
08-05-2011, 08:25 AM | #6 |
Rep 67
@inTgr8r, it didnt happen right after the tune - right after the tune car ran GREAT! (was done in january, better than stock)
@wonton180, it has been about 40k since spark plugs were changed, could it be time for some new ones? Not sure it could be the gas as the problem has persisted over a coupe tanks from different Shell stations. Thanks for the inputs guys!!! |
08-05-2011, 10:11 AM | #7 |
MMA fighter and F1 test driver
18
Rep 362
do you have an AFE intake, mine did the same thing after I installed the intake. I reset the battery and it went away but after a couple hundred miles came back.
NOW:08 M.Coupe SMB #102/248 #1669/1815
:|MORRVS8|APEX8|SS.X-pipe|SS.PW.Loop|AFE.intake|Matte.grill|short.ant|Z HP.knob|interior.LED|bulletproof 09 Audi Q5 THEN:96Accord|98Camry|04TSX SC|06 M3|06A4|05Civic Si|05Imprezza|05S2000|08FJ |
08-05-2011, 10:28 AM | #9 |
Rep 106
I'm not sure how a aftermarket tune (ECU software we are talking about here?) would potentially affect spark plug life. If it's dumping more fuel in, I suppose it could accelerate wear.
the OEM plugs typically last 50-60K. The reason I said spark plugs is that they generally present as a studder during acceleration around the 2-3K RPM range. it's a cheap fix. |
08-05-2011, 11:11 AM | #10 |
Rep 67
@sho-one, I have a K&N air filter but a stock intake.
@Roffle Waffle, I was thinking it could be a TPS too until it showed no codes and then I was kinda dumfounded as to what could be causing this and why there were no codes. I was also thinking it could be the vanos related but I had the seals fixed about 40k miles ago so it shouldn't be that. If anyone else has any ideas please feel free to chime in. Hoping to try and fix this without having to take the car in. |
