08-04-2011, 12:20 AM | #1 |
30
Rep 740
Rubber hose behind battery in Z4MC
I was changing out the battery this evening since I found out that my coupe still had the original battery from 5 years ago and it was causing low voltage errors...anyways, I noticed there was this grey rubber tube that seemed to be connected to nothing (see attached photo circled in red). Any ideas what that is or if I need to connect it to anything?
Thanks, Gernard |
08-04-2011, 12:46 AM | #2 |
64
Rep 483
Isn't that the drain tube if the battery should leak? The acid won't eat the trunk, it will eat the suspension.
On my 3.0si it's pretty obvious it's a drain tube. It's a little tough to tell from this pic. Search around I think RoffleWaffle had some battery alternatives. Low voltages can wreak havoc on BMWs. Eventually you'll get stuck in "tow mode" and your AC and other accessories won't work. You'll need the dealer to reset tow mode. |
08-04-2011, 08:02 AM | #4 |
44
Rep 1,855
^ It vents hydrogen expulsions from the battery away from the cabin. On normal cars, the battery sit in the engine bay, so it vents directly to the outside (not cabin) already . . .
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
08-04-2011, 09:49 AM | #5 |
30
Rep 740
Santov, yeah the low voltage was causing the auto up and auto down on my windows to not work, and was messing with my trunk release a bit. The new battery is in and so far no issues from the 40 miles I test drove last night.
I replaced the battery with an OEM battery but didn't see a place to connect the tube, anyone have a picture that shows the location? |
