07-22-2011, 10:34 PM | #1 |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
So I destroyed my brakes
Ran Hawk HPS pads for 2 trackdays and completely used them. My mistake for not verifying after each session...I honestly thought they would last past 2 days. Anyways, ended up being metal on metal and warped the pads, piston and rotors. Instead of buying stock again, decided to upgrade . Car was not driveable so had it towed to garage and installed the kit. Wheels are stock 18s 9.5 all around. 12mm spacer in the rear but not needed.
So here goes Destruction: Upgrade: |
07-22-2011, 11:34 PM | #3 |
470
Rep 454
A new set of pads, and you used them up and warped the rotors in 2 track days??!? Holy wow - are these cars that hard on brakes??
Nice upgrade though... very very nice. |
07-22-2011, 11:37 PM | #4 | |
#thatsanicemovebro
202
Rep 3,920
me, not so much thx bud |
07-23-2011, 12:12 AM | #5 |
892
Rep 9,032
I hope Persian see's this. He almost got those pads for the track. They are NOT a track pad. They're not even that great of a street pad.
StopTech makes the Sport pad for the OEM calipers that would be a much better street/track pad.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
07-23-2011, 12:24 AM | #6 |
Sheetrock Intl.
28
Rep 128
Damn,
that's serious damage. Enjoy the new ones!!
"More tears are shed over answered prayers than unanswered ones"- Mother Theresa
07-23-2011, 01:41 AM | #7 | |
#thatsanicemovebro
202
Rep 3,920
last time im ever listening to anyone on the forums for advice. |
07-23-2011, 02:19 AM | #8 |
471
Rep 2,991
Yeah, HPS are horrible pads. I'd never run those on a track again, after I had a very similar experience. They are ok until they overheat and then they fall apart and basically never come back. Nice solution! Anyone who has a good experience is just slow (not that there is anything wrong with that!)
07-23-2011, 09:39 AM | #9 |
15
Rep 751
No, but some drivers are. Not to bash the OP, since the pad choice was a big part of the problem. But, brakes are consummable, and it's just a matter of weight, speed, and brake demand vs. brake capacity. If you burn through the pads with a fully track-ready brake system, you would see similar damage.
07-23-2011, 10:28 AM | #11 |
818
Rep 7,887
Hawk HPS's sure are not a track pad as you have discovered.It is a different world when you run a BBK with proper track dedicated pads.This year on my new car I went with a Stoptech 380/355 setup and been using Pagid RS29's and my brake concerns have been a thing of the past.8 trackdays so far and I will changing out my orginal front RS 29's which of course only takes about 5 minutes per corner when changing tires.
07-23-2011, 10:49 AM | #12 | |
#thatsanicemovebro
202
Rep 3,920
i think 14.5 or 14.25 not sure.
07-23-2011, 03:29 PM | #13 |
923
Rep 15,818
would you be able to someone get BMW to cover lol
doubt it i asked cause my friend warped his rotors..but he used stock pads with them how do you guys think the ST ones will do with the rotors? do i need to keep checking them...?
07-23-2011, 03:36 PM | #14 |
167
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
You're a freaking man. Do work.
07-24-2011, 04:18 AM | #15 | |
#thatsanicemovebro
202
Rep 3,920
yeah keep checking man to be safe |
07-24-2011, 10:01 AM | #16 |
9
Rep 134
Just curious, does anyone have experience with the HP+'s? That's what I was planning on putting on the car for track duty. I've ran them before on other cars and had good luck, but I'd rather not waste my time if you guys think they'll do the same thing as the HPS's. Thanks.
07-24-2011, 10:29 AM | #17 | |
15
Rep 751
07-24-2011, 10:42 AM | #18 |
9
Rep 134
I thought the Hawk HP+'s were a track pad? I definitely agree with you on what works for one does not necessarily work for all. I ran HP+'s on a number of cars, but all of them had better venting than the M3 does, and all of them had big brake kits that I either installed, or came from the factory. I definitely am looking for a pad that won't kill my rotors in one weekend. Otherwise I am going to have to install a big brake kit on the car and I am really trying to avoid that.
I'll take a look again at the HP+'s, but I swear those are track pads. Either that, or I've gotten extremely lucky with them and must be lighter on the brakes than I thought. Thanks a lot for the response. I'm also going to check and see if Stoptech makes a pad for track use on the factory brake system. Appreciate it! |
07-24-2011, 10:57 AM | #19 | |
chris
278
Rep 12,144
Btw, i've had good experience with hp+. I am no where near as hard on the brakes as gewow. I've even done hpde's with oem pads with minimal fade - maybe slight sponginess towards the end of the sessions but nothing major. It all depends on how hard u are on brakes and ur driving style.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
07-25-2011, 08:35 AM | #21 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
dam that sucks, but at least have a sick set of brakes
07-25-2011, 12:59 PM | #22 |
41
Rep 625
I use the Hawk blue pads in the front, and the +'s in the rear. Seems to work decently well for me, but nothing like a bbk. The HPS's are not up for the track duty. Good luck with the new AP BBK!
