BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
European Auto Source (EAS)
      07-18-2011, 10:54 AM   #1
persian54
persian54's Avatar
Drives: M760/G83M4
Alignment printout?
Does anyone with stock suspension have their alignment printout?
Specifically someone who is running negative camber
Thank you
      07-18-2011, 12:22 PM   #2
LiM3y
LiM3y's Avatar
United Kingdom
70
Drives: 2008 E90 M3
M3 alignment specs for 18" and 19"
      07-18-2011, 12:40 PM   #3
persian54
persian54's Avatar
Drives: M760/G83M4
Thanks but I'm actually looking more for one that isn't stock alignment specs (hence the negative camber part)
This may be one of my failed attempts at trying to do something and ending up messing things up..but thought I'd give it a try
e93 preferred, but prly won't get that, so e92?
or are all e9X the same?
      07-18-2011, 01:07 PM   #4
Merked M3
Merked M3's Avatar
Drives: E90 M3 6MT
I have pulled the front alignment pins for more negative camber:
Front left -1.75, 1/32
Front right -1.4, 1/16
Rear left -1.57, 1/16
Rear right -1.31, 1/16
I am running an E90 M3 with stock 18's and will most likely keep the same setup when I put the track 18's on. Do you want ALL the specs, SAI, caster, ect?
2008 E90 M3 6-MT - Sold but not forgotten - amazing car
The next car, my Porsche Cayman S
      07-18-2011, 01:09 PM   #5
persian54
persian54's Avatar
Drives: M760/G83M4
Essentially I'd like a printout so that when I go to the alignment shop, I can show it to them....
Cause I don't think I can go and be like "I want X negative camber. Thanks"
      07-18-2011, 08:59 PM   #6
Merked M3
Merked M3's Avatar
Drives: E90 M3 6MT
Cool, I am working tomorrow and will try to remember to turn it into a PDF.
      07-18-2011, 09:50 PM   #7
Martin_D
Martin_D's Avatar
Drives: Ford Super Duty
You can. Tell them to "bury" the camber
MAX front and rear, pull the pins.
      07-18-2011, 09:57 PM   #8
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
On a stock, mostly street driven car with occasional track use, I would do:
Front:
Max camber
Neutral toe
Rear:
-1.6 deg
1-2 mm toe
      07-19-2011, 12:43 PM   #9
persian54
persian54's Avatar
Drives: M760/G83M4
Front:
Max camber
Neutral toe
Rear:
-1.6 deg
1-2 mm toe
excuse my ignorance.... what do you mean by neutral toe?
When you say front Max Camber, that would be -1.2 correct? (without pulling out the pins)
My friend with a stock ZCP e90 M3got an alignment recently, he got:
Left Front: Right Front:
-1 camber -0.9 Camber
6.9 Caster 7.0 Caster
.05 Toe .05 Toe
Left Rear: Right Rear:
-2.2 Camber -2.2 Camber
.11 Toe .10 Toe
I'm thinking of either taking the car to West End Alignment ($120 I think?)
Or having my family friend do it ($60, he's been doing alignment for as long as I'm alive pretty much, but street cars, not track spec cars But if I give him the correct printout, I don't see why he can't mimic it)
Or going to BMW (their retail is $330, but I can get it for $150 as a special cause I just referred a bunch of people there). The tech said their alignment includes: "weighting the car to the proper ride height for exact angles while vehicle is in motion."
I would like to go to my family friend because:
A) He's 1 minute from my office (west end is a good 45 minutes)
B) cheaper
C) if it's wrong, I can go back for adjustment next day or something for free.
I'd like to go with West End because:
A) Great forum rep
B) lots of reviews
I'd like to go with BMW because:
A) well it's BMW so I'm assuming they'll warranty it if the alignment is off...
B) I can get it done at the same time I'm getting other stuff done, so it's the most convenient option
C) the whole "exact angles while in motion" is the first I've heard and it seems pretty..legit..?
Thanks for your inputs everyone
      07-19-2011, 12:46 PM   #10
persian54
persian54's Avatar
Drives: M760/G83M4
      07-19-2011, 12:58 PM   #11
Merked M3
Merked M3's Avatar
Drives: E90 M3 6MT
Neutral toe is zero.
Maximum negative camber varies on the vehicle, the specs my shop pulled for an M3 were -1.95 to -1.55 in the rear. But when the tech maxed it out, he could only accomplish -1.31. So if your looking to max it out, your better off saying that vs requesting a specific number.
Are you just trying to get the car to handle better?
      07-19-2011, 01:21 PM   #12
persian54
persian54's Avatar
Drives: M760/G83M4
This as well as being able to clear AD08 tires (265/30/19 295/30/19)
I don't want to rub, even if I daily drive with 4 people, top open, around crappy LA roads and freeways...
So does it matter which alignment shop I go to then? (from the 3 I listed)
I hear to many different things regarding alignment, it's getting very confusing..
      07-19-2011, 04:09 PM   #13
persian54
persian54's Avatar
Drives: M760/G83M4
I just remembered I got an alignment in May after I hit a pothole (it put a bubble in my tire so I knew it must have knocked something out of alignment, I hit it pretty hard..)
Found the sheet...
If I read it right.... I already have -1 Camber in the front? and -1.7 in the rear
Isn't that what is pretty much being recommended anyways....? Now I'm really confused
This is when I had my OEM 18s on
      07-19-2011, 09:43 PM   #14
Merked M3
Merked M3's Avatar
Drives: E90 M3 6MT
Here are my E90 M3 aligment specs, again the pins are pulled in the front so it may be more negative than you will be able to get.
      07-19-2011, 11:03 PM   #15
persian54
persian54's Avatar
Drives: M760/G83M4
Thanks
Your sheet is a bit confusing to read for me compared to others I've seen
Everyone is telling me to pull the pins out... what is a negative attribute of doing this? I'm a lease so I can't imagine putting them back in
Also, how do you take them out...?
      07-22-2011, 07:46 PM   #16
ShadeD1
Drives: 2011 X5 xDrive 35i
I just had it done. I had a bit of trouble getting it done but finally the owner of SW Alignment in Houston knew how. I'm taking it to the track tomorrow
Here it the DIY on pulling the pins
http://www.m3post.com/forums/showthr...highlight=pins
Thanks
      07-22-2011, 07:50 PM   #17
persian54
persian54's Avatar
Drives: M760/G83M4
put up your sheet
m3post
