07-15-2011, 04:31 PM | #1 |
58
Rep 912
Need new Z4M Rotors, suggestions?
My front rotors have gone to brake rotor heaven so i need new rotors / pads. I've changed pads for now because i can't help myself, i need to take the car for a spin or i will die.
What i know so far from research is that the OEM rotors are a 2 piece floating rotors and rank pretty high in performance and what i basically need is just to get OEM rotors, some aftermarket pads e.g.: axxis ultimate (very low dust) and to upgrade the brake lines to stainless steel and do a fluid change with a bleed, that should make the OEM braking feel much more solid then it is. Any suggestions based on experiences? i'd like to have some feedback. |
07-15-2011, 04:33 PM | #2 |
58
Rep 912
If you'd like to suggest a better aftermarket alternative that will fit on stock calipers, please be my guest. be sure to state why you think so because it's important to me.
07-15-2011, 04:46 PM | #3 |
13
Rep 505
Depends how you use your car... For just spirited driving stock setup will be just fine.
One of the advantages of running a true two piece aftermarket rotor is that after the initial investment you just have to replace the outer ring...u reuse the hat thus saving some money. |
07-15-2011, 04:52 PM | #4 |
58
Rep 912
Are you talking about the racingbrake rotors? if you are, I have come to realise that the rotor replacement cost as much as the OEM rotors so what's the point ? seems like i paid for an extra hat, that's it.
07-19-2011, 02:41 PM | #6 |
44
Rep 1,855
Racingbrake appears to be a better design, possibly longer lasting and/or lighter than the stock ones. Unfortunately, they don't stock our size any more, despite what it may say on the website. I tried ordering about 6 months ago. No go. They don't have our size "hats" any more.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
11-11-2011, 10:13 AM | #7 |
Rep 26
RB two piece rotor status just got updated.
http://www.zpost.com/forums/showpost...2&postcount=18 |
